Author Topic: KEycool 87 not working  (Read 3105 times)
Offline Wintermoot
« on: Tue, 25 September 2012, 11:28:45 »
I just got my KC 87 in the mail and it's not working, I already checked the cable and I was wondering if there is anything I should try before I send it back.
WASD V1 MX Blue|Keycool 84 MX Red
Offline jeroplane
Re: KEycool 87 not working
« Reply #1 on: Tue, 25 September 2012, 15:57:40 »
Specify what you mean by "not working". Is it just not being recognised by the computer at all? Have you tried restarting, trying different USB ports?
My signature hasn't changed since 2012. I should really update it.
Offline Wintermoot
« Reply #2 on: Wed, 26 September 2012, 04:13:26 »
plugging it in does nothing.
PS
I tried various ports and even different computers.
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #3 on: Wed, 26 September 2012, 05:51:18 »
This may sound stupid, but have you turned the computer off, plugged it in and restarted it?
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline Will@Drop
  • MD Co-Founder
    • Massdrop
« Reply #4 on: Thu, 27 September 2012, 02:41:46 »
I'd probably just send it back ASAP. If you got it through one of the ebay sellers you may have a very small window in which you can return it.
Offline Wintermoot
« Reply #5 on: Thu, 27 September 2012, 07:16:13 »
never mind, fixed it. I opened it up and it turned out that the cable that connects the USB connector to the main plate wasn't properly connected.
Offline Squiddy
« Reply #6 on: Mon, 01 October 2012, 13:08:32 »
I should be getting one of these tomorrow - how easy was it to disassemble?
« Reply #7 on: Mon, 01 October 2012, 20:20:15 »
y did you get keycool? is it cheaper?
