Author Topic: Holy Crap, Replacement Mousefeet from HK  (Read 2241 times)
« on: Sun, 30 September 2012, 12:16:25 »
I would've posted this in "great finds" "other hobbies" but they have far fewer traffic, and I was afraid that people who may need these would miss it.   ;)
http://stores.ebay.com/iTakTech/Mouse-Feet-/_i.html?_fsub=3652382016&_sid=1094877886&_trksid=p4634.c0.m322
They even have White Color replacement pads, you have to select "white" in the drop down box. theres a picture in the item description of the white.
Don't buy the 0.18mm mouse feet, i just measured my stock mx518 and g500 with a "ghetto" caliper,  the "new version" mx518 measures 0.5mm, it actually has a second layer under the teflon layer.
The g500 came out 0.43mm, but take that with a grain of salt, as my caliper is ghettto.
They have all the popular mice covered,  and they got the .5mm thick kind, which is better than some of the thinner stock pads.
Why did no one tell me bout this.  :))
I'm not the seller, I just came across this on youtube.
Offline Lethal Squirrel
  • I <3 60%
Re: Holy Crap, Replacement Mousefeet from HK
« Reply #1 on: Sun, 30 September 2012, 13:17:02 »
Thanks for sharing! My Ikari laser needs some bad :D
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Sun, 30 September 2012, 13:20:35 »
Good find. This is dirt cheap too. This thread is probably more fitting in the "input device" or "great finds" section.
« Reply #3 on: Sun, 30 September 2012, 14:49:04 »
aw crap, did I just screw myself, if this stuff get's popular, he's gonna jack up the price.
Relative to US income, this is cheap
relative to the amount of "material" that you're getting, they're still making hella' profit.  :))
