Author Topic: Razer Star Wars mouse is on sale on NCIX for 79.99 CAD, think of getting one  (Read 3310 times)
Offline Neo.X
Any owner here have an opnion on this products?
Thanks
All those keyboards will be lost in time....
Thanks
Almost all popular 5000+ dpi laser mice use the exact same sensor.
So any mouse using the "Avago DIP-16 Laserstream" will perform identically with respect to the user. You really don't EVER need to concern yourself with the technical specs they bold on the box, because it's all inconsequential.
That said, logitech- g600 seems a bit cheaper and does the exact same thing. So determine if the Starwars theme is worth the additional expense.
The only real differences comes down to software.
Just chk out some videos for that.
Offline Neo.X
Thanks.
I did some research, it turns out just a Naga with Star War makeup. I just stick on my Naga then.
