Author Topic: My CPU seems to have rather high temperatures  (Read 4513 times)
Offline Internauta
« on: Mon, 08 October 2012, 20:02:35 »
Just built this rig, I haven't touched any clock speeds or voltages. Just using a stock cooler, either stock coolers are really this bad or something is wrong...help?
Those temperatures seem quite high for just having a few things in the background running.
I'm thinking of maybe getting a corsair H100 soon, or RMA'ing the CPU.
Offline SmallFry
Re: My CPU seems to have rather high temperatures
« Reply #1 on: Mon, 08 October 2012, 20:06:43 »
The Ivy Bridges run at consistently higher temperatures. There is a thread in the Off Topic about taking off the silver part of your CPU and changing out the crappy heat paste/crust.
Offline Internauta
« Reply #2 on: Mon, 08 October 2012, 20:07:45 »
The temps are reasonably higher than sandy, but I don't think they should be quite this high.
Offline WRXChris
« Reply #3 on: Mon, 08 October 2012, 20:34:09 »
That does seem rather high, especially considering you're using Voffset and the temps are that high idling at only .968 volts.
I don't want to sound condescending, but have you tried re-applying thermal paste and made sure the hsf is fully seated?
Offline SmallFry
« Reply #4 on: Mon, 08 October 2012, 20:36:30 »
Here is how to remove the IHS to apply new paste to the die
Offline xJaPx
  • Oh, Herro!
« Reply #5 on: Mon, 08 October 2012, 20:45:40 »
Re apply tim, use AS 5 or some phobya HE grease, because those temps at under 1v are crazy
| Poker MX Red |
« Reply #6 on: Mon, 08 October 2012, 20:45:48 »
Yea, bro, De-lid is your only option if you want cooler temps.
Applying new paste to the space between the IHS and Die is not as effective as Direct die contact.
« Reply #7 on: Mon, 08 October 2012, 20:46:38 »
No, for Ivy that's normal... remember it will lower by 5-10 over time.
Offline CKTofu
  • I don't even...
« Reply #8 on: Mon, 08 October 2012, 23:48:31 »
After delidding and lapping my 3770K as well as using Coollaboratory Liquid Ultra in between both the Die & IHS, and the IHS & Heatsink, with a lapped H100 cooler, I have dropped temperatures to 51C Max at max load, stock clock.
Ducky Shine 2 - MX Red with Red LEDs
Offline nullstring
« Reply #9 on: Tue, 09 October 2012, 00:05:26 »
Thats still pretty high.
Mine is low 60's max load with much overvolting and overclocking. (2500k overclocked to 4.9Ghz)
Internauta: I would definitely try reapplying thermal grease and reseating. Something isn't quite right there.
Using one of these: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024
Offline Internauta
« Reply #10 on: Tue, 09 October 2012, 00:17:32 »
Going to get corsair H100, i'll apply some "better" thermal paste once I do that. Also keep in mind Sand Bridge have insanely low temp's, hence people easily getting 5.0ghz oc's. I'm going to try de-lidding it, too. I'll post updates if I decide to do so. Thanks!
Offline MechKey
« Reply #11 on: Thu, 11 October 2012, 16:58:16 »
MX-4.
« Reply #12 on: Thu, 11 October 2012, 19:20:38 »
That's exactly why I keep yelling at people who are buying Ivy, when Sandy is such a time tested, KNOWN performer... SOLID.... all the way...
Offline Skull_Angel
« Reply #13 on: Thu, 11 October 2012, 21:21:00 »
No body's asked what case you're using? Poor airflow could be a cause (and is in most instances I've seen with "odd" temps.); generally stock coolers are "just good enough" for stock speeds, but I'll agree that those max temps are a bit on the high side.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Fri, 12 October 2012, 07:29:21 »
Well 4.05GHz on an Ivy Bridge is going to run fairly warm. That's a reasonably decent temp really. I get 65 - 70C 4.5GHz @ 1.35v on my 2500k. And that's on a hyper 212.
EDIT: FAIL. Didnt realize you were idling... Yeah that's high, my 2500k is 70 peak at 100% load. I idle around 45ish. That's a bit high though.
« Last Edit: Fri, 12 October 2012, 07:30:59 by oTurtlez »
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #15 on: Fri, 12 October 2012, 10:34:54 »
Yo, I think you have at least 200mhz more to lock in at those settings. Post your bios screens so we can tweak it. ;D
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #16 on: Fri, 12 October 2012, 16:07:51 »
Will do tomorrow night. At a friends house now on my lappy. I tried to go 1.3v but it didnt like it >.> I guess clock can go up rather than voltage down :D
TOO BAD FOR YOU
Offline rayuki
  • RAAAAAAR
« Reply #17 on: Fri, 12 October 2012, 16:14:38 »
your complaining about 50C temps? those are fine on ivy, i ran my ivy at 90C for like 6 months D3 botting 24/7 with no issues.
what are your temps like under load, run a prime95 and report back.
these chips are built ford tough, dont stress mate.
« Last Edit: Fri, 12 October 2012, 16:16:26 by rayuki »
« Reply #18 on: Fri, 12 October 2012, 18:01:44 »
Yea, OR.... You could delid "like a boss" and get temps as low as Sandy.
« Reply #19 on: Fri, 12 October 2012, 18:03:21 »
1.35 is definitely enough for 4.7ghz, it's good enough for 4.8 if you have a silver chip. The highest "gold chip" I've heard of for 1.35 is 4.9, but i suspect the guy is actually reading the voltages wrong.
Mine is only capable of 4.8ghz at 1.35. I was disappointed, so I bought the stupid intel insurance. running 5ghz.
