Author Topic: How to rinse Cherry Blue keyboard?  (Read 3252 times)
Offline aegrotatio
« on: Tue, 09 October 2012, 09:40:37 »
I drenched my Cherry Blue keyboard with diet cola and it's pretty much not clicky on many keys.  The circuits are fine though.  Since it's otherwise ruined, I wonder if anyone knows what sort of solvent I can try to rinse this keyboard in?
Thanks.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline Lethal Squirrel
  • I <3 60%
Re: How to rinse Cherry Blue keyboard?
« Reply #1 on: Tue, 09 October 2012, 09:46:41 »
Rinsing it wont work. I did the same thing with my first mechanical keyboard. I put mine in the dishwasher, soaked it in the tub, sprayed it with a pressure washer, and some other things. The keyboard still worked, but nothing made the switches clicky again. You're gonna have to desolder every switches and clean them out individually. It sounds crappy, but that's the only way to do it. : (
« Reply #2 on: Tue, 09 October 2012, 10:41:16 »
If the contaminant was water-based, water will be the best thing to flush it out with. Unfortunately, "flush" implies a "through" motion and you are looking to clean out, among other things,  the interiors of a bunch of tiny nearly-closed boxes.
Adding some sort of soap is great for getting rid of the dirt, but adds even more dramatically to the rinsing problem.
Getting all the residue rinsed away is, for all practical purposes, impossible.
To use a really bad pun, you are hosed.
- D Trump 2026-10-24
Offline khaangaaroo
« Reply #3 on: Tue, 09 October 2012, 11:06:49 »
I've never had to deal with this problem before, but I would probably try soaking it for a few days in water, while actuating the keys every now and then while it's submerged. In theory, if you can get water into all the spaces, the soda should dissolve if you gave it enough time. A month of soaking? haha
« Reply #4 on: Tue, 09 October 2012, 17:30:54 »
Not really, if it was drenched then it's pretty much an ex-keyboard.
You can try alcohol-based solvents, but the only way to be sure, especially with MX blues, is to replace the switches.
Offline khaangaaroo
« Reply #5 on: Tue, 09 October 2012, 20:36:38 »
If you're going to get rid of it, can i have it? :P
Offline TheQsanity
  • SmallFry Lovin'
« Reply #6 on: Wed, 10 October 2012, 00:55:02 »
or me :D
I can make it click just as much or a little more than mx browns.
look up Deoxit F5 and D5(D5 is good for cleaning)
If you want to wash it don't use water based solvents( I heard distilled water worked though)
When you are cleaning it just make sure you don't let the contacts rust or use a solvent that would melt your plastic.
If all else fails Just mail it to me :)
SmallFry! <3
« Reply #7 on: Wed, 10 October 2012, 02:02:51 »
My god people, have some self-respect... You're all acting like a bunch of Bums..
Offline 1Ferdi
  • i am the catman
« Reply #8 on: Thu, 11 October 2012, 10:29:50 »
I did a similar thing to my Das with blues but with beer. Not sure how much i damage i did (smelled lovely + sticky switches) but i disassembled it and soaked the pcb in a bowl of ethyl alcohol while pushing the board down to actuate the switches several times. After letting it dry, i reassembled everything and it worked like a charm again except for one switch which feels a lot lighter than the others. It does click though.
« Last Edit: Thu, 11 October 2012, 12:26:01 by 1Ferdi »
Daily: Realforce 87U 45g uniform EK Edition
Filco TKL
Steelseries 6gv2 | G80-1501HAD | IBM Model M '91 Gray Label
Filco MJ2 | Noppoo Choc Mini | Das Ultimate S | G80-1000LFADE
Offline TheQsanity
  • SmallFry Lovin'
« Reply #9 on: Thu, 11 October 2012, 20:53:06 »
Light is good! It gives your keyboard character and the satisfaction of having a different feeling board!  :D
SmallFry! <3
Offline 1Ferdi
  • i am the catman
« Reply #10 on: Fri, 12 October 2012, 05:46:08 »
That's the way i see it, just glad it wasn't ruined :D
I would have gotten me some nice mx clears as replacement instead i guess.
Filco TKL
Offline MechKey
« Reply #11 on: Fri, 12 October 2012, 08:46:04 »
Rofl.  Pressure washer.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #12 on: Fri, 12 October 2012, 09:03:12 »
What kind of board or, more specifically, switch mounting type are we talking about?
PCB-mounted switches can be taked apart rather easily (even with a single small flat blade screwdriver; it's fairly quick once you get the hang of it). Drop switch tops and sliders in sopy water, put spring aside, swab out switch bottom using same water. Washing the PCB may not be a bad idea either, though at least Diet Coke shouldn't contain quite as much sugar that would turn into nasty acids easily. (Whether I would drink too much of the stuff is another matter. The daily dose of sweeteners like aspartame is probably best kept as low as possible.)
With plate-mounted switches, you are in fact screwed and would have to go the rather tedious desoldering route as outlined above.
