Author Topic: Does a keyboard with a usb 2.0 hub give you true usb 2.0?  (Read 1868 times)
Offline xyril
    • Youtube Channel (full of typing and gaming vods)
« on: Fri, 12 October 2012, 13:32:25 »
Title says it all...
for instance, gonna transfer my girlfriend's pictures from my camera using the usb2.0 port available with the TT MEKA G1 . Does the transfer rate will be the same as the original USB hub @ pc?
Offline Neo.X
Re: Does a keyboard with a usb 2.0 hub give you true usb 2.0?
« Reply #1 on: Fri, 12 October 2012, 13:56:01 »
I believe so. Because it's using an extra usb cable for the port.
All those keyboards will be lost in time....
Offline BucklingSpring
« Reply #3 on: Fri, 12 October 2012, 17:21:16 »
But not all keyboards with USB a hub will work well if connected to a USB hub themselve.
This is why I prefer boards without builtin hub.
Boards I own, click ->
« Reply #4 on: Fri, 12 October 2012, 17:26:47 »
Some keyboards have hubs. Others have hub + passthrough for the USB 2.0. Passthrough means that it is just a cable that is wired through the keyboard.
Offline gloster
« Reply #5 on: Fri, 12 October 2012, 17:36:20 »
Some, e.g. the Das Keyboard, provide power while others, e.g. the Matias quiet pro, provide an interface but will not charge a device.
Offline MechKey
« Reply #6 on: Fri, 12 October 2012, 18:48:59 »
Depends.  You have to read the specifications of the keyboard.  What is a Happy Hacking Keyboard?
Offline xyril
« Reply #7 on: Sat, 13 October 2012, 00:20:34 »
Hmm idk why i wanna go with a keyboard with a USB hub :S.....   and if in the future , a TKL keyboard + a USB hub would be awesome for me<3 !!!... but if you know any TKL version keyboard have a USBHUB dont hesitate to tell me .
Offline MechKey
« Reply #8 on: Sat, 13 October 2012, 10:00:02 »
Why did you ask then?
