Author Topic: Cherry Clear/Green/White Comparison  (Read 33673 times)
Offline newtrekemotion
« on: Sat, 17 November 2012, 09:48:58 »
To begin with
The Boards
First is a tenkeyless Leopold with Cherry MX Clears. Of these boards it is the one that I’ve had for the longest. Next, is a KBT Race with Cherry MX Whites. This is the only 75% board that I have ever owned, and that is probably my least favorite part of the board. Finally, is my newest addition, a Cooler Master Storm Quick Fire Rapid with Cherry MX Greens.
Some pics:
QFR
QFR and Race
Leopold and Race
Quickly, my thoughts on the different boards. My favorite for the keycaps is definitely the Race, though that is the only one with PBT caps. The Race is also my least favorite layout. I can’t quite get adjusted to the extra small control and shift keys on the right. In fact I’d prefer smaller arrow keys to have larger control and shift. The QFR definitely feels the most “rugged” of the three, and I’m fairly certain that it is the heaviest. That said the keycaps are probably my least favorite of the three, as I hate being able to feel the lettering so much (though I actually like the font). Though the biggest drawback on the QFR as a whole is the FN key and that it can’t be remapped at all. This is the only real negative against what I would consider otherwise the closest to a perfect keyboard for me (just give me a trackpoint and make the FN key remappable <- is that a word?). Now I haven’t said anything about the Leopold, but that is because it is just a solid board, nothing to really complain about. Also the most “standard” experience I would imagine to get.
As I want to focus on the switches and not the boards, I’ll be doing my best to put aside the differences in the boards. Ideally of course, the switch comparison would come from using the same board with different editions. As my soldering skills are basically nonexistent, and there isn’t, to my knowledge, a company that sells boards with these three switches, this will have to do for now.
Now that all of that is out of the way onto
The Switches
Clears:
    These were the second mechanical switch that I tried after MX Blues. I read quite a bit, mostly on here, about switches and the feelings obtained from them. I thought for sure that I would love the heavier feeling compared to the MX Blues and didn’t think that the lack of the click would bother me. Well I was partially correct. I do like heavier switches (obviously), and the noise of the Blues isn’t something that I’m particularly tied to. Clears are quite good, and compared to my time with Black Alps, I definitely like the Clears better. However, compared to the other two switches of this review this is by far my least favorite for just the switch. The Cherry switches that are not clicky seem to have a bit of a grinding feeling to them compared to the others. In speaking with a friend I finally came up with calling the clicky switches less resistant. That is they can be just as heavy, but they don’t seem to resist the keypress as much. As a result of this design I feel as though the clears do not feel as tactile as the weight implies.
Whites:
    I’m going in descending order of experience here, so next is whites. While, my time with Whites hasn’t been nearly as long as Clears, I instantly fell in love with the White switch compared to the Clears. They feel much more tactile to me, and as a result I actually bottom out less. Though this could also be from the White switch, at least according to the deskthority wiki, being much heavier, 80cN versus 55cN. My Race is, to my knowledge, the only PCB mounted board I’ve tried so far as well. So that may have an impact on my feelings here. At this point I honestly don’t know why the Whites are not more common, they seem to be a superior love child of the Clears and Blues. Also, I should point out that they are heavier, and quieter, than most “ghetto greens” since that usually involves a Black spring, at 60cN, and the louder Blue slider.
Greens:
    So the last switch here is the MX Greens which as stated previously, I have from the new QFR edition. In trying to eliminate all of the other possible variables from the equation, I would think that that my opinion of the Greens is very similar to the Whites. The activation point on the Greens seems a bit higher, which I like, but I cannot say with certainty if the the plate mounting has something to do with that. Perhaps someone with more knowledge can comment on this? The Green switches are definitely louder than the Whites, though I don’t have proper sound equipment to give anyone a video comparison between the two. The activation point aside, I think that any consideration between keyboards with either Whites or Greens is going to come down to other issues in the board. In my case the QFR is without a doubt a better made keyboard (even with what I consider to be much worse keycaps), and so I am more comfortable typing there. But if I try to look past anything like layout, then the switch comparison becomes basically a toss up.
So in summary, I’ve enjoyed all of these switches. Though I seem to favor the clicky switches, the noise is not something that I’m after, but rather a side effect of the design of the switches. I like the Whites and Greens about the same, and they are both heavier and, as I say at least, less resistive than the Clears. Though the Clears are definitely quieter and I’ll continue to use them at my cubicle in attempts to bother those around me as little as possible.
tldr: Greens ~= Whites, both are better feeling than Clears, but Clears are quieter.
In Mail: HHKB Pro 2
Current: Endura Pro
Past: Das Professional , KBT Race (White), CM QFR , Leopold TKL (Clear), Dell 101W (Black Alps)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Cherry Clear/Green/White Comparison
« Reply #1 on: Sun, 18 November 2012, 21:54:34 »
Thanks for this analysis! I was actually planning on obtaining the CM QFR with greens too! Looks like I don't need to hold back :) Would you just say that these greens are just a stiffer/heavier blue? I currently own a Ducky DK9008 with blues and the blue switches on this keyboard feel way different (stiffer) from any other blues I've felt on many other brand keyboards /w blues. I believe they the older cherry mx blues (sky blue) but I didn't think it would mean that the switches are stiffer than the newer blues (my experience)... Scared I'll receive the greens and not be able to tell the difference between my old blues and the greens.
« Reply #2 on: Sun, 18 November 2012, 23:43:46 »
Yes, greens are stiffer blues.  From feedback I've seen so far, most people seem to like them.
« Reply #3 on: Mon, 19 November 2012, 00:18:47 »
Thanks for doing a head-to-head of the uncommon cherry switches. Hopefully this will help people learn and decide about them, as well as clear up some common mistakes and confusion.
I have a hundred or so of each switch, and plan to put them into keyboards soon. Hopefully my findings will echo yours.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #4 on: Mon, 19 November 2012, 00:33:24 »
Awesome :P
I'll be looking forward to reading your thoughts too :D
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Mon, 19 November 2012, 00:43:42 »
There is definitely a difference between greens and blues, even if you have a slightly stiffer variant of a blue. Most people just merely state that greens are stiffer than blues, but there's more to it than that. Even though they have the exact same stems, greens feel a tad less tactile because the click feel and sound is reduced. This is the result of a heavier spring. So more stiff, but less tactile.
Offline SmallFry
Re: Re: Cherry Clear/Green/White Comparison
« Reply #6 on: Mon, 19 November 2012, 00:56:27 »
Hundreds? Oooh shiny... name your price!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #7 on: Mon, 19 November 2012, 01:01:26 »
Yeh, it physically makes sense that the tactility of the switch would be softened by the stiffer springs. Even though I love my stiffer blues because of the weight and hard click, I would love to feel the combination of a stiffer switch with a smoother click. I can only imagine it's a mixed feeling between blacks and blues but a lil' stiffer.
« Reply #8 on: Mon, 19 November 2012, 03:06:54 »
lol a hundred or so of each switch type is about enough to make one full keyboard with each switch.
    • youtube
« Reply #9 on: Mon, 19 November 2012, 03:53:19 »
Black springs are equivalent to green springs. I would define it as a clicky tactile switch more than a linear one, so it's not really a hybrid of blue and black switch because you don't get the smoothness from the black switches.
Offline gameaholic
« Reply #10 on: Mon, 19 November 2012, 05:19:25 »
Is there a chart somewhere of which springs and which stems are identical other than color?  I've heard that blue and green stems are identical, red and black stems are the same, and that red, blue and brown springs are the same.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
« Reply #11 on: Mon, 19 November 2012, 06:35:58 »
Thanks! That is exactly what I was trying to do. I knew that when I first started looking at mechanical keyboards (and geekhack as a result), that something like this would have helped me and now I had the opportunity to do it.
You'll definitely be able to tell the difference. I'll pull out my Das (I packed it up since it is for sale) and try to add a section for Blues, but it will have to wait until tonight.
Not according to http://deskthority.net/wiki/Cherry_MX_Green and http://deskthority.net/wiki/Cherry_MX_Black Those say that Black is 60cN and Green is 80cN, so if you took the springs from Greens you could make an even heavier Black, but not still not have http://deskthority.net/wiki/Cherry_MX_Super_Black
In Mail: HHKB Pro 2
Current: Endura Pro
    • youtube
« Reply #12 on: Mon, 19 November 2012, 07:37:39 »
Not according to [link] and [link] Those say that Black is 60cN and Green is 80cN, so if you took the springs from Greens you could make an even heavier Black, but not still not have [link]
Well my last post was based on the last time I opened up my green and black switches, not what I read in wikis. Since what I remember conflicts with what you posted, I'll go back and check again later today.
« Reply #13 on: Mon, 19 November 2012, 07:51:54 »
Thank you. If we find that the wiki needs to be corrected then incorrect information will stop being spread through that channel. I apologize if I came accross as rude.
In Mail: HHKB Pro 2
Current: Endura Pro
Offline jeroplane
« Reply #14 on: Mon, 19 November 2012, 07:59:29 »
Actuation force does not depend solely on the spring. For example, Blues require 50cN while Reds require 45cN, despite having identical springs. While I haven't measured myself (got some samples of each coming in soon), I'm pretty sure the slider/plunger mechanism of Greens, much like Blues, results in a higher actuation force than Blacks with identical springs.
« Last Edit: Mon, 19 November 2012, 08:01:32 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
« Reply #15 on: Mon, 19 November 2012, 08:09:20 »
Actuation force does not depend solely on the spring. For example, Blues require 50cN while Reds require 45cN, despite having identical springs. While I haven't measured myself, I'm pretty sure the slider/plunger mechanism of Greens, much like Blues, results in a higher actuation force than Blacks with identical springs.
This is very true. However, if the slider/plunger is the same in Greens as it is in Blues as well as Blacks and Reds, then wouldn't the force difference be the same? I mean, if the Blue mechanism takes an additional 5cN over the Red machanism then shouldn't the Green mechanism take an additional 5cN over the Blacks?
In Mail: HHKB Pro 2
Current: Endura Pro
Offline esoomenona
  • Gnillort?
« Reply #16 on: Mon, 19 November 2012, 10:54:14 »
Hello everyone. My boy pointed me over here to help you guys out. Take a look through this guide for information you may have regarding comparisons between the different Cherry MX switches, stems, and springs. It is very informative and full of science in relation to keyboards.
« Reply #17 on: Mon, 19 November 2012, 13:13:57 »
"Ripster keyboard science" sigh
Offline Neo.X
« Reply #18 on: Mon, 19 November 2012, 15:45:23 »
Thanks for this greal article! I need white and green to fulfill my  MX collection.  :) :)
All those keyboards will be lost in time....
Offline shawn o
« Reply #19 on: Mon, 19 November 2012, 21:36:07 »
Hmmm, where can one buy a bunch of whites? In the USA.
mx1a-a1nn I believe.
« Last Edit: Mon, 19 November 2012, 21:41:47 by shawn o »
Online tp4tissue
« Reply #20 on: Mon, 19 November 2012, 22:24:35 »
Greens are Fantastic for typing, because you don't need to hold down keys.. However for fps gaming, one is much better off with lighter switches...
Greens are too powerful to hold down for extended periods, especially considering you'll need to hold down several keys in an FPS.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #21 on: Mon, 19 November 2012, 23:18:19 »
Agree but I think they would be amazing for RPG's and Starcraft II.
« Reply #22 on: Mon, 19 November 2012, 23:36:58 »
You said the same thing about MX blacks when I was asking about them :)
I probably have stronger fingers, but I have no problems playing FPS agmes on MX blacks.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #23 on: Mon, 19 November 2012, 23:59:30 »
I own Cherry MX reds for my linear keyboard (great for all types of gaming and also for typing) but I used to own a SS 7G and I personally think blacks are the best FPS switch. I only sold it because I don't play enough FPS games to make it worth keeping.
« Reply #24 on: Tue, 20 November 2012, 22:17:23 »
I haven't had any trouble with it, though I haven't played more than about 3 hours at a stretch yet. I think I prefer reds for gaming (slightly) but greens are excellent all-purpose switch for people whe like heavy switches.
Oh, bytheway, I took a bunch of comparison pictures between green and white, and hosted them up on my photobucket. If anyone's interested, here's the link:
http://s92.beta.photobucket.com/user/dork_vader/library/Keyboards
(Despite what the currency test shows, I believe whites are about 2g lighter than greens, I believe this is for the same reason blues are 5G heavier than browns, and is also related to the fact that whites are quieter.) (EDIT: Apparently, I haven't posted currency test photos yet. If anyone wants, PM me and I'll try to remember to upload them sometime)
My switches are not for sale, 'cause they're all going to be used. I actually don't think I'll have enough to fully stuff all my upcoming keyboards, and will have to buy more loose switches again! :0
Offline gameaholic
« Reply #25 on: Thu, 22 November 2012, 13:16:06 »
I'm also wondering how lubing the switches affects actuation force.  I've seen the test where people stack nickels or weights on the switch until it depresses.  Is the the standard test or is there another?  Also could someone make a matrix of what you get when you combine different springs and stems?  Maybe we could link it to reviews of each combination.  Something like this:
please excuse my terrible excel skills btw
oops ergo clear in wrong slot
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #26 on: Mon, 25 November 2013, 04:56:20 »
I have a chance to try out Green on the QWERKeys Sampler Kit and yes, it feels like clicky as Blue but as stiff as White (a bit less), I'd definitely recommend Green to Blue
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline LouisHjelmslev
  • This is all so complicated
« Reply #27 on: Mon, 25 November 2013, 06:45:50 »
Thought it was more of a continuous conversation. Off by just 3 days .... + 1 year  :)
« Reply #28 on: Mon, 25 November 2013, 15:19:11 »
+1
I had the blues, but felt something was lacking.
Then I got black, and never looked back.
Now I have gone green - the best of both worlds!
Offline divito
« Reply #29 on: Tue, 26 November 2013, 19:59:10 »
True story. <3 Greens....still can't wait to get White or Clears though to try.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
