Author Topic: Hard Drive temperatures  (Read 2049 times)
« on: Sun, 25 November 2012, 05:01:21 »
All my drives run 23C, they're fan-cooled and not in a case.
However, I've got this suckgate external which runs at 53C... Seems really hot...  >:D
Should I just pull it and run sata?
Offline davkol
  •  Post Editing Timeout
Re: Hard Drive temperatures
« Reply #1 on: Sun, 25 November 2012, 05:14:38 »
IIRC temperature doesn't matter much as long as it doesn't change a lot.
Offline damorgue
    • Personal portfolio
« Reply #2 on: Sun, 25 November 2012, 05:16:45 »
23C is worse than 53C. It is worse to run them too cold than to run them too hot. The manufacturers take the thermal expansions into account, and the drives are meant to run hotter than 23C. This is an annoying myth because common users try to make them run as cold as possible.
Edit: Quote from Google and their huge pool of data regarding hdd life expectancy:
"The figure shows that failures do not increase when the average temperature in creases. In fact, there is a clear trend showing that lower temperatures are associated with higher failure rates. Only at very high temperatures is there a slight reversal of this trend."
See the huge amount of failures at the lower end of the scale?
« Last Edit: Sun, 25 November 2012, 05:25:28 by damorgue »
