Author Topic: replace windows keycaps realforce  (Read 2767 times)
Offline blackrim
« on: Thu, 20 December 2012, 08:47:28 »
Does anyone have a good way to replace the windows keycaps (the dome is really annoying) on the realforces without getting a whole set and using arrow keys or something similar? I really don't want to have to buy a whole set of keycaps to replace two keys.
Realforce TKL 45g | HHKB (white and black) | Filco TKL blues | Das Ultimate browns | Kinesis Advantage
Re: replace windows keycaps realforce
« Reply #1 on: Thu, 20 December 2012, 08:54:09 »
Quite simply, Move both Window keys to "Right Ctrl" and "right function position"
Those are a very uncommon place for you hands to be..
Offline blackrim
« Reply #2 on: Thu, 20 December 2012, 09:02:39 »
Hm, I think we may be talking about different things. I want to actually remove and replace the keys with ones that don't have domes. I actually don't use the keys at all (linux user anyway). I just don't like the domes.
Offline Yuuki
« Reply #3 on: Thu, 20 December 2012, 09:17:49 »
In gnome it's quite useful. It brings the app menu with the search bar (by default I think)
Offline esoomenona
  • Gnillort?
« Reply #4 on: Thu, 20 December 2012, 09:34:46 »
I don't know what you could replace them with. Elite Keyboards has topre sets but those have the same Windows keys; even the blank sets.
Offline blackrim
« Reply #5 on: Thu, 20 December 2012, 09:53:31 »
Yeah, my current worst case scenario would be buying a blank set from EK and replacing the windows keys (and some of the others while I am at it) with arrow keys or some of the others that are low on the keyboard and the same size. Not a great option.
« Reply #6 on: Thu, 20 December 2012, 10:01:02 »
Oh I c, it's an OCD problem, LOLOL... you might wanna speak to a psychotherapist for that.... ;D
Offline blackrim
« Reply #7 on: Thu, 20 December 2012, 10:56:56 »
Ha, well if i did that I wouldn't own so many boards cause I would be fine with a rubber dome like millions of others :-p
Offline nar
« Reply #8 on: Thu, 20 December 2012, 14:46:41 »
Well if you are fine with red, I have a spare red menu key that you can use for the windows key that I can sell.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline blackrim
« Reply #9 on: Thu, 20 December 2012, 16:05:44 »
I am fine with red but i would need two.
