Author Topic: New keyboard recommendation  (Read 4079 times)
Offline Flyersfan1
  • Hi!
« on: Sat, 12 January 2013, 22:37:17 »
Hi All! I'm new to geekhack, this is such a great forum and I'm so bummed I didn't discover it sooner!  I was looking for a little bit of help in picking out a new mechanical keyboard, I'm definately going for something with Cherry MX Blues and have a budget of around 65-80 dollars.  The two keyboards that really caught my eye that were well within my budget are the Rosewill RK-9000 and the CM Storm QuickFire Rapid.  I know both keyboards have gotten pretty high praise around these forums. I like the idea of having a more full size keyboard that the Rosewill model offers, but got a little worried reading numerous reviews on Amazon and NewEgg that the mini USB connector is somewhat prone to failing after a short while.  I don't know too much about the CM model other than the fact that it's a little smaller and is perhaps more portable.  They both look really solid as far as build quality and user experience are concerned so it's been kind of a tough decision to make.  Any recommendations on which model I should go for would be most appreciated, this will be my first mechanical keyboard so I'm very excited to finally get to use one.  Thanks so much for reading!
Quote from: Photekq
Re: New keyboard recommendation
« Reply #1 on: Sat, 12 January 2013, 22:55:53 »
If you REALLY REALLY need a keypad, you can get a separate inexpensive mechanical keypad
I'd recommend the Quickfire Rapid TKL, and use autohotkey, you can easily replace the missing keypad..
Remember only the TKL Rapid and Trigger is made by Costar, the other one is made by iRocks..
http://www.amazon.com/ADESSO-AKP-220B-Adesso-Mechanical-Numeric/dp/B0038KN3YY/ref=sr_1_1?ie=UTF8&qid=1358052834&sr=8-1&keywords=keypad+mechanical
« Reply #2 on: Sat, 12 January 2013, 23:23:15 »
QFR - lots of Rosewills seem to have delicate USB connectors (although it has been reported as being fixed, nevertheless reports continue to come in of people having broken ones).
Offline Preach
  • The Insane
« Reply #3 on: Sun, 13 January 2013, 00:22:41 »
I came from a laptop squishy nasty feeling membrane keyboard to a tower with mechanical keyboard. I bought the QFR rapid, just with browns because that switch met my needs most.
 I can say after about a month or two of using the QFR that I will never look back.
Gaming on them is very nice. I play wow and have to press a lot of keys rapidly. I also type a lot. Overall the QFR has met every expectation and then some.
Little side note:
     I watched a video of a razer keyboard being destroyed with a QFR used as a weapon. That was part of the reason I pulled the trigger on the QFR instead of another board.
QFR - Browns |
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #4 on: Sun, 13 January 2013, 00:33:13 »
I'm gonna side with rowdy on this one. Quickfire Rapid is an EXCELLENT budget board with a wide variety of things you can do to it later on if you get more budget. Highly recommended.
Having a bad day?
Offline Flyersfan1
  • Hi!
« Reply #5 on: Sun, 13 January 2013, 10:50:41 »
Thank you so much for the recommendations guys! Just to clarify, the QFR is still made by Costar right?
« Last Edit: Sun, 13 January 2013, 10:59:55 by Flyersfan1 »
Quote from: Photekq
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #6 on: Sun, 13 January 2013, 22:42:10 »
Yeah, i think so.
Having a bad day?
« Reply #7 on: Sun, 13 January 2013, 22:51:39 »
explain? what are you "doing to it"
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #8 on: Sun, 13 January 2013, 22:54:02 »
Having a bad day?
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #10 on: Sun, 13 January 2013, 23:04:11 »
How do you know that's all i changed? Seems rather presumptive.
Having a bad day?
Offline Preach
  • The Insane
« Reply #11 on: Mon, 14 January 2013, 04:06:20 »
What else did you change? Cause I was actually looking at mods for the QFR. Whether it be cases like some other boards have, etc.
QFR - Browns |
Offline Magnusian
« Reply #12 on: Mon, 14 January 2013, 04:08:59 »
I too really like my QFR, it's a great little piece of kit.
Model M 1390120 1986  | Unicomp Customizer 104 1-Piece Keys | Franken M IBM 1390120 1987/Unicomp U4044A 2007 hybrid | CM QFR Cherry MX Greens
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #13 on: Mon, 14 January 2013, 04:20:46 »
I just changed a few of the switches out. Nothing special.
Having a bad day?
Offline Mountain Man
« Reply #14 on: Mon, 14 January 2013, 07:18:38 »
I can't say enough good things about WASD Keyboards.  Can't go wrong with them.
Offline Germiphene
« Reply #15 on: Mon, 14 January 2013, 13:14:40 »
I would recommend not going with a Rosewill.  My first mechanical was a rosewill with blues, and it lasted for about 3 months before a switch stopped working.  Stupid me threw it out before harvesting the rest of the switches  >:D.
HHKB pro | RF 87U | RF 87U uni-45g | CM QFR | Steelseries 6Gv2 | Filco MT2 | IBM model M | IBM SSK '87
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #16 on: Mon, 14 January 2013, 13:17:10 »
If you're ok spending a little more money, buy the Quickfire TK and have the best of both worlds!
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #17 on: Mon, 14 January 2013, 17:42:24 »
I would never buy a rosewill for a first board- if you want to know about rosewills, ask TotalChaos
Go with the CM QFR
Btw, you're a Flyers fan? I bet you're excited about the end of the lockout :)
« Last Edit: Mon, 14 January 2013, 17:47:11 by uJalled »
« Reply #18 on: Mon, 14 January 2013, 18:20:26 »
throwing it out was your first response? ;D
that's totally n00b  :))
Offline Flyersfan1
  • Hi!
« Reply #19 on: Mon, 14 January 2013, 18:55:55 »
Go with the CM QFR
I'm a huge flyers fan! And yes, i'm totally psyched! I really can't thank you all enough for all help, ordered a QFR from NewEgg yesterday.
Quote from: Photekq
