Author Topic: Pressing enter turns on capslock  (Read 1541 times)
Offline HaiiYaa
« on: Mon, 14 January 2013, 08:34:58 »
I am using a cm storm quickfire tk and before I had this problem where the LED turned off every time I pressed the enter key
Now capslocklock turns on everytime I hit enter :( Anyone know how to fix this?
Re: Pressing enter turns on capslock
« Reply #1 on: Mon, 14 January 2013, 13:58:53 »
almost surely the pcb has excess solder somewhere causing a short... Hopefully it's on the back side, and not the front.
« Reply #2 on: Mon, 14 January 2013, 16:39:54 »
OH, also, i heard the different NKRO mode may cause mischievous behavior on certain motherboards.. So try toggling that too.
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #3 on: Mon, 14 January 2013, 17:34:50 »
Didn't read yours :P - what he said
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #4 on: Mon, 14 January 2013, 17:41:34 »
Hit on capslock for enter next time, and switch the key caps.  :p
