Author Topic: My Leopold TK MX Brown keyboard w/ white PBT keycaps  (Read 4998 times)
Offline jukaduke1184
« on: Tue, 15 January 2013, 21:35:32 »
My current keyboard:
Re: My Leopold TK MX Brown keyboard w/ white PBT keycaps
« Reply #2 on: Tue, 15 January 2013, 21:38:20 »
haha. Nah, I think i'm gonna stop here. I'm a simple man.
« Reply #3 on: Tue, 15 January 2013, 21:39:34 »
We'll see about that :)
Offline akuJIWA
  • Lock 'N Load!
« Reply #4 on: Tue, 15 January 2013, 21:42:02 »
dat spacebar
The Cheat - B/R/B ; Clear switch with 62g springs
quit
« Reply #5 on: Tue, 15 January 2013, 21:42:37 »
that's what I said... then I was like.. ooooo... aluminum Case... shiny....
then.. I'd tell myself, that's completely useless....
then I'd go,, but it's aluminum....
I drink a can of coke... and went, f&^c it.. and bought the vortex case.
« Reply #7 on: Tue, 15 January 2013, 21:47:51 »
Yeah. Unfortunately, the space bar that came with the keycap set didn't fit. Looked a little deformed. Not a big deal for me.
Offline keymaster
  • Topre Revolution Theorist
« Reply #8 on: Tue, 15 January 2013, 21:58:29 »
Hello,
Where did you purchase these PBT keycaps? I've been thinking about getting a set of 87.
Offline missalaire
  • Great Finder of Great Finds
« Reply #9 on: Tue, 15 January 2013, 22:02:29 »
Hello,
http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=40 has them. They only have full 108 key sets available though.
« Reply #10 on: Tue, 15 January 2013, 22:06:46 »
As the above person said, I got them at www.mechanicalkeyboards.com I really liked them but, like I stated earlier, the space bar was a little deformed so couldn't get it to fit. Probably a bad one. Nothing to be too hesitant about.
Offline keymaster
« Reply #11 on: Tue, 15 January 2013, 22:08:00 »
Hello,
I see. However, the Leopold has different sizing on its space bar so I don't think the space bar that came with the set is deformed.
« Reply #12 on: Tue, 15 January 2013, 22:16:25 »
Ahh. I did not know that fact. Guess I gotta apologize to Ducky for that angry email  ;)
Offline keymaster
« Reply #13 on: Tue, 15 January 2013, 22:17:44 »
Here's the thread: http://geekhack.org/index.php?topic=15482.0
You should read through it :)
« Reply #14 on: Tue, 15 January 2013, 22:21:39 »
Cool. thanks for the link.
Offline Saturn
« Reply #15 on: Wed, 16 January 2013, 01:10:01 »
dat spacebar
i wonder if i'm crazy that i would switch keyboard entirely for that reason alone (non-matching spacebar)
Offline keymaster
« Reply #16 on: Wed, 16 January 2013, 09:38:03 »
dat spacebar
You're not alone. It would bother me to the same extent.
« Reply #17 on: Wed, 16 January 2013, 13:19:10 »
dat spacebar
Matching spacebar might not necessarily be the way to go...
as long as you have a good trim color for it.. it should look fine.
Offline Preach
  • The Insane
« Reply #18 on: Wed, 16 January 2013, 13:36:39 »
Aaahh simplicity. I like it.
QFR - Browns |
Offline eth0s
  • Peace & Love
« Reply #19 on: Wed, 16 January 2013, 16:13:15 »
For a simple man, my advice is simple:  get moar keyboards.
Offline jooks1184
« Reply #20 on: Wed, 16 January 2013, 17:49:25 »
Coincidentally , I'm lookin to get a green alps board.
