Author Topic: What 105-key Full keyboard do you recommend?  (Read 8731 times)
Offline Wopian
  • Why Hello There.
    • Bobstudios
« on: Sun, 20 January 2013, 08:27:57 »
Looking for a new mechanical keyboard to replace my old TKB020 (which replaced my IBM Model M a few years ago :( )
Do you have any you recommend? I'll also probably be replacing the key caps with custom ones.
Re: What 105-key Full keyboard do you recommend?
« Reply #1 on: Sun, 20 January 2013, 08:40:20 »
Sup dude,
CM-Trigger if you're a younger kid
Filco 104, if you're a bit older
Topre 104 if you're older and have a job
Filco/Topre with Aluminum Casing, if you "understand" the hobby
I don't like how people keep using the word "custom"
Is there really anything "custom" about buying mass available retail products?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Sun, 20 January 2013, 08:43:42 »
Go backwards. Get another Model M. Caps? pckeyboard.com
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #3 on: Sun, 20 January 2013, 08:52:33 »
I define "custom" as a modification to the stock parts.
« Reply #4 on: Sun, 20 January 2013, 09:30:20 »
Filco 104.
I bought the Ninja but I thought the stock keys were awesome. You could get the normal top printed version and save yourself a few bucks.
Offline BucklingSpring
« Reply #5 on: Sun, 20 January 2013, 10:37:05 »
Are you on a budget?
+1 for esoomenona suggestion - If you liked the M - pckeyboard.com -> Unicomp
Boards I own, click ->
« Reply #6 on: Sun, 20 January 2013, 10:41:38 »
yea but remember, unicomp only sells grey/beigh/black keycaps. "they're available in Blanks
Offline baldgye
  • Will Smith Disciple
« Reply #7 on: Sun, 20 January 2013, 10:45:47 »
what you gona do to your caps? :S
...but as a filco user I'm very happy and they come in most languages and layouts too if you want a proper UK layout
Offline FoxWolf1
  • 154
« Reply #8 on: Sun, 20 January 2013, 10:49:23 »
From Unicomp site:
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #9 on: Sun, 20 January 2013, 13:21:45 »
EDIT: Guess i'll just go for 104, 105 seems very unpopular overall. Is this any good? Elite Keyboards FC500RT/AB (Brown Switch). Gives me much more left over of my £130 budget.
« Last Edit: Sun, 20 January 2013, 13:54:46 by Wopian »
Offline swagpiratex
« Reply #10 on: Sun, 20 January 2013, 14:21:40 »
tp4 was spot on, imo.
Offline iri
« Reply #11 on: Sun, 20 January 2013, 15:56:48 »
i'd go for a unicomp keyboard
-Ray Bradbury
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #12 on: Sun, 20 January 2013, 16:04:12 »
Thanks guys ;)
Going to order Topre 104 later this week.
« Reply #13 on: Sun, 20 January 2013, 16:05:39 »
From Unicomp site:
F---ME... Really????????????? They have orange???????? wow.. Ordering....
Offline iri
« Reply #14 on: Sun, 20 January 2013, 16:06:04 »
got some pm's convincing you to buy a topre?
-Ray Bradbury
Offline iri
« Reply #15 on: Sun, 20 January 2013, 16:06:34 »
also lolz @ tp4
-Ray Bradbury
« Reply #16 on: Sun, 20 January 2013, 16:08:07 »
Thanks guys ;)
I see you are "adult" and "have a job",, wonderful.... ;D
Ah... if you do get a 104 though, just remember that they usually.... do not make full size Aluminum Cases, so if you plan to go "metal" in the future.. You might consider getting a 87 TKL...
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #17 on: Sun, 20 January 2013, 16:18:43 »
Thanks guys ;)
I be no adult! But I do have a pretty good job for my age.
Offline Tym
« Reply #18 on: Sun, 20 January 2013, 16:20:41 »
If you are still looking, the steelseries 6gv2 is good value for monies?
http://shop.steelseries.com/uk/keyboards/steelseries-6gv2.html
£64.99
« Reply #19 on: Sun, 20 January 2013, 16:22:35 »
Thanks guys ;)
what job, drug dealer?
« Reply #20 on: Sun, 20 January 2013, 16:24:17 »
£64.99
Imo, the big enter key doesn't feel as smooth as smaller enter keys, because the stabilizers don't do a good enough job for that "SHAPE"
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #21 on: Sun, 20 January 2013, 16:36:58 »
£64.99
May I ask what switch type it is?
Offline esoomenona
  • Gnillort?
« Reply #22 on: Sun, 20 January 2013, 16:37:29 »
Aren't all steelseries MX Blacks?
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #23 on: Sun, 20 January 2013, 16:50:06 »
Thanks.
Offline esoomenona
  • Gnillort?
« Reply #24 on: Sun, 20 January 2013, 16:50:56 »
^Don't take my word for it. That's all I've ever seen. That's why it was a question.
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #25 on: Sun, 20 January 2013, 16:57:53 »
They have one marked as Red in the title, so i'm guessing they will be as they would say if their keyboard switches varied.
« Reply #26 on: Sun, 20 January 2013, 18:11:58 »
Thanks guys ;)
Woot! So much for the budget thing :-)
Which one are you aiming for? I'm not big on their boards with variable weight switches. But I really love the all 55g's
Offline volatilecoffee
  • Formerly ybnrmalatall
  • I don't feel any certain way.
Linear gang needs to rise up against the tactile hipsters.
« Reply #28 on: Sun, 20 January 2013, 18:51:33 »
Sup dude,
Do they sell aluminium cases for 104 Filcos? I've seen aluminum cases for the Filco TKL but wasn't even sure if they existed for 104s.
« Reply #29 on: Sun, 20 January 2013, 19:49:20 »
Sup dude,
come to think of it, i don't think they do.. LOL..  hmm. only tkl
« Reply #30 on: Sun, 20 January 2013, 19:52:18 »
Sup dude,
I think SmallFry told me that he's only seen two? But they seem ultra rare. Maybe I have a project on my hands ^_^
« Reply #31 on: Sun, 20 January 2013, 19:54:33 »
Sup dude,
Market is too small, there wouldn't be significant amount of takers.
Offline Vintage
« Reply #32 on: Sun, 20 January 2013, 20:12:22 »
I agree. If you buy non-stock hubcaps for your car you call it custom. You don't have to break out solidworks and design your own.
Just my opinion though.
CM QFR w/ MX Reds  | Logitech G900
« Reply #33 on: Sun, 20 January 2013, 20:15:01 »
Sup dude,
I meant for me and my board. I know that 104 boards aren't too popular so I agree and don't think I'd bother running a GB or anything.
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #35 on: Mon, 21 January 2013, 11:06:10 »
Oh, just noticed the Topre uses it's own special switch, (EDIT:) not cherry switches.
Should I trust this seller of a Filco Magestouch-2 (brown) w/ Blue Aluminium case? (£132)
http://www.amazon.co.uk/Filco-Majestouch-2-Action-Metallic-Keyboard/dp/B004Z0OS54/ref=sr_1_9?s=computers&ie=UTF8&qid=1358787426&sr=1-9
(EDIT:) I feel stupid of not noticing the seller is infact Filco...I seem to miss a lot.
Else I think I might go for Vortex KBT ONE (brown). (~£80)
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=206
« Last Edit: Mon, 21 January 2013, 11:21:16 by Wopian »
Offline iri
« Reply #36 on: Mon, 21 January 2013, 11:12:25 »
i still wonder for what reason you suddenly chose topre.
vortex have bad reputation here for questionable quality control and lack of customer support.
-Ray Bradbury
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #37 on: Mon, 21 January 2013, 11:18:00 »
I see.
(I miss-read the price for $175, not $275. Along with the switch picture not loading on mobile.)
« Reply #38 on: Mon, 21 January 2013, 13:08:44 »
I see.
Buy, Both,
Get an inexpensive MX along with a topre... make sure to get "uniform" topre, because the variable key weighting is annoying to some people :))
Offline lazerpointer
  • ya gotta stay phresh
« Reply #39 on: Mon, 21 January 2013, 13:16:10 »
Get the KBT Oni - a great browns board with nice PBT caps.
I'm gonna wait for the WASD V2 board myself. Full size or TKL with minimal branding and LED back lighting. Also gonna get the version without caps if WASD continues to offer that, to save a bit of money / waste.
i type, therefore i geekhack
« Reply #40 on: Mon, 21 January 2013, 13:31:34 »
why would you get backlit "without caps"   the way that cherry mx switches has the LED setup, it looks silly with normal caps because the light diffusion looks so unsymmetrical
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #41 on: Mon, 21 January 2013, 13:49:46 »
Eye, me too. But it's too long away to wait for it, need a new keyboard before this one falls apart.
Offline Tym
« Reply #42 on: Mon, 21 January 2013, 14:14:21 »
£64.99
Sorry I never got back to you, mine is black, I know a while back they made some with blue (I bought mine for early xmas present) and they do sell reds differently, I believe a quick email to steelseries could resolve this for you!
Offline Tym
« Reply #43 on: Mon, 21 January 2013, 14:15:34 »
£64.99
Also I don't have a problem with the big f*ck off enter key, i enjoy the fact it offends people who try my keyboard :D I like being different! Thats why i have a pen1s which is only 3 inches...from the ground XD
Offline baldgye
« Reply #44 on: Mon, 21 January 2013, 14:21:28 »
I'd still recomend a fullsize filco, that you can get with pretty much which ever switch you like (cherry) and in either US/EU or UK layouts...
thekeyboardco are a uk site too so shipping is quick and not too bad...
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #45 on: Mon, 21 January 2013, 14:40:48 »
I dislike tenkeyless and numberpad-less keyboards. Also, I can't use that site because I can't actually read the text because of the background...
Offline baldgye
« Reply #46 on: Mon, 21 January 2013, 14:49:34 »
thats why I said get a fullsize one, like the one I have...
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #47 on: Mon, 21 January 2013, 14:53:11 »
Nvm, changing background through css edit each time I load the page lets me use it, might get it from them, much cheaper inc. shipping!
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #48 on: Mon, 21 January 2013, 14:53:56 »
I know.
« Reply #49 on: Mon, 21 January 2013, 15:22:42 »
Beware - I own this specific keyboard. IT IS NOT ALUMINUM.
As written in the description: the color is "Metallic Blue".
It's a standard plastic case. Looks really good though. I like it very much.
« Last Edit: Mon, 21 January 2013, 15:25:02 by BucklingSpring »
