Author Topic: Cherry MX for my wife  (Read 2943 times)
Offline DamienG
    • DamienG
« on: Sat, 26 January 2013, 15:33:40 »
So, given it's going to be a while before I have the parts to assemble my Phantom I thought I'd offer to get a keyboard for my wife as she needs one for her office.
First off we looked online at keyboard layouts (romantic, I know) - liked the idea of less-than full-size but wants a numeric keypad (she spends too much time in Excel). Best keyboard layout looks to be the CM Quick Fire TK. I haven't seen any others that drop the arrow key section and go with the numeric keypad - am I missing any?  Looks like the phantom couldn't do this as the numeric pad is 4 across, not 3.
Next step was Fry's to have her test some switches to see if she preferred blue, brown or red. My money was on the (currently hard to get on the TK) brown but she complicated the situation a bit by preferring black switches on the Mionix Zibal 60 and Azio Mech5 they had.
The final result will have white keycaps so the question is:
Do I go with the CM Quick Fire TK and a donor keyboard and swap over all the switches or is there something else with a similar format to the TK?
If I change the switches what's a good donor keyboard?
[)amien
« Last Edit: Sat, 26 January 2013, 15:58:33 by DamienG »
Re: Cherry MX for my wife
« Reply #1 on: Sat, 26 January 2013, 15:41:54 »
Here's what you should do....
Get an mx blue tkl, prob cm quickfire, for $55 from amazon, it says out of stock, but you can still order it at that price on the "right side of the page" where it says ships in 2-4 weeks.. amazon restocks really fast, so you'll likely get it before then.
 then get the 'adesso" numpad for $32 on Amazon. and Swap in Black switches on that..
Unless she's VERY sure that she wants black switches for her main,, don't get it......
Offline DamienG
    • DamienG
« Reply #2 on: Sat, 26 January 2013, 15:47:47 »
She definitely doesn't want Cherry blues for her main keyboard. She's tried my DAS keyboard and hates them plus her small open office would be drowned in the noise.
As for adding a numeric pad onto a tenkeyless - it would be just as large as a regular keyboard then.
[)amien
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 26 January 2013, 15:48:07 »
A couple alternatives to Tk that are similar are Plum 96 and Cherry G80-1865/1800. Both of these are also PCB mount so are much eaier to switch mod if you choose.
Offline keymaster
  • Topre Revolution Theorist
« Reply #4 on: Sat, 26 January 2013, 15:51:06 »
www.elitekeyboards.com/products.php?sub=leopold,tenkeyless&pid=fc200rlab
I think this will suit her quite well. It has a more professional appearance compared to the gamer-esque Quickfire.
Offline DamienG
    • DamienG
« Reply #5 on: Sat, 26 January 2013, 16:02:41 »
Unfortunately is missing a numeric keypad and if I add a separate one it's no smaller than a regular keyboard.
Offline keymaster
« Reply #6 on: Sat, 26 January 2013, 16:04:31 »
Oh, I see...Then, I don't think she'll have too much of a choice other than the TK you've mentioned. If she's not okay with that, then she may as well get a full-sized keyboard.
Offline FoxWolf1
  • 154
« Reply #7 on: Sat, 26 January 2013, 16:16:29 »
Okay, so reduced-size but WITH numberpad? Let's see...
-Quickfire TK, as mentioned.
-Plum 96: similar to QFTK. Comes with MX Black by default, which may be good for you, but is also PCB-mount, so easy to change.
-Tt MEKA (with no G or anything): same width as the above, but has arrow keys tucked underneath Enter, so you can use them and the number pad at the same time. Once again MX Black.
-Cherry G80-1865: Has all the keys of a full-size (I think), but kinda squished together to make it narrower.
This is off the top of my head...there might be more out there that can be found with some digging.
Offline DamienG
    • DamienG
« Reply #8 on: Sat, 26 January 2013, 16:29:57 »
That looks like it might be an ever better option as it already has white keycaps too. PCB-mount will probably be okay. Now I just need to find out where to get these from!
[)amien
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Cherry MX for my wife
« Reply #9 on: Sat, 26 January 2013, 20:03:30 »
[)amien
talk to qtan he should be able to get you one.
Offline 1839cc
« Reply #10 on: Sat, 26 January 2013, 20:20:32 »
How about a G80-11900? It's 19" wide, so narrower than fullsize, but longer.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline linuxid10t
« Reply #11 on: Sun, 27 January 2013, 02:00:28 »
Honestly I am pretty sceptical to someone wanting to get Blacks unless they REALLY like them.  They aren't an easy switch to get used to and can get tiring very fast.  That being said I am typing on some right now, but I feel slower on this than I do on my blues by a fair amount.  I normally type an average of 75 wpm on typeracer on blues, but only 68 wpm on blacks.  Of course there are plenty of advantages.  Although the main one I can think of is how much quieter they are than any other cherry switch.  Especially if you put O-rings on them.
Offline GMC
  • Shiny.
« Reply #12 on: Sun, 27 January 2013, 04:23:56 »
11900 is a good call. If she is used to trackpads and uses excel a lot, the close proximity of trackpad and numblock could be ideal.
Otherwise go for an 1800 or plum96 though she may get annoyed having arrows and numbers layered with the latter.  The meka has a big ass enter iirc which will be hard to source an alternative for if you want to change out caps.
Wildcard option would be poker/race and a separate numpad but then she has to get used to a fn layer and getting blacks/modding if needed will be harder.
WASD V1 - waiting on R4... - MX Brown
KBT Pure - Zinc caps - MX Brown
Cherry G80-1800 ISO WKL - SkiData caps - MX Clear
« Reply #13 on: Sun, 27 January 2013, 04:36:11 »
You gotta practice ;D
« Reply #14 on: Sun, 27 January 2013, 05:23:17 »
Curiously I feel faster on my MX blacks than blues - maybe the novelty, maybe the keycaps, dunno.
But I can see that they would be an acquired taste, particularly for people who do not have inherently strong fingers.
Offline linuxid10t
« Reply #15 on: Sun, 27 January 2013, 18:57:23 »
To me it feels like when I go to Blues from Blacks, I type waaaaaaaaaaaaaaaaay too hard and it feels really awkward.
Offline DamienG
    • DamienG
« Reply #16 on: Sun, 27 January 2013, 19:15:03 »
She played viola for a long time.
[)amien
Offline 1839cc
« Reply #17 on: Sun, 27 January 2013, 20:10:09 »
Unless Blacks are in a Korean keyboard they will have the resale value of a rock.  [ask me how i know] :(
Some rocks are very expensive!
If you go with PCB mount you will have easy swapping options.
Offline DamienG
    • DamienG
« Reply #18 on: Sun, 27 January 2013, 20:24:38 »
Yeah going to go for the Plum 96 - she likes the wireless option so that's Korean and PCB mount I believe.
Just waiting to see if qtan can score me one.
[)amien
Offline DamienG
    • DamienG
« Reply #19 on: Thu, 31 January 2013, 16:45:04 »
No answer from qtan so tried AliExpress and BuyChina as both had listings for them.
Alas both suppliers on both sites were actually out of stock of the white with black stems. One gave me a lot of hassle to cancel and kept trying to persuade me to go with a different combination (he shouldn't have listed it in-stock).
Still searching!
[)amien
Offline JPG
  • Model F is my new passion!
« Reply #20 on: Thu, 31 January 2013, 16:57:24 »
[)amien
I do not agree that the numpad would make it as large as a normal keyboard. The beautifull thing about the numpad independant from the keyboard is that you can put it where u want, not next to your keyboard, and on the side you prefer. So it's not the same as having them in one keyboard.
Also, well you could look at the GH60 and GH60pad (or whatever the official name). Not cheap, but then you can choose what u want! (and not available yet, but soon if I can rely on the comments of the thread).
