Author Topic: Regarding HHKB slipping  (Read 3159 times)
Offline ValerieV
« on: Sun, 27 January 2013, 18:52:56 »
Can anyone recommend a specific brand that i can put on my HHKB so it won't slip off my Mac computer. I place it on top and it slides all over the place. I can only put it on the bottom part of the keyboard because if i put it anywhere else it will hit the keys on the computer keyboard and cause a problem. Thanks.
Re: Regarding HHKB slipping
« Reply #1 on: Sun, 27 January 2013, 19:23:21 »
Um.... hmmm...  you could buy a sheet of adhesive sided rubber. I mean, this is pretty straight forward..
Offline sth
  • 2 girls 1 cuprubber
« Reply #2 on: Sun, 27 January 2013, 19:25:00 »
yeah... just find some soft rubber dots or cut strips/a mat out of adhesive rubber. or just spread some rubber cement on the bottom from time to time :P
Offline ValerieV
« Reply #3 on: Sun, 27 January 2013, 20:15:17 »
I've tried those. I was wondering if anyone had a specific type because the ones that i bought are hitting the keys on the computer keyboard. It's frustrating because it is a great keyboard but they should have put better rubber padding underneath. Thanks.
« Reply #4 on: Sun, 27 January 2013, 20:41:24 »
well, yea, you're putting the hhkb ontop' of where your regular keyboard is..
Easiest way is to use the rubber stuff that you have now, and disable the "onboard" keyboard.
Offline ValerieV
« Reply #5 on: Sun, 27 January 2013, 21:54:15 »
I was trying to figure out how to do that. If you have a MAC can you tell me? Thanks.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #6 on: Mon, 28 January 2013, 01:09:57 »
Get some Egrips!
« Reply #7 on: Mon, 28 January 2013, 01:58:54 »
http://forums.macrumors.com/showthread.php?t=433407
I can't test this, as my mom has windows on her work macbook..
Had a hackintosh years ago, it wasn't much better than windows after I got bored of the cool bottom bar.
