Author Topic: How to make "clear plastic" opaque?  (Read 15318 times)
« on: Fri, 01 February 2013, 15:01:15 »
any experts on this?
dip in acetone?  :-X
Offline alaricljs
  • I be WOT'ing all day...
Re: How to make "clear plastic" opaque?
« Reply #1 on: Fri, 01 February 2013, 15:05:08 »
Cyanoacrylate fogs many plastics.
Filco w/ Imsto thick PBT
Offline sth
  • 2 girls 1 cuprubber
« Reply #2 on: Fri, 01 February 2013, 15:13:10 »
fine steel wool on the 'inside' would work too.
Offline inteli722
« Reply #3 on: Fri, 01 February 2013, 15:41:36 »
Or, if you want to have a odd-looking keyboard and/or you're on the kind of budget where you should've never bought a mechanical keyboard in the first place, cut-and-tape paper/fiberboard/whatever.
It would work. May not be pretty, but it works.
Waiting for: Phantom Plate
Offline alaricljs
« Reply #5 on: Fri, 01 February 2013, 15:49:05 »
craaaaaaazy glue, often the fumes are enough.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #6 on: Fri, 01 February 2013, 15:55:08 »
dip in acetone?  :-X
LoL, this must be some part of another conversation that I was not privy to. So my answer might be overly simplistic
as the complicated one is well... complicated.
Paint it.
With you know, opaque paint.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline inteli722
« Reply #7 on: Fri, 01 February 2013, 16:04:03 »
Well, I suppose that DOES work, and probably better than my suggestion :))
Offline TotalChaos
  • Indy Game Coder
« Reply #8 on: Fri, 01 February 2013, 17:57:25 »
Replace the clear plastic with a piece of opaque plastic.  Voila!  ;)
Offline x2o
    • x2o.me
« Reply #9 on: Fri, 01 February 2013, 18:59:37 »
Would dying the plastic do the trick maybe?
I've never toyed with clear plastic too much, but RIT Dye does wonders on most plastics I've used it on.
note : it can get messy!
« Last Edit: Fri, 01 February 2013, 19:01:19 by x2o »
Offline BucklingSpring
« Reply #10 on: Sat, 02 February 2013, 10:42:40 »
Do you really mean opaque?
vs translucent...
Some of the solutions above will fog... But light will still go through. ie not opaque.
Boards I own, click ->
« Reply #11 on: Sat, 02 February 2013, 11:14:55 »
Use paint - on the inside.
It gives you whatever you want, with a nice, bright, well-protected exterior.
Any paint on the outside will wear and chip, no matter what.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline davkol
  •  Post Editing Timeout
« Reply #12 on: Sat, 02 February 2013, 14:28:18 »
What about sanding?
edit: I meant nail polish + sanding
« Last Edit: Sat, 02 February 2013, 14:39:17 by davkol »
Offline hoggy
  • * Ergonomics Moderator
« Reply #13 on: Sat, 02 February 2013, 14:57:38 »
Or just nail varnish, but that's a different story...
Are we talking about key caps, or something else?
« Reply #14 on: Sat, 02 February 2013, 15:05:01 »
I have these acrylic plates that I'd like to become Opaque for lighting purposes..
Also Some of these LEDS I have are "clear lenses" I'd like them to be opaque too, and no i checked, they don't make opaque diffused versions of these.
