Author Topic: Filco Majestouch2 Keycaps  (Read 4676 times)
Offline Wopian
  • Why Hello There.
    • Bobstudios
« on: Sun, 03 February 2013, 05:11:00 »
There was no response from the key caps section so it's here...
So, as I'm getting a black filco majestouch2 with red esc keycap (and switches) and blue wasd keycaps, I am wondering where the best place to get modified keycaps (see pic). I know WASD do the keycaps and are 100% compatible with this keyboard. However, I have these issues:
1. Can't have the front-sided text (sys rq and break) with WASD keycaps.
2. Is there anywhere else that will do front-sided text for Filco keycaps?
3. What font and size does Filco use?
Dark grey represents default black keycaps.
Red esc key and blue wasd is being bundled with keyboard - So only the grey and white keycaps needed + grey wasd)
(I used a white filco majestouch2 and recoloured it, so ignore the scruffy bits (also why black keycaps have black text ;)))
Offline BucklingSpring
Re: Filco Majestouch2 Keycaps
« Reply #1 on: Sun, 03 February 2013, 07:55:17 »
Are you are looking for a place to buy ABS or PCB keycaps?
Boards I own, click ->
Offline Wopian
  • Why Hello There.
    • Bobstudios
« Reply #3 on: Sun, 03 February 2013, 09:52:46 »
ABS, as that's what the stock Filco keycaps uses.
