Author Topic: Squeaky backspace (cherry stabilizer)  (Read 10518 times)
Offline keymaster
  • Topre Revolution Theorist
« on: Thu, 07 February 2013, 17:50:23 »
The keyboard is a Leopold FC200R.
I recently replaced the standard caps with PBT caps. The backspace is squeaky for some reason, but when I switch it out for the standard ABS key it doesn't squeak.
Note: the PBT caps are cherry profile, the ABS is OEM
What gives? I ordered some lube from EK just in case (and for the future).
« Last Edit: Thu, 07 February 2013, 17:56:29 by keymaster »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: Squeaky backspace (cherry stabilizer)
« Reply #1 on: Thu, 07 February 2013, 19:04:57 »
It's the angle where you're pressing it. When I put non-SP profile caps on a Cherry stabilized Wyse PCET, it squeaks. Because you've changed the profile, you're changing the angle of interaction enough for it to squeak. Unfortunately that's all I know there - I have no idea why that's enough to do it, just that it seems to be.
A bit of lube should probably clear it up. Also, HOORAY FOR CHERRY STABILIZERS! Death to wire stabilized junk!
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline keymaster
« Reply #2 on: Thu, 07 February 2013, 19:10:19 »
I'll definitely try the lube, but I don't think it's the angle. It makes a squeak no matter which angle I press the backspace -- none of the other keys have a problem. I'm wondering if the stems on the cherry profile keycap are shorter and thus making the noise? Idk..
Offline sth
  • 2 girls 1 cuprubber
« Reply #3 on: Thu, 07 February 2013, 19:13:20 »
is there another sort of cherry stabilizer that i don't know about? or do you mean something different by wire?
Offline laffindude
« Reply #4 on: Thu, 07 February 2013, 19:16:51 »
Wire stabilizer = Costar stabilizer.
Offline keymaster
« Reply #5 on: Tue, 12 February 2013, 10:46:06 »
Alright so the lube came in from EK today. I tried lubing the stems AND where the red arrows point to:
However, this doesn't seem to get rid of the squeakiness at all. The backspace squeaks with a small amount of pressure while moving less than 2mm. Would anyone know what seems to be the cause of this? To reiterate from my previous posts: this only happens with the new backspace key (cherry profile) and doesn't happen with the standard (OEM profile) backspace.
Offline toast
« Reply #6 on: Tue, 12 February 2013, 14:57:45 »
When I got my Leopold I had the same issue.  Applied some lube in the same way mentioned, still squeaked.
After using it for a couple weeks though my squeaking had disappeared.
Maybe it just needs to break in a bit.
Offline missalaire
  • Great Finder of Great Finds
« Reply #7 on: Tue, 12 February 2013, 15:06:57 »
My Ducky had a squeaky space bar, but after lubing what I could of it, it went away after a little while.
Offline keymaster
« Reply #8 on: Tue, 12 February 2013, 15:17:29 »
Thanks for the reply, toast. I guess I'll just wait it out for now.
Offline rootwyrm
    • My Website!
« Reply #9 on: Tue, 12 February 2013, 16:11:33 »
Which lubricant did you use?
For stabilizers, I recommend heavy duty white lithium grease. This is otherwise known as the stuff used on car doors. Anything with a high viscosity is going to just soak in or not really lubricate worth a damn. White lithium grease on the other hand, is sticky nasty ugly stuff that will stay around forever and is impossible to clean up.
As I mentioned, the squeaking is from contact due to the changed angle. It's likely plastic on plastic. So you will need to break it in a bit regardless. I would recommend removing the keycap, applying a bit of white lithium grease to the top of the post, working it a few times, adding a bit more, and repeating.
Offline keymaster
« Reply #10 on: Wed, 13 February 2013, 01:48:17 »
It's the silicone grease from Elite Keyboards.
« Reply #11 on: Wed, 13 February 2013, 04:41:32 »
it works, but an EPIC rip-off....  white lithium is where it's at..
ALSO.. you could've alternatively gotten Honda Shin E silicone grease, top tier sht... but $20 a tube, enough for over 9000 keyboards probably... :))
Offline keymaster
« Reply #12 on: Fri, 15 February 2013, 17:22:38 »
After a day of allowing the lube to settle in -- NO MORE SQUEAK! Great success.
