Author Topic: Gigabyte Osmium Aivia - Win Lock to Menu key  (Read 3596 times)
Offline maudio33
« on: Mon, 11 February 2013, 10:44:45 »
Hi all,
I am new in mech keyboards.
Today I bought Osmium Aivia with cherry red mx and it is just perfect, much more better than my Microsoft Natural 4000 and my Thinkpad keyboard.
But I have one problem, I tried to google, but without success.
I bought this keyboard not for gaming, but for programming and office and sometimes I use menu key on my other keyboards.
It is possible somehow change function of Osmium "Win Lock" key to standard menu command?
Thanks,
Tomas
Re: Gigabyte Osmium Aivia - Win Lock to Menu key
« Reply #1 on: Mon, 11 February 2013, 10:47:15 »
NO
well... to be sure, if it's "not" in their "macro" software...
That.. means it's hardware based.. which means "no changing"
HOWEVER, you can sacrifice one of your unused keys and just wire that up, then using the scan-code changer, alter it to map for context menu key..
Offline maudio33
« Reply #2 on: Mon, 11 February 2013, 10:49:18 »
Did you try it?
I am thinking about some WIN8 registry hack or something...
« Reply #3 on: Mon, 11 February 2013, 10:51:42 »
Did you try it?
The key lock "doesn't" send anything to the computer.. it's likely hardware.
Offline maudio33
« Reply #4 on: Mon, 11 February 2013, 10:56:37 »
Too bad, besides this, keyboard is perfect...so maybe I will map Menu key to some other unused button like you said. Thanks for your insight
(And what about Fn key? It will be the same hardware stuff right?)
