Author Topic: KBT ONI vs Filco Majestouch-2 TLK  (Read 3116 times)
Offline red_magic
« on: Mon, 11 February 2013, 17:35:54 »
I have still not decided weather I want to buy a KBT ONI or a Filco Majestouch-2. Does anyone have any input on this? I am leaning towards the ONI because of the PBT stock keycaps and the general look of the board, but I have heard horror stories about Vortex/KBT boards so I am not sure.
Thanks
Re: KBT ONI vs Filco Majestouch-2 TLK
« Reply #1 on: Mon, 11 February 2013, 18:03:43 »
Stay away from Vortex at all cost, "IF YOU CAN"
Get Filco only if you tend to be "modding" in the future via "soldering"... Otherwise the improved PCB doesn't do anything for you..
If you have no intention of ever modding the keyboard, then go with the Quick Fire Rapid... It's $65 for the MX Blue, and you can get a set of choice Color PBT with the left over funds from anywhere.
Offline gnubag
« Reply #2 on: Mon, 11 February 2013, 18:20:45 »
I have the ONI with brown switches, and all i can say is that it comes damn close to a filco.
there is no knro with ps2, but instead you get pbt keycaps.
also http://geekhack.org/index.php?topic=40153.0
but buy what ever you like :)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Mon, 11 February 2013, 19:23:36 »
Here is a fairly detailed review/comparison. Surely some thing get lost in translation but it seems to be pretty favorable and you can see how close in build it appears to be to each other. Oni/One are VERY different keyboards from the Race/Poker/Pure and have almost nothing in common.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #4 on: Mon, 11 February 2013, 19:36:25 »
Is the Oni plate mounted?
Offline gnubag
« Reply #5 on: Mon, 11 February 2013, 19:50:07 »
yes it is.
Offline leisilin
« Reply #6 on: Wed, 13 February 2013, 14:15:24 »
I have some white Filco 87s, which look good.
Also, Filco would give you a good reason to buy many key caps. :D :D :D
If you can accept the price, Filco is a good choice.
Offline gnubag
« Reply #7 on: Wed, 13 February 2013, 14:22:08 »
The oni aleady has good keycaps :)
no need to spend more money :)
(jk just do whatever you think is right)
