Author Topic: In the market for a Mechanical keyboard.  (Read 1530 times)
Offline Rare
  • Spending racks and bands on keyboards.
« on: Mon, 11 February 2013, 21:55:08 »
Hi guys, I'm gonna be building a new PC and I have some extra money that I didn't know about. I'm looking to get a mechanical keyboard. I have a few in mind.. But I wanna know what you guys think as you guys definitely know your stuff. My budget is $103 haha. I'd really like for it to have some USB ports on it. It would be really helpful. I'm gonna use it for both gaming and typing/general use. Thanks guys.
Saber 68 (MOD-H)
my glo
Offline gnubag
Re: In the market for a Mechanical keyboard.
« Reply #1 on: Mon, 11 February 2013, 21:56:51 »
do you know what switches you want?
if no, get a sampler kit or try keyboards out first (samplerkits : http://www.wasdkeyboards.com/index.php/products/sampler-kit-1.html )
if you know what switches you want, the best bang for the buck are Coolermaster Quickfire Rapids.
« Reply #2 on: Mon, 11 February 2013, 22:02:37 »
If you plan to do soldering mods in the future with customized switches like ERgo clears, panda, etc.... then stretch the budget for a FILCO.. the PCB takes to soldering much better than the Quickfire Rapid.
If you don't plan to customize the switches, then go with the QUICKFIRE rapid....
Offline Strelok
« Reply #3 on: Mon, 11 February 2013, 22:06:20 »
If you type a decent amount, get Blue's or Browns.
If all you ever do is game, go for Blacks.
If you don't want or need a numpad, there are TenKeyLess (TKL), 75% (no arrows or special key cluster) and 60% (no Function keys).
I like 60%'s myself.
Offline Rare
« Reply #4 on: Mon, 11 February 2013, 22:12:28 »
Yeah, I want either a blue or a brown, doesn't matter at this point.
Saber 68 (MOD-H)
my glo
« Reply #5 on: Mon, 11 February 2013, 23:19:10 »
Blues are noisier than browns, but the tactile feedback is better.
Some people find that the release point being above the activation point is awkward for gaming, especially if you need to double tap.
