Author Topic: [SOLD] QFR with Ergo-clears - $100  (Read 4920 times)
Offline khaangaaroo
  • Trade Count: (0)
« on: Mon, 11 February 2013, 22:37:48 »
I have a QFR with reds that has been half-modded with ergo-clears. I bought the board from another member here to try out ergo-clears, but decided they weren't for me. I let my brother use it for a few weeks, but he eventually decided he liked mx browns more. So I'm looking to pass it on to the next person who's wants to try them out.
$100 plus actual shipping from California. CONUS for now. (Sorry international buddies)
SOLD for $100 within CA.
« Last Edit: Thu, 14 February 2013, 13:13:40 by khaangaaroo »
Offline epicsilas
  • Trade Count: (0)
Re: QFR with Ergo-clears - $100
« Reply #1 on: Mon, 11 February 2013, 22:57:21 »
Wow, awesome deal. I wish I could snatch this up right now. :(
GLWS!
  • Trade Count: (0)
« Reply #2 on: Tue, 12 February 2013, 01:07:25 »
Could you post a picture of the BACK of the PCB, Just want to check if the solder job is good. ;D
Offline WhiteFireDragon
  • Trade Count: (0)
    • youtube
« Reply #3 on: Tue, 12 February 2013, 01:28:08 »
Do as the man wishes. Post a pic of the back, but make sure it's blurry :P
Offline khaangaaroo
  • Trade Count: (0)
« Reply #4 on: Tue, 12 February 2013, 02:07:34 »
PCB shots:
http://i.imgur.com/rlDcvIV.jpg
http://i.imgur.com/Q50eh7q.jpg
http://i.imgur.com/HkF1gaF.jpg
The solder pad on the space bar is lifted a bit. (It wasn't me!)
But the rest seems like a better soldering job than I could have done myself.
Offline terrpn
  • Alpha Geezer
  • Trade Count: (0)
  • - Buy Vintage -
« Reply #5 on: Tue, 12 February 2013, 10:28:54 »
do these hang or stick at all?
deskthority says they might occassionally hang...........?
http://deskthority.net/wiki/Cherry_MX_Ergo_Clear
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
  • Trade Count: (0)
    • youtube
« Reply #6 on: Tue, 12 February 2013, 10:32:58 »
If you're typing normally, they won't ever. But if you're depressing it very slowly to test them out, it might feel like they stick when it gets to the tactile bump on the way up, but it'll still make it past the bump. Lube greatly reduces this and makes it feel so much better, both pressing down and when it springs back up.
Offline khaangaaroo
  • Trade Count: (0)
« Reply #7 on: Tue, 12 February 2013, 10:39:38 »
nope. Haven't noticed any sticky feeling on these.
Offline terrpn
  • Alpha Geezer
  • Trade Count: (0)
  • - Buy Vintage -
« Reply #8 on: Tue, 12 February 2013, 10:46:16 »
gotcha :cool:
ok so dump question......... since i have no experience with these. if lubed would they not revert basically to something linear (like the other reds) and lose the slight bump?
Offline khaangaaroo
  • Trade Count: (0)
« Reply #9 on: Tue, 12 February 2013, 10:57:07 »
The bump will still be there. With lube, there's less friction, so the key will feel less gritty. But the force required to get over the bump will remain pretty much the same, minus the little bit of friction.
Offline terrpn
  • Alpha Geezer
  • Trade Count: (0)
  • - Buy Vintage -
« Reply #10 on: Tue, 12 February 2013, 14:17:43 »
ok...........another dumb question. i have read many of the posts in the past about these switches. in laymans terms they are like browns with a more pronounced bump, yet with a slight hesitation on the way back up?
just trying to figure out the feel. pretty much everybody likes browns yet we have many that do not like the ergo-clears, so i am presuming the maybe mushy, stickiness on the way up that i read?
Offline terrpn
  • Alpha Geezer
  • Trade Count: (0)
  • - Buy Vintage -
« Reply #11 on: Tue, 12 February 2013, 14:24:09 »
this helps............
Offline khaangaaroo
  • Trade Count: (0)
« Reply #12 on: Tue, 12 February 2013, 14:29:06 »
There's no stickiness on the way up that I can feel. All the keys spring up just like any other cherry board I have.
If you like browns, but wish that they were a little more tactile, then you'll probably like ergo-clears. I think a lot more people like browns because a lot more people have tried browns. My guess it that  people who have ergo-clears either have spent more money getting one, or more time making one, so expectations are higher.
But it really comes down to personal preference. I was never able to get a feel for what I liked until I actually tried the different types. Reading about it and watching videos will only get you so far.
Offline akuJIWA
  • Trade Count: (0)
  • Lock 'N Load!
« Reply #13 on: Tue, 12 February 2013, 14:46:11 »
If it had a plate, I would be all over it.
The Cheat - B/R/B ; Clear switch with 62g springs
quit
  • Trade Count: (0)
    • youtube
« Reply #14 on: Tue, 12 February 2013, 14:49:37 »
lol the plate is like the most obvious part. It's bright red!
Offline gnubag
  • Trade Count: (0)
« Reply #15 on: Tue, 12 February 2013, 14:53:14 »
this! and also because he had to do soldering...
Offline cobraj
  • Trade Count: (0)
« Reply #16 on: Tue, 12 February 2013, 14:53:33 »
I see khaangaaroo, and keep thinking you live in Australia.
Harsh life :(
GLWS though :)
Offline akuJIWA
  • Trade Count: (0)
  • Lock 'N Load!
« Reply #17 on: Wed, 13 February 2013, 02:01:07 »
Aw, come on, you know what I mean! :p
quit
Offline Reomero
  • Trade Count: (0)
  • Manual breather
« Reply #18 on: Wed, 13 February 2013, 03:34:08 »
I'd be potentially interested in this if my wallet lets me and if you shipped internationally...
But anyway, GLWS! :)
