Author Topic: Bluetooth numpad into game controller.  (Read 3386 times)
Offline bear95
« on: Wed, 13 February 2013, 15:17:32 »
So I'm thinking of making a wireless game controller with mx switches with a bluetooth numpad. Specifically, I'm going to make it into a nes controller. I'm making it as a gift for someone and I'm thinking of giving it to the person along with a nes emulator to play on the person's mac.
But since it has to be small, I'm going to chop it and I've seen people do it with fullsize keyboards but can you do it on a numpad and make it even smaller?
« Last Edit: Wed, 13 February 2013, 17:27:23 by bear95 »
Offline SmallFry
Re: Bluetooth numpad into game controller.
« Reply #1 on: Wed, 13 February 2013, 15:34:25 »
I'm not sure I follow, paint diagram may be of assistance.
Offline bear95
« Reply #2 on: Wed, 13 February 2013, 15:47:26 »
This is basically my plan. didn't draw in the controller parts or the batteries but i recognize they should be there.
« Last Edit: Wed, 13 February 2013, 16:02:02 by bear95 »
« Reply #3 on: Wed, 13 February 2013, 16:33:23 »
//Facepalm..
this will be a really ****ty controller that doesn't fit your hand... and you know it... ;D
Offline bear95
« Reply #4 on: Wed, 13 February 2013, 16:51:00 »
Yeah i really do. But I feel the effort will mean more to the person I'm giving it to than its actual function :P rather than buying a gift card or something :P
Plus it will be fun to do :D
« Reply #5 on: Wed, 13 February 2013, 17:23:30 »
:D  if this successfully gets you laid... WIN....
Offline bear95
« Reply #6 on: Thu, 14 February 2013, 16:40:01 »
so IS it possible to cut a numpad?
Offline SmallFry
« Reply #7 on: Thu, 14 February 2013, 17:20:53 »
You will need a new controller such as using a teensy with Hasu's firmware etc.
Offline bear95
« Reply #8 on: Thu, 14 February 2013, 17:32:32 »
^Woah... that is actually sweet. I might just ditch the numpad and work with that.
Offline SmallFry
« Reply #9 on: Thu, 14 February 2013, 17:34:06 »
A teensy is not the keypad itself.
Offline bear95
« Reply #10 on: Thu, 14 February 2013, 17:43:14 »
Can't i hook up switches to it and attach it to my own made plate?
« Reply #11 on: Thu, 14 February 2013, 17:48:51 »
Yes. but there's going to be duct-tape involved..
Offline SmallFry
« Reply #12 on: Thu, 14 February 2013, 17:51:46 »
Yes. You can.
