Author Topic: MX Greens  (Read 6031 times)
Offline Edjewh
MX Greens
« on: Sat, 16 February 2013, 09:25:17 »
can you put on mx black springs onto MX greens switches I find the greens to lite
Offline khaangaaroo
Re: MX Greens
« Reply #1 on: Sat, 16 February 2013, 09:40:13 »
I think they use the same spring. you'd need to find springs heavier than black
Offline AKIMbO
  • HHKBro
Re: MX Greens
« Reply #2 on: Sat, 16 February 2013, 09:43:00 »
First time I've ever heard that.  You must have some Arnold Schwarzenegger fingers.  I think you may be out of luck if you want heavier than mx green springs.  The only other spring I know of is a super black, but good luck finding enough for an entire board.  Super blacks are rare birds.
| KBD75 (box reds)
Offline khaangaaroo
Re: MX Greens
« Reply #3 on: Sat, 16 February 2013, 10:38:41 »
I read somewhere that ballpoint pen springs are heavier. Not sure if they'd fit though.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: MX Greens
« Reply #4 on: Sat, 16 February 2013, 12:00:34 »
If greens are too lite, try cherry mx clear springs
-Enzo Ferrari
Offline tauburn
Re: MX Greens
« Reply #5 on: Sat, 16 February 2013, 12:17:17 »
i thought the green springs were heavier than the blacks
Offline inteli722
Re: MX Greens
« Reply #6 on: Sat, 16 February 2013, 13:18:23 »
Greens are heavier SWITCHES than blacks. Same spring. Higher actuation weight comes from the tactile bump (similar to how Reds/Browns have the same spring as Blues, but blues are slightly heavier switches.)
Waiting for: Phantom Plate
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: MX Greens
« Reply #7 on: Sat, 16 February 2013, 13:45:40 »
NO. Green and white have the same springs as greys, which are indeed heavier than both black and clear.
Offline Loligagger
Re: MX Greens
« Reply #8 on: Sat, 16 February 2013, 13:55:50 »
Is that so? I tried swapping between clear and white springs with a clear stem and felt little to no difference in the force required (the clear spring is shorter & has less windings, however).
Offline inteli722
Re: MX Greens
« Reply #9 on: Sat, 16 February 2013, 14:02:19 »
Really? Because Blacks and Greens look like they have the same springs.
Side-by-side Comparison: http://imgur.com/a/RJqM4#23
Re: MX Greens
« Reply #10 on: Sat, 16 February 2013, 14:09:11 »
Sure they might look same, but there is a 20cN difference and the click mechanism can't add that much.
Offline inteli722
Re: MX Greens
« Reply #11 on: Sat, 16 February 2013, 14:11:20 »
The grays look like they're made of stiffer material. There's also Ghetto Greens (Blues with Black springs.) Anyone have a comparison of the 2 handy?
Offline gnubag
Re: MX Greens
« Reply #12 on: Sat, 16 February 2013, 14:12:55 »
Here: http://imgur.com/a/084iV
and the comments with the name of the pen on reddit here: http://www.reddit.com/r/MechanicalKeyboards/comments/1869u1/modificationthe_hardest_mechanical_keyswitch_mod/
Offline tauburn
Re: MX Greens
« Reply #13 on: Sat, 16 February 2013, 14:16:16 »
i really want to feel what it's like to type of a full keyboard of these
Offline cobraj
Re: MX Greens
« Reply #14 on: Sat, 16 February 2013, 14:38:28 »
Inb4 Carpal Tunnel :P
Offline Edjewh
Re: MX Greens
« Reply #15 on: Sat, 16 February 2013, 17:08:28 »
I must be mental because my black ducky feels a lot heavier then the QFR green I have
and I guess that answers my question it will feel the same
Offline Strelok
Re: MX Greens
« Reply #16 on: Sat, 16 February 2013, 17:19:28 »
Whites, Greys, Super Blacks and Super Greys are heavier.
Offline tauburn
Re: MX Greens
« Reply #17 on: Sat, 16 February 2013, 17:20:27 »
it's probably hard to feel a true difference when one is tactile and one isnt
Offline Edjewh
Re: MX Greens
« Reply #18 on: Sat, 16 February 2013, 18:13:01 »
accidental presses during gaming maybe I have heavy hands
« Last Edit: Sat, 16 February 2013, 20:05:13 by Edjewh »
Re: MX Greens
« Reply #19 on: Sat, 16 February 2013, 18:29:13 »
Or just go BS. Seriously though, don't your fingers get tired after a few hours on heavy switches?
Offline tauburn
Re: MX Greens
« Reply #20 on: Sat, 16 February 2013, 18:39:02 »
mine do not get tired at all. i use my greens from the minute i get up until i go to sleep.
Offline ishumprod
Re: MX Greens
« Reply #21 on: Sat, 16 February 2013, 18:47:59 »
what ?? you don't type while you sleep ? or maybe worse, you type on other switches ???
home-made TKL rubber dome keyboard !
Offline tauburn
Re: MX Greens
« Reply #22 on: Sat, 16 February 2013, 19:51:03 »
i guess if i could put switches in my phone i would type while i sleep
Offline Edjewh
Re: MX Greens
« Reply #23 on: Sat, 16 February 2013, 20:06:16 »
had a keyboard with browns that drove me nuts
so so touchy
Re: MX Greens
« Reply #24 on: Sat, 16 February 2013, 21:06:03 »
It wouldn't exactly be all that cheap to get 87 pen springs together.
Offline tauburn
Re: MX Greens
« Reply #25 on: Sat, 16 February 2013, 23:43:52 »
Re: MX Greens
« Reply #26 on: Sun, 17 February 2013, 01:13:13 »
uh yeah it would be
http://www.staples.com/Staples-Retractable-Ballpoint-Pen-Medium-Point-Assorted-50-Pack/product_656534
2 packs comes out to about $26 after tax...
How is that Cheap.....
The whole keyboard qfr mx blue on sale goes for $55 shipped.
Offline tauburn
Re: MX Greens
« Reply #27 on: Sun, 17 February 2013, 10:47:57 »
uh yeah it would be
you're on a forum where people spend $400+ on a single keyboard. i don't know what you think cheap means.
Offline khaangaaroo
Re: MX Greens
« Reply #28 on: Sun, 17 February 2013, 10:51:29 »
QFR blues + pens is still cheaper than buying QFR greens. Someone do it! For science
Offline kboardvintage
Re: MX Greens
« Reply #29 on: Sun, 17 February 2013, 16:29:30 »
want to try that green switch. Already own a QFR with blues and a G80-3000 with clears; can't be bad a mix of both :)
Offline Edjewh
Re: MX Greens
« Reply #30 on: Sun, 17 February 2013, 17:06:25 »
I would sell you this one
Offline eth0s
  • Peace & Love
Re: MX Greens
« Reply #31 on: Sun, 17 February 2013, 18:45:36 »
Hmm, I think this might be a troll post.  I don't think this is actually a serious post, because it's simply too ridiculous.
OP, you are trying to pull a goof here, aren't you?
Offline gnubag
Re: MX Greens
« Reply #32 on: Sun, 17 February 2013, 19:28:06 »
what?
why would it be a troll post?
most wikis say that the blacks have a actuation force of 60g and the greens 80g.
so people might think that they have different springs.
Offline Edjewh
Re: MX Greens
« Reply #33 on: Sun, 17 February 2013, 19:56:40 »
wasn't trolling I accidently press buttons on the greens and I don't on my blacks so I figured the green had lighter springs
was considering trying the black springs on the greens but since they are the same not much point in it
Re: MX Greens
« Reply #34 on: Sun, 17 February 2013, 20:11:20 »
what?
I thought they "WERE" in fact the same springs, but because the special "nub-slider" on the green shaft causes that extra friction bringing it up to 80
Offline inteli722
Re: MX Greens
« Reply #35 on: Sun, 17 February 2013, 20:17:19 »
They are. FormerlyLysol and I were having an argument over it 1st page. where were you?
Offline MKULTRA
  • telling it how it is
Re: MX Greens
« Reply #36 on: Mon, 18 February 2013, 00:16:03 »
OP there are some vintage black springs for sale atm.  Might be worth checking out
