Author Topic: CM QFR Media keys issue  (Read 2402 times)
Offline tauburn
« on: Sat, 16 February 2013, 16:43:28 »
The media/volume keys on my qfr seem to only work when they feel like it. It has no correlation to what applications i have open, but right now they wont work at all. yesterday they were fine. this happens all the time. they choose whether or not they want to work.
does anyone know why this would happen. plugged in through ps/2 and my computer is  running windows 7
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: CM QFR Media keys issue
« Reply #1 on: Sat, 16 February 2013, 19:30:11 »
I'd get an RMA. The only cause I can think of is the Fn switch or traces being hosed. I'm using them extensively in 7 Ultimate with PS/2, no issues. Just in case, you did remember to double check which audio device is set active, right? What about the PP, Stop, Prev and Next keys? Win Lock?
I mean really other than that, it's literally nothing more than a standard set 2 scancode being sent.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline gnubag
« Reply #2 on: Sat, 16 February 2013, 19:39:08 »
easiest would be testing it on another pc to see if it is the keyboard or not.
also did you get the QFR after the left alt problems? maybe it has the bad solder at the fn key instead.
Offline tauburn
« Reply #3 on: Sat, 16 February 2013, 19:45:13 »
I contacted CM and i'm waiting to hear from them.
i don't know anything about the "left alt problem" issue. it's one of the green switch models if that helps.
Offline gnubag
« Reply #4 on: Sun, 17 February 2013, 03:30:45 »
This is about the "left Alt" issue.
but if you still can rma it, go for it.
Offline kboardvintage
« Reply #5 on: Sun, 17 February 2013, 16:29:59 »
ye RMA it mate. Faulty batch apparently.
Offline tauburn
« Reply #6 on: Sun, 17 February 2013, 22:49:28 »
hmm. over 24 hrs and no response from CM
Offline gnubag
« Reply #8 on: Sun, 17 February 2013, 23:45:54 »
also presidents day.
