Author Topic: what to expect in my realforce 87u ?  (Read 18735 times)
Offline LifeIsGooD2
« on: Sat, 16 February 2013, 17:36:38 »
its coming monday ... its my first topre but I dont have ridiculous expectations ... although I do hope it is nicer than my filco with browns I wont be shocked if it is not ...
mainly I am hoping it might cause a little less strain over time on my hand and fingers( I heard it might) my filco doesnt really either but when I have to use them for about 8 hours a day at work any little bit helps
so just looking to see what  I should expect ? also will I notice a difference due to the PBT caps ? they are very appealing on the eye IMO but I have never used them to type before
Offline calavera
Re: what to expect in my realforce 87u ?
« Reply #1 on: Sat, 16 February 2013, 17:48:42 »
It's hard to describe but it feels like you're typing on bouncy jelly. :P It will take some time for the feel to sink in and really appreciate them though.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Sat, 16 February 2013, 17:49:23 »
Uh I've never used a Topre either, I'm getting mine next year.  I have filled my quota for my "scheduled keyboard purchase" this year  :)
From what I heard is that it will basically feel like a very high quality rubber dome, because it's basically what it is.  It has rubber cups inside.
So you might be a bit disappointed initially.  But if you stick to it and use it for a while, when you go back to cherry switch you'll start to notice the difference and by then you won't be able to use anything else.  Or at least this what I've heard.
Hope it helps  :P
Offline jpm804
  • KeyCap Assasin
« Reply #3 on: Sat, 16 February 2013, 19:00:04 »
I personally like it better than MX browns....Definitely something I think everyone (who is into keyboards) should try once, but its defintely not for everyone.
It definitely is something different if you are coming from MX switches and even rubber domes even though that is a closer comparison ( at least in my opinion). Which version did you get? .... Also I do like the texture to the PBT RF keycaps better than the PBT MX keycaps... I am not sure if the its combination of switches and PBT's but it feels good to me.
Let us know how it feels when you do get it... like you I started with browns then got my first Topre.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
« Reply #4 on: Sat, 16 February 2013, 20:37:41 »
You can expect Rubber-Dome, usually "lighter" than the ones you're used to, unless you've had very thin dome boards...
and the travel is quite rigidly-straight...
Offline karljs
« Reply #5 on: Sat, 16 February 2013, 23:13:55 »
I think the only correct answer here is that you will experience the "good feeling of oneness with cup rubber."  :D
« Reply #6 on: Sat, 16 February 2013, 23:38:47 »
That, or if you live in a liberal country, "dang, shoulda gotten 12x BJs instead for that much."
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #7 on: Sat, 16 February 2013, 23:55:12 »
I'm used to using browns as well, and id like to know your thoughts on the switch to topre.
Having a bad day?
Offline lazerpointer
  • ya gotta stay phresh
« Reply #8 on: Sun, 17 February 2013, 02:56:54 »
It's different, to say the least.
To me it seems like it requires more energy to type on Topre and my highest speed yet was 97 WPM on typeracer (was only to get that once out of the week I've had the board.) I'm still getting used to the switches, but I'm also looking into scissor switch boards because of the way Topres work. I'm actually considering a Razer Deathstalker. It just seems like with Topre I can't flow so easily... Maybe it's cause I'm used to lighter actuation force? (Using a 55g.)
Anyway I haven't had enough time with the Topres to conclude, but ATM I will make typos like accidentally adding extra letters or missing a letter. Backspace key is getting LOTS of love right now >.>
i type, therefore i geekhack
« Reply #9 on: Sun, 17 February 2013, 04:45:07 »
:D, I've seen this before, blame the keyboard for your crappy typing skillz :D
« Reply #10 on: Sun, 17 February 2013, 04:47:07 »
I am trying sooooooo hard, lol. I want to like this keyboard - not giving up just yet! Maybe I need to take a break from it for a few days.
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #11 on: Sun, 17 February 2013, 05:44:58 »
it took me 2 weeks to get back my old wpm on my 55g after my filco brown
« Reply #12 on: Mon, 18 February 2013, 12:27:49 »
Bit of an update here. I was over analyzing it.... I was trying Wayyy too hard. You have to relax and flow with Topre switches... Don't worry about minor details - remember the board is there to be your friend... your comfortable, smooth keyboard for long typing sessions. It IS sitting in front of my main home monitor right now, after going and buying that Deathstalker (made me remember why I moved on from scissor switch in the first place)
Side note;
bought a Ducky green alps for the living room computer... I liked the sound of it on youtube vids :3
Offline LifeIsGooD2
« Reply #13 on: Mon, 18 February 2013, 12:31:42 »
so far I am really liking it ...its fairly similar to my browns in some ways but its definitely like nothing else I have typed on not sure whether it will totally replace my browns but so far I think its great
off to try it for some sc2
Offline LifeIsGooD2
« Reply #14 on: Mon, 18 February 2013, 12:33:38 »
the only thing that I dislike so far is the spacebar not being the same type of cap
Offline eth0s
  • Peace & Love
« Reply #15 on: Mon, 18 February 2013, 14:07:38 »
Hmm, is that how you translated the Japanese?  Because I think a closer translation is "typing on this gives good feeling of a cloud of boobs."
Offline HybridCore
« Reply #16 on: Mon, 18 February 2013, 16:21:32 »
Topre is sort of the middle ground between mechanical and rubber dome keyboards so expect a slightly mushy mechanical switch. I didn't really like Topre all that much because I love having no mushiness at all. It definitely had really smooth travel though which I did enjoy a lot.
Offline Michael
  • Formerly Bro Caps
« Reply #17 on: Mon, 18 February 2013, 16:43:16 »
Topre is not the 'middle ground', but that's personal preference. 55g RF's do not feel mushy. They are quite snappy and have a very pronounced tactile bump.
If you like scratchy, or obnoxiously loud clicky switches, stick with MX :)
Offline sth
  • 2 girls 1 cuprubber
« Reply #18 on: Mon, 18 February 2013, 16:48:25 »
there is nothing mechanical about topre switch actuation... they don't feel mechanical in the slightest. they feel like really nice rubber domes because they are really nice rubber domes.
cup rubber is not a four letter word
Offline eth0s
  • Peace & Love
« Reply #19 on: Mon, 18 February 2013, 17:31:03 »
Yeah, TBH, I think all the fuss over stickers and lube, and special Korean springs, is just part of an attempt to make a Cherry MX switch feel smooth like a Topre.  Why go through all that hassle, when you can just get Topre?
With that said, I am currently adding stickers and lube and special springs to my Phantom project.  So I am one of those people too.  But at least I know I'm trying to get my MX switches to feel more like my Topre switches, and I'm not kidding myself.
Oh and the Silent (purple) Topre switches are superior to the regular (black) ones.
Offline Michael
  • Formerly Bro Caps
« Reply #20 on: Mon, 18 February 2013, 17:47:33 »
This.
I have built the epitome of cherry switch boards. Best lube, stickers, etc. At the end of the day, my RF 55g still felt better. Call it a rubber dome if you like, it feels nothing like one.
If you had to compare it to an MX switch, an MX clear would be the closest in terms of tactile bump. I am sure there are plenty of haters that don't understand why the price premium,
but spend enough time with a RF or HHKB and you will understand why.
Offline sth
« Reply #21 on: Mon, 18 February 2013, 18:12:14 »
i have used a couple of  rdoms boards that do feel closer to topre than others. i just wish we could get past the 'rubber dome = bad' or the association between rubber dome and RDOMS.
« Reply #22 on: Mon, 18 February 2013, 18:18:14 »
On MY 55g, there's really no "bump" but more of a "collapse" of the rubber cup, which indicates that within a milometer or so, the switch will actuate. (The tactile bump people keep referring to does NOT happen when the switch is actuated. It only changes the resistance of the switch in a kind of pleasant way, so that A- you know when the switch is being depressed, and B- when you bottom out, it's very soft and smooth.)
IMO with Topre (as opposed to cherry browns) you will rely more on relative positioning and spacial awareness (muscle memory, like a linear switch) rather than tactile feedback.
Offline Michael
  • Formerly Bro Caps
« Reply #23 on: Mon, 18 February 2013, 18:24:51 »
I guess when I think of rubber dome, I think of the current gen of Logitech-type boards. So that's what I am basing it off of. But I have used some higher quality rubber domes that feel nice. Not as nice as my 55g, but nice.
I guess if you consider MX switches as the 'traditional' tactile bump, then topre is an entirely different beast. But it's still a tactile bump, and quite pleasing to type on. So you definitely don't rely on that bump to tell you when the switch is activated, but you definitely enjoy topre because of it.
« Last Edit: Mon, 18 February 2013, 18:27:43 by Bro Caps »
Offline Nunez
  • BACK!
« Reply #24 on: Mon, 18 February 2013, 18:30:01 »
All I can say is, be open minded about it. Give them a chance and you'll most likely grow to love them. I love all my keyboards, in their own unique way.
Typing this on 104U Variable.
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline fuzzybaffy
« Reply #25 on: Mon, 18 February 2013, 20:51:26 »
Whenever I type on a typical rubber dome, I think of this:
But when I type on a Topre, I'm constantly reminded of this:
Which is basically what it is. It certainly has rubber, but there are springs underneath it, so the overall feeling is like a... springy rubber. Or a rubbery spring. If that makes sense.
« Last Edit: Mon, 18 February 2013, 20:53:04 by fuzzybaffy »
Offline o2dazone
« Reply #26 on: Mon, 18 February 2013, 21:09:57 »
I got tired of sleeping with all the 16 year old hussies (cherry), and eventually wanted to settle down to a more mature board that I never have to fiddle with, and will take care of my needs (topre)
Offline sth
« Reply #27 on: Mon, 18 February 2013, 21:10:51 »
you're the hussy in that example
nttawwt
Offline o2dazone
« Reply #28 on: Mon, 18 February 2013, 21:16:47 »
nttawwt
Offline o2dazone
« Reply #29 on: Mon, 18 February 2013, 21:21:26 »
Well said. People love the mechanical feel. The actuation, the tactile bump, the click, the clack. Those who can't live without it, will look at Topre switches, and find them boring.
Offline AKIMbO
  • HHKBro
« Reply #30 on: Mon, 18 February 2013, 21:34:56 »
Topres are their own beast.  They are tactile, just not as sharp as a cherry switch.  The best comparison is a dampened alps switch.  But even the dampened alps switch is sharper than a Topre.  When I'm old and arthritic, I will turn to topre....for now....I'm young and want dem hussies!
| KBD75 (box reds)
Offline simingma
« Reply #31 on: Tue, 19 February 2013, 00:38:16 »
You will like it, it's technically rubber dome, but it has a tactile feel of its own category. Keep them all! lol
Offline eth0s
  • Peace & Love
« Reply #32 on: Tue, 19 February 2013, 00:54:00 »
Boom:  Topre Baby
Offline kboardvintage
« Reply #33 on: Tue, 19 February 2013, 04:19:35 »
Boom:  Topre Baby
looks sooo tasty
Offline sth
« Reply #34 on: Tue, 19 February 2013, 05:29:28 »
Offline LifeIsGooD2
« Reply #35 on: Tue, 19 February 2013, 07:47:15 »
just in case anyone missed my earlier post I am really really liking it
just wish the spacebar was the same as the rest of the keycaps
Offline LifeIsGooD2
« Reply #36 on: Tue, 19 February 2013, 09:28:16 »
update I will be using my filco again since I play so much starcraft
I should have listened when people said topre is not good for gaming so I will be selling it if anyone is interested I will be posting in classifieds sometime today when I know what to ask for
but I have zero regrets ...for those people wanting to try topre DO IT ... it is an amazing keyboard if it wasnt for so much gaming I would never think of getting rid of it .. if I had to make a review I would say it is nicer build quality and feel than cherry MX but for me it is not optimal ...
thanks guys
Offline AKIMbO
  • HHKBro
« Reply #37 on: Tue, 19 February 2013, 09:41:24 »
thanks guys
Might I ask why you say it isn't good for gaming?  I use my 87u all the time for late night CS:GO, BF3 sessions, and L4D2 sessions.  I'm not an RTS gamer.....is it the key layout?
| KBD75 (box reds)
Offline LifeIsGooD2
« Reply #38 on: Tue, 19 February 2013, 09:49:51 »
Im not sure if its actually bad for gaming
I prefer the realforce for typing I prefer the filco with browns for gaming ... gaming is the biggest need for me so Im going with the filco ...this is the scenario I figured would happen but I am glad to try the realforce so now I know ... it really is a fantastic keyboard
Offline fuzzybaffy
« Reply #39 on: Tue, 19 February 2013, 11:17:03 »
Really? I love the Realforce for gaming, but, to each their own I guess.
Offline LifeIsGooD2
« Reply #41 on: Tue, 19 February 2013, 12:14:41 »
its probably more of how much I love my filco and being so used to it
Ive tried
Black widow MX Blue
Npoppo Choch red
filco red
now realforce topre
and always end up back with my trusty filco browns
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #42 on: Tue, 19 February 2013, 12:28:46 »
I'm selling my Deathstalker if interested.
I'd also be willing to trade it for a Realforce 87U.
« Last Edit: Tue, 19 February 2013, 12:31:40 by OnTheBrink »
« Reply #43 on: Tue, 19 February 2013, 12:34:46 »
LOL. LOL.
« Last Edit: Tue, 19 February 2013, 12:42:35 by Flip »
Offline calavera
« Reply #44 on: Tue, 19 February 2013, 12:35:08 »
I actually prefer gaming on my realforce. Dunno why you feel the opposite.
« Reply #45 on: Tue, 19 February 2013, 12:42:40 »
I find it's fine for gaming now - I was really over thinking it that day, and was a bit pissed off. I mentioned that I did actually go pick up a scissor switch board to try it for a while, but then went back to mainly using my Topre. Mouse = 20x more important when it comes to gaming anyways. If anybody's curious, I'm mainly using a Logitech g400 atm.
Offline OnTheBrink
    • Wired In Store
« Reply #46 on: Tue, 19 February 2013, 12:44:23 »
LOL. LOL.
For extra money obviously, not a one to one trade.
Even though a Deathstalker new is the same price as an 87U. So still, I don't understand the sarcasm.
« Reply #47 on: Tue, 19 February 2013, 12:46:51 »
Sorry about that, uncalled for. I intend to keep both my 87u and my Deathstalker.
Offline OnTheBrink
    • Wired In Store
« Reply #48 on: Tue, 19 February 2013, 12:50:46 »
All good. I got an offer of $200 for the Deathstalker. I think I'm just going to flip it. I am really not impressed with it. Maybe because light feels cheap or I am spoiled by the heaviness of my mechs.
Nevertheless, it feels cheap to me.
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #49 on: Tue, 19 February 2013, 12:53:55 »
 :eek:
Having a bad day?
