Author Topic: Mixed Switch Color Keyboard?  (Read 2795 times)
Offline Luke
    • My Technology Blog
« on: Thu, 28 February 2013, 17:43:48 »
Hi Guys,
I was just thinking of which switches to use when I build a GH60, currently I use MX Blues on my KeyCool 87 and I really enjoy it for typing day to day. The only time I don't enjoy my blues is when I'm gaming, I find that the WASD keys take too much force to actuate. So then I had a thought, how about I use a medium-stiff switch (Clears) for most of the keys and just have the WASD keys with light switches (Reds).
Would this be a good idea or would it be weird to type on?
Cheers :D
Offline inteli722
Re: Mixed Switch Color Keyboard?
« Reply #1 on: Thu, 28 February 2013, 17:45:14 »
If you think it's a bad Idea...then tell Ducky that.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=291
Waiting for: Phantom Plate
Offline Luke
« Reply #2 on: Thu, 28 February 2013, 17:51:08 »
Haha indeed, but I think there's a bit of a difference between that and what I proposed :P
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #3 on: Thu, 28 February 2013, 17:55:14 »
The springs in blues and reds are the same weight.  Clear springs would be heavier, but if that's ok for typing, go for it there.  If blues are too heavy for WASD use, get something lighter like the 55g springs that sherry sells.
Offline Luke
« Reply #4 on: Thu, 28 February 2013, 18:08:14 »
Ah ok, thanks for that :) I would probably go with blues again to be honest because I like them, but I haven't tried anything else so i want to mix things up a little  :))
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #5 on: Thu, 28 February 2013, 21:31:47 »
I went from blues to clears/blacks.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Fri, 01 March 2013, 11:28:34 »
If you like blues but want something without it's shortcomings try light whites.
« Reply #7 on: Fri, 01 March 2013, 12:10:30 »
If you think BLUEs are too heavy... there's nothing out there for you... You'll need a new hobby.
Offline noons
« Reply #8 on: Fri, 01 March 2013, 15:15:29 »
Reds, hell even browns to me feel lighter then blues.
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
Offline mechanisch
« Reply #9 on: Fri, 01 March 2013, 15:18:41 »
Wow, I didn't know that the springs for Blues and Reds were the same.  I guess the tactile bump makes them feel heavier and more sluggish (to me).
Offline Luke
« Reply #10 on: Sat, 02 March 2013, 03:31:24 »
Cheers guys, but like I say it's just the tactile bump on every little movement, and when playing something like Scout on TF2 it feels really weird. I thought that reds had a much smoother travel? :)
