Author Topic: MX Greens might be...  (Read 1910 times)
Offline t4t3r
« on: Thu, 28 February 2013, 18:27:09 »
The sweet spot for me! My second QFR just came in today, this one of the Cherry MX Green variety.  Finally pulled the trigger on a new keyboard about a month ago after an older rubber-dome Logitech called it quits, and this QFR is my third new keyboard within that time...I totally underestimated this place after lurking for so long.
Not a big fan of Browns which are on a Rosewill RK9000 that I'm now using at work.  My other QFR has Blues which I do really like even thought I didn't expect to, but the actuation on both Browns and Blues is a little light for my taste.  Enter Greens, which I am REALLY liking so far.  For people who own boards with Greens and Blacks, what are your thoughts between the two?
Next up, some dye-sub PBT caps for this sucker :)
Offline zoolzoo
Re: MX Greens might be...
« Reply #1 on: Thu, 28 February 2013, 18:59:20 »
Never tried em. Send me your board and Ill post a review.  :-*
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline jabar
« Reply #2 on: Thu, 28 February 2013, 19:06:59 »
I do like linear switches but I feel that linears benefit from lighter springs (I much prefer Reds over Blacks). Greens are much more satisfying to actuate over Blues because the click is more subdued and the resistance helps prevent bottoming out.
As for your question, Blacks and Greens don't really compare. I do have trouble sustaining Greens; Blacks are a bit easier but I'd prefer Reds.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline crthell
    • crthell
« Reply #3 on: Fri, 01 March 2013, 01:39:38 »
We forgive you, but you must pay...with your wallet! *evil laugh*  :p
/crthell
Mechanical Keyboard(s): Apple Extended Keyboard II M3501 (dampened Alps)
Quality Rubber Dome(s): Dell QuietKey RT7D5JTW
Offline crthell
    • crthell
« Reply #4 on: Fri, 01 March 2013, 01:40:22 »
My idiocy aside, congrats on finding a switch that works for you.
/crthell
« Reply #5 on: Fri, 01 March 2013, 03:32:43 »
Greens are good..
They're troubling if you have inconsistent weather // room-temperature..
at 80F all's good.. But as soon as you go down to 75-72, your hands start to freeze up in the coldness... And the 80g force becomes too much to sustain.
Offline t4t3r
« Reply #6 on: Fri, 01 March 2013, 07:44:20 »
Is there a switch between blues and greens, maybe like 70g AF?  I think I'll just have to take the plunge anyway and try out the other 2 switches I'm missing, blacks and reds are still intriguing for some reason...
Offline jabar
« Reply #7 on: Fri, 01 March 2013, 07:57:02 »
MX Blacks are in between Blues and Greens in actuation. The springs are different; maybe if you can swap out Green springs with Blacks (a tedious procedure unless the board has PCB-mounted switches) you'd get an in-between switch.
http://imgur.com/a/RJqM4#0
Phantom 7bit
