Author Topic: Rapoo - "Yellow shaft" MX clones?  (Read 3172 times)
Offline DamienG
    • DamienG
« on: Thu, 07 March 2013, 01:21:11 »
Just saw this keyboard on eBay http://www.ebay.com/itm/Rapoo-V7-87-keys-fully-programmable-PRO-Mechanical-gaming-Keyboard-yellow-shaft-/280897072580?pt=PCA_Mice_Trackballs&hash=item4166c52dc4
Switches look like some MX clone in... yellow. Specs look like a bad tolerance red.
Anyone seen these before?
Meh: Just found another thread with this already. Please ignore. I forget search is context sensitive.
[)amien
Offline esoomenona
  • Gnillort?
Re: Rapoo - "Yellow shaft" MX clones?
« Reply #1 on: Thu, 07 March 2013, 07:18:38 »
Speaking of, the context sensitive search should tell you what context you're searching in.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 07 March 2013, 11:58:46 »
Most that have encountered these in real life have been fairly disappointed. Here you can view the shameless copying of MX in detailed tear down by Kailh themselves.
However if you happen to have some spare real MX switches laying about, you can improve the keyboard itself by replacing the switches with some that don't break.
Offline FoxWolf1
  • 154
« Reply #3 on: Thu, 07 March 2013, 12:02:30 »
If I recall correctly, these yellows were one of Kailh's earlier attempts at an MX clone. Wonder if they've improved?
Force was supposed to be somewhere between MX Red and MX Black, I think-- a promising idea, perhaps, but only if the switches actually hold up.
Offline whiskytango
  • Don't touch the trim
« Reply #4 on: Thu, 07 March 2013, 12:10:25 »
I love how the write up starts with "developed with independent intellectual property rights" and then proceeds to detail how they copied the Cherry switches in almost every dimension and detail. You are correct, that is shameless
« Reply #5 on: Thu, 07 March 2013, 12:11:59 »
improved????
seriously???
this is 2013 people... we're well beyond improving this level of tech...
It comes down to "cost", which is why the mx was even copied in the first place.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Thu, 07 March 2013, 12:14:27 »
The lowest context possible... so if you are looking at a thread, context is *that thread*, if you are looking at a sub forum, that's the context... and so on up the tree.
As an example, while reading this thread, search for leopold, then backup and try kailh.  Then go to the keyboards forum and try it again. :)
Filco w/ Imsto thick PBT
Offline esoomenona
  • Gnillort?
« Reply #7 on: Thu, 07 March 2013, 12:23:00 »
Is there a user context?
Offline esoomenona
  • Gnillort?
« Reply #8 on: Thu, 07 March 2013, 12:23:46 »
Also, would it be possible to have links of that tree to easily move up it to our desired context?
Offline phetto
  • HHKB JP
« Reply #9 on: Thu, 07 March 2013, 12:47:25 »
Has anyone confirmed if those stems fit a real cherry switch? I don't want to hear the same thing as the last time I asked, about how bad they are.. It's purely aesthetics for some cool modding a boring Sunday night :D
Offline DavinDidIt
« Reply #10 on: Thu, 07 March 2013, 13:56:55 »
The form factor and aesthetics of the board as a whole actually look pretty good!
KMAC 2, HHKB
Offline cannedlemons
« Reply #11 on: Thu, 07 March 2013, 21:50:56 »
I actually own one but is a different brand but I believe they are essentially the same. They aren't THAT bad but then I haven't used any actual Cherry keyboards yet, only ALPS so I can't really compare. But I can say that they have no clicky noise or tactile feedback so a silent keyboard...
Offline mcgci5450
« Reply #12 on: Fri, 08 March 2013, 23:25:42 »
http://www.kailh.com/en/products.asp?Categoryid=113&rel=15       Definately a cherry clone
I wonder what else these switches are used in. I think it would be interesting to see which cherry switches they feel the most like.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #13 on: Sat, 09 March 2013, 00:11:14 »
The profile on that stepped key looks interesting-- like they found a way to make it stepped and still fit a centre mounting pin.
Overton130, Box Pale Blues.
