Author Topic: Your thoughts on TTE (ThermalTake) Mechanicals  (Read 2491 times)
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« on: Fri, 15 March 2013, 13:05:51 »
We'll likely be offering a full line of TTE soon.  The G1s are all Costar which I know GHers go nuts over, but the frames on the newer 'G Units' aren't the simplest of form factors (not sure ODM on these either).
Any opinions?
http://usa.ttesports.com/productlist.aspx?c=2
MechanicalKeyboards.com - What do you type on?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Your thoughts on TTE (ThermalTake) Mechanicals
« Reply #1 on: Fri, 15 March 2013, 13:14:56 »
Personally if it was my call I would only carry the G1 variants. I think the others are made by solidyear, I think who also responsible for the Corsair, Logitech and CM TK. Then also how well do your other keyboards with black switch sell, since that is all Tt come in that should be a high consideration too.
Offline ShakeR
« Reply #2 on: Fri, 15 March 2013, 13:23:20 »
Thanks for your input Ivan!
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Fri, 15 March 2013, 14:12:04 »
Meka and Meka G-Unit are made by iRocks. Quite solid keyboards, but I'm not a fan. The G-Unit is too gimmicky, and they've ruined the 96layout on Meka.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #5 on: Fri, 15 March 2013, 15:10:59 »
The Meka G1 is a Costar CST-104 "Sydney" and a solid board with the lowest damn quality keycaps ever. I mean really, really solid. The kind that makes it a slap in the face to put such garbage keycaps on. HOPEFULLY they fixed the broken debounce. Oh, and ALL of the G1's are Costar CST-104's. Including combat white, Illuminated, and the G1 Prime. (So yeah, backlit Costar, blah blah.) But dear gods, they are the lowest quality keycaps ever.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline daerid
    • Rossipedia
« Reply #6 on: Fri, 15 March 2013, 15:34:14 »
The blacks on the Meka G1 are by far the sweetest blacks I've ever typed on
Offline daerid
    • Rossipedia
« Reply #7 on: Fri, 15 March 2013, 15:34:25 »
Damn Tapatalk double post
Offline dante
« Reply #8 on: Fri, 15 March 2013, 17:48:22 »
I agree with this!  The MX Blacks in the G1 feel like they are lighter than most stock Black switches.  They do not feel half way between Red and Blacks but feel 5g'ish lighter than Blacks.  Either they've got some lube / lighter springs or they are installed at such a perfect typing angle that they lose a lot of the gritty feeling you can sometimes get.
While I agree the keycaps aren't the best, the excellent feeling of the particular switches on the G1 make up for it.
If you want better keycaps - that's what the accessories page on mechanicalkeyboards.com is for. ;)
Offline laffindude
« Reply #9 on: Sat, 16 March 2013, 03:07:21 »
I believe iRocks use Solid Year as OEM as well.
Offline Demofly
« Reply #10 on: Sat, 16 March 2013, 05:03:30 »
I'd personally only stock the Meka G1s. I've never seen someone with anything else and I wouldn't personally buy anything else.
i5 2300 - 7870Ghz - 8GB DDR3-1600 - 21.5" Acer 1080p
HPE 87 MX Brown + Ducky PBT (purchased from Flip!) | Ducky 1087XM Xiang Min Black ALPS clones.
Offline davkol
« Reply #11 on: Sat, 16 March 2013, 06:48:47 »
Yep, lsusb output suggests that. At least the Meka is slightly modified iRocks design though, and G-Unit is more or less the same.
