Author Topic: A question about cherry brown noise and between filco and ducky...  (Read 2235 times)
Offline frowni
  • i love typing!
Hey,
As you can see i've 2 questions :)
First,
Check out this video:
Is Brown really this noisy or is it the video? If they are, are reds quiter?
I'm ordering a new keyboard tomorrow and trying to decide between Filco and Ducky, some says Ducky's are great others say Filco's are top notch. Can you help me on that if you used them both?
I'm either buying,
http://www.cclonline.com/product/92970/DK9087G2P-BUKPLW/Keyboards/Ducky-G2-Pro-Mechanical-Keyboard/KBD0503/
which looks very pretty, especially white caps on black.
or
getting the Filco tenkeyless cherry brown..or red still couldn't decide.
Thank you
Offline Koroviev
  • Well-rounded otaku
Re: A question about cherry brown noise and between filco and ducky...
« Reply #1 on: Sun, 17 March 2013, 22:47:52 »
That's the sound of the keys bottoming out.
Edit: And I would personally go with the Filco since I'm not a big fan of LED backlighting.
« Last Edit: Sun, 17 March 2013, 22:56:37 by Koroviev »
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Sun, 17 March 2013, 22:55:54 »
To answer your question:
1.  Yes red is slightly quieter but not by much.
2.  Personally I'd go with Filco.
MX Brown
MX Red
Offline WhiteFireDragon
    • youtube
« Reply #3 on: Sun, 17 March 2013, 23:06:46 »
The only noise you hear from mx browns is the bottom-out, and when the keys spring back up.
Filco and the newer duckies are pretty much on part in terms of quality. Their internals are very similar.
Offline Skull_Angel
« Reply #4 on: Sun, 17 March 2013, 23:24:50 »
Between the two, I prefer Ducky for the Cherry stabilizers.
Offline Hyde
« Reply #5 on: Sun, 17 March 2013, 23:34:18 »
Lol I actually picked Filco because of Costar stabilizers. I guess it's a preference type of thing.
« Reply #6 on: Sun, 17 March 2013, 23:36:08 »
Un-dampened with orings... blue brown black red mx, are all pretty loud.. because of the clack noise when it bottoms out, and the Dchat-- noise when it rebounds.. the 'D' is silent when pronouncing "dchat'
with orings, the red brown and black are quiet on the down stroke, but then you still have the upstroke which remains undampened.. Though if you want to argue, that since the oring reduces travel, technically, the upstroke has less energy and thus is ALSO dampened... well then you'd just be right.. but yea so you see..
« Reply #7 on: Sun, 17 March 2013, 23:38:41 »
no it's cuz costar is better because it's less sensitive to alignment.
cherry is problematic because if there is any misalignment, you get a mushy-friction-ee feeling at the bottom
Offline DavinDidIt
« Reply #8 on: Mon, 18 March 2013, 00:02:23 »
Honestly, I'd go with whatever one is cheaper.
KMAC 2, HHKB
Offline TheQsanity
  • SmallFry Lovin'
« Reply #9 on: Mon, 18 March 2013, 00:09:36 »
Pbc mounted kbs seem to make less noise. Cherry stabz seem to also make less noise.
SmallFry! <3
Offline Koroviev
« Reply #10 on: Mon, 18 March 2013, 00:49:57 »
CFR with no branding.
