Author Topic: Apple Extended Keyboard II, sore left pinky finger  (Read 3185 times)
Offline sameer.wahid
« on: Wed, 20 March 2013, 12:10:31 »
I recently switched away from my MS ergo kb to an Apple Extended Keyboard II. I love the tactile feel, but I'm starting to feel some pain in my left pinky finger. I suppose it's most from tapping the "a" and left shift keys. Anyone know of a way to help solve this problem? (lower the actuation force, inject steroids into my pinky, whatever).
Offline iri
Re: Apple Extended Keyboard II, sore left pinky finger
« Reply #1 on: Wed, 20 March 2013, 12:16:35 »
seriously, moving to a lighter switch. cherry blues, browns or ergo clears (once you are ready to do the modding).
-Ray Bradbury
Offline ishumprod
« Reply #2 on: Wed, 20 March 2013, 12:16:48 »
iirc that keyboard has yellow or orange ALPs, so i would suggest lubin them. as for how to do so there should be a page on wiki, or maybe someone here will be able to help you
yeah alps :
http://www.google.ch/search?hl=fr&safe=off&biw=320&bih=416&tbm=isch&sa=1&q=ALPS+apple+extended+keyboard+2&btnG=#biv=i%7C3%3Bd%7C-ougfCzoL2FYfM%3A
« Last Edit: Wed, 20 March 2013, 12:19:50 by ishumprod »
home-made TKL rubber dome keyboard !
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #3 on: Wed, 20 March 2013, 12:36:52 »
They are cream dampened ALPS (the original AEK used undampened orange).
I know that some people swear by lubing their ALPS switches with RO-59. If I had an AEKII that I loved, that's what I would try.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
« Reply #4 on: Wed, 20 March 2013, 12:37:13 »
It probably has "dampened cream" Alps which are not too heavy.
If it is old and dirty, they can get sluggish.
I got some teflon lube for mine, which helped.
- Franklin Roosevelt 1933
Offline Burz
« Reply #5 on: Wed, 20 March 2013, 12:40:18 »
Yes, dirt. You'd want to clean the affected switches before lubing them. The good thing about it being the left pinky is you probably only have to service 2 keys.
« Reply #6 on: Wed, 20 March 2013, 12:51:20 »
If you like apple.. get their WIRED full size scissor board... that's really the only good one...
Offline 1391406
« Reply #7 on: Wed, 20 March 2013, 13:16:14 »
I disagree. I have two Apple Extended Keyboard's (M0115) and think they're great. I don't care for the feel (or sound) of the AEK II at all.
Offline ishumprod
« Reply #8 on: Wed, 20 March 2013, 13:54:19 »
type for an hour or two on the M0116 of m teacher and i have to say alps feel great. nothing to see with scissor
« Reply #9 on: Wed, 20 March 2013, 15:25:03 »
Thanks, I'll look up how to lubricate the switches. They are indeed the cream ALPS. I estimate they have an actuation force of about 75g, much more than I am used to!
Offline simon_C
« Reply #10 on: Wed, 20 March 2013, 17:23:30 »
yeah i'm gonna say they definitely need lube then, my AEKII was much lighter than that in the keys,
« Reply #11 on: Sat, 15 June 2013, 07:41:38 »
Just to follow up, I never did get around to lubricating the switches, but after a few weeks the soreness went away - either I had worked in the switch enough, or my pinky adjusted.
