Author Topic: Typing tutorials, ideas for creating a new one.  (Read 1800 times)
Offline ksm123
« on: Sun, 31 March 2013, 15:20:42 »
I'm doing my best to switch to Colemak. This means wasting my time on typing tutorials. I've started to think about typing tutorials in general, and I would like to bounce some ideas off keyboard enthusiasts (you).
1. Colemak tutorial in "gtypist" is too short, after a few repetitions, but well before I develop new "muscie memory", it gets boring.
2. Lists of words and N-grams frequency in English language are available on the Internet.
3. Computers are fast enough to measure not only how many mistakes I make, but also how long I hesitate before keying each letter (and how letter sequence alters my lag).
4. Data gathered by analysing my typing, correlated with 3-gram frequency data, can be used to predict which of my weak points will slow my typing down the most, and focus training on them.
5. Frequency lists can be used to create typing drills (selection of words or 3-grams, composed from "known" letters, randomly chosen,  with frequency as weight).
Do you know of any typing tutorial working in similar way?
What typing tutorials did you use? What were their pros and cons?
What other features you would like to find in typing tutorial?
Re: Typing tutorials, ideas for creating a new one.
« Reply #1 on: Sun, 31 March 2013, 19:44:11 »
mmm.. typing tutorials are not necessary..
Your "Daily" computer routine is the most adequate and adapted learning you could need...
It trains you on the stuff YOU type.
The only important thing is forcing yourself to use the new layout...
HOWEVER... ultimate typing speed is NOT hindered by layout...
If your reason for changing layout is for "ergonomics sake", then again I urge you to not bother, because the bulk of keyboard related injuries is due to "OVER USE"
No 'magical layout"  will ever remedy that...
You're better off retraining your technique on the SAME layout...
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Mon, 01 April 2013, 13:29:56 »
Amphetype
Also, there are some interesting compilations of tests at forum.colemak.com.
