Author Topic: Mechanical keyboard  (Read 8269 times)
Offline drynnn
Mechanical keyboard
« on: Fri, 12 April 2013, 14:37:48 »
Hey, im buying my first mechanical keyboard, im going to use it for MMORPG such as WoW and FPS like bf3, css and so on.Cant decide between cherry mx brown,blue or red. I heard that double tapping is hard on blue ?  :confused:
Offline bazemk1979
Re: Mechanical keyboard
« Reply #1 on: Fri, 12 April 2013, 15:34:32 »
reds are found to be most acceptable between newcomers and people with seniority among keyboards, same goes for gamers and typist. Left you pm
Offline babyhands
« Reply #2 on: Fri, 12 April 2013, 16:34:54 »
I have used and owned all three of those switches, and used all of them for gaming. Honestly, I think it is all personal preference. I dislike the reds, just because I don't like linear switches, and none of them really made a difference for me while gaming, and i game quite a lot :P
Offline csloan1218
  • Technomancer
« Reply #3 on: Fri, 12 April 2013, 16:52:25 »
I just went to reds from a membrane board, I like it, although I haven't used any other switches yet.
Ducky DK9008 Shine II Blue LED Backlit (Red Cherry MX)
Leopold Linear Touch FC500RR/AB (Red Cherry MX)
Offline tauburn
« Reply #4 on: Fri, 12 April 2013, 16:55:54 »
it amazes me that people are willing to sign up for a forum to find out info that can be searched for on google. but to answer your question, it is physically impossible to play games unless you have a linear switch. blues and browns are only double clickable if you are superman.
Offline ping111
« Reply #5 on: Fri, 12 April 2013, 17:10:57 »
Or, if you're really gentle.  I can press one key at least four times a second on my brown but hovering my finger just over the bump, and pushing it just under.  If you slam your keys when you game, your problem.
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline drynnn
« Reply #6 on: Sat, 13 April 2013, 02:26:56 »
I guess i will go with reds..Any suggestions on which kb is good? Thinking of cm storm quickfire tk red
Offline csloan1218
  • Technomancer
« Reply #7 on: Sat, 13 April 2013, 03:28:02 »
for a backlit keyboard like the quickfire, I would recommend the ducky shine 2 as an alternative.
check out some videos on youtube to compare the two.
Offline babyhands
« Reply #8 on: Sat, 13 April 2013, 10:49:49 »
just buy my leopold :D, its higher quality than both boards and basically brand new
« Reply #9 on: Sat, 13 April 2013, 11:43:36 »
That isn't true.
Offline Rule16
  • R.I.P. SmallFry
« Reply #10 on: Sat, 13 April 2013, 14:10:25 »
Blues are only hard to double tap because the slider is not completely connected to the stem, any other cherry switch besides MX White (as in the west's white, not clears)
Diagram VS Browns
Double tapping with browns and clears, and any other fixed stem is definitely possible. So, If you want a tactile switch, get browns or clears.
Completely untrue, BROWNS are very easy to double tap, unless you're full on retard.
« Last Edit: Sat, 13 April 2013, 14:13:34 by Rule16 »
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Online tp4tissue
« Reply #11 on: Sat, 13 April 2013, 14:16:03 »
Mechanical keyboard has NOTHING to do with GAMING....
Yes, manufacturers took advantage of the gaming crowd, usually populated by kids, who'll believe anything..
The only Proven advantage to mechanical is reduced fatigue.
« Reply #12 on: Sat, 13 April 2013, 14:21:17 »
+1
Offline Abacus1234
« Reply #13 on: Sat, 13 April 2013, 16:07:51 »
How is reducing fatigue not an advantage in gaming? I'm not saying a good keyboard will make a bad player good, but if your equipment is more comfortable to use, you'll perform better. I can also double tap faster on mechanical, for what it's worth. I don't think anyone seriously believes that a mechanical keyboard is going to completely revolutionize their game immediately.
« Reply #14 on: Sat, 13 April 2013, 16:09:19 »
I think that's what TP meant. Of course being more comfortable is a huge plus, but it doesn't mean you actually perform better (unless you're playing for a long, long time in one sitting).
Offline Rule16
  • R.I.P. SmallFry
« Reply #15 on: Sat, 13 April 2013, 16:23:03 »
Thats the only "proven" advantage to typing as well... You type faster aswell, sure, but hmm wouldn't that translate right over to gaming?
Dvorak Only Zone
« Reply #16 on: Sat, 13 April 2013, 16:28:22 »
No it doesn't, or at least not in my experience. I am an avid FPS and dota player, and a mechanical board hasn't improve my performance in either. Of course, I do find it far, far more pleasant to use.
Offline tauburn
« Reply #17 on: Sat, 13 April 2013, 17:23:03 »
lol because any fatigue you'd have from gaming is like the slightest bit imaginable. unless you're a fat neckbeard who doesnt walk anywhere other than the fridge and bathroom, you're not going to feel tired from gaming
Offline Abacus1234
« Reply #18 on: Sat, 13 April 2013, 20:05:07 »
I don't think that is a very good argument. You sort of focused in on the word "fatigue" but I think it has more to do with a lower actuation force and comfort. If you're more comfortable, you're less distracted, which will help everything you do on the keyboard, from typing to gaming. I can tell you that when I game on a laptop I play worse. Partly that has to do with not being used to it, and sure over time I would adjust. But I think it would never feel quite as natural.
The other reason I think keyboards are relevant for gamers is that they are simply more durable than regular keyboards. I have mechanicals that have literally thousands of hours of typing time on them that still feel almost the same as new. Since gamers tend to use their keyboards for both work and play, it makes sense to have something more durable. The reasons mechanicals are better for gamers are the same reasons they are better for anyone. Why is it so hard to imagine that a keyboard which will increase your WPM will also have some very marginal improvement in how you perform in a game?
Online tp4tissue
« Reply #19 on: Sat, 13 April 2013, 21:14:35 »
A mechanical keyboard will NOT increase your WPM...   sean wrona is 200wpm on ANYTHING.. hand him 2 sticks not even connected to a computer, he'll still somehow conjure 200wpm on typeracer.
Offline PointyFox
« Reply #20 on: Sat, 13 April 2013, 22:10:31 »
It hasn't been proven to reduce fatigue.
Offline Truday
  • Grunt Life
« Reply #21 on: Sun, 14 April 2013, 06:38:36 »
 :)) @ Photekq. Tauburn has a point... so many kids/lazy people come here asking, "ok so plz tell me wat the bestest gaming keyboard is plz. I heard blues are best cuz they r clicky but cant double tap or redz bcuz dey are lyke typing on boobz kthx." Like c'mon people. There is a search button for this entire forum which has a **** load of threads and posts regarding the different types of switches in relation to gaming.  I'm sure most members here get tired of reading the same thread everyday asking which mech board is the best for gaming. Overclock.net @ http://www.overclock.net/t/491752/mechanical-keyboard-guide is a great guide to Cherry MX switches albeit a tad dated. Stop being lazy and use Google. I started out as a dummy not knowing anything about mechanical keyboards and bought a Razer BWU because I thought it was cool and was top of the line :rolleyes: and my buddy had one. After much research/reading, trial and error, and way too much money spent on RMAing keyboards let alone coming down with all too common mechanical keyboard frenzy fever :cool:, I know what I like personally and what works for me when I'm gaming, browsing the net, or just adding it to my collection. My best advice is to look for QUALITY mechanical keyboards like a CM QFR, Filco, or for flashy lights a Ducky Shine II. It'll save you a lot of money and headaches. Good luck.
-Truday
Currently own:
Noppoo Choc Mini Noppoo Choc Mini, CM QuickFire TK,CM QuickFire Rapid
CM QuickFire Rapid
« Reply #22 on: Sun, 14 April 2013, 06:54:41 »
-Truday
What Tauburn said about googling was true, but what he said about the switches wasn't. I agree people should google before coming here and asking.
Offline drynnn
« Reply #23 on: Sun, 14 April 2013, 09:18:08 »
-Truday
I have googled, alot.Just dont understand a **** cuz im new to mech keyboards :D
« Reply #24 on: Sun, 14 April 2013, 09:23:23 »
Good to be reminded that we all have opinions.
But, you might as well ask "which shoes should I buy?"
or even "which car is best for a mix of city and highway driving?"
There are half a dozen major common types of switches and most have sub-categories. Starting with Cherries, tactile for typists or linear for gamers, is as good a place as any, and don't get rid of something immediately after getting something else that you think is "better" on first impression .....
- Franklin Roosevelt 1933
Offline tauburn
« Reply #25 on: Sun, 14 April 2013, 11:48:46 »
-Truday
It's truly sad that you couldn't tell i was being sarcastic about the switches.
« Reply #26 on: Sun, 14 April 2013, 11:56:38 »
It's hard to detect sarcasm over the internet, especially when there are plenty of idiots out there who think certain switches (especially blues) are unusable for gaming.
Offline tauburn
« Reply #27 on: Sun, 14 April 2013, 12:08:46 »
i thought "physically impossible" would give it away but yh m8 i got u
Offline drynnn
« Reply #28 on: Sun, 14 April 2013, 14:41:46 »
What do you think about cm storm quickfire tk guys?
Offline tauburn
« Reply #29 on: Sun, 14 April 2013, 16:12:32 »
its great. get it.
Offline babyhands
« Reply #30 on: Sun, 14 April 2013, 16:34:34 »
So basically for the OP, the general consensus is: its personal preference. Some people like some switches, some people like other switches. Pro games use all types of switches and you aren't a pro, so get what feels best.
Offline Abacus1234
« Reply #31 on: Sun, 14 April 2013, 18:31:49 »
People on this forum sure are elitist. Why is it so offensive if someone wants a good suggestion for a gaming keyboard? Why do you act like all gamers who want mechanical keyboards type like idiots? I don't understand that at all.
« Reply #32 on: Sun, 14 April 2013, 18:48:45 »
I thought that my suggestion was very egalitarian.
Most people who engage in a hobby (ie subscribers to this forum) do it because they like to experiment and learn. I doubt that anybody here will say that the first keyboard he/she got is/was the best one they ever had.
Really, it is more like the drunken sailor's walk for a lot of us.
Offline tauburn
« Reply #33 on: Sun, 14 April 2013, 21:30:48 »
because there are a hundred of this same thread and every question he asked could be obtained from using google.
Offline Abacus1234
« Reply #34 on: Sun, 14 April 2013, 21:51:40 »
Somehow that still doesn't sound like a great reason to be a jerk to a newcomer.
Offline tauburn
« Reply #35 on: Sun, 14 April 2013, 23:16:07 »
it's just common sense.  theres a searchbar at the top of the site and probably a google search bar at the top of his browser..
Offline csloan1218
  • Technomancer
« Reply #36 on: Sun, 14 April 2013, 23:40:59 »
I'm new here and all my google research led me to this site, as I'm sure most of the people new here have in common. I'm sure some my questions were inane and annoying, but I got the answers I was looking for and got the best board to suit my needs. So I got my board and found a great (if not somewhat neurotic) community, its a win-win for me.
However, I think constantly directing people to google kinda defeats the purpose of a community like this. I would suggest using the search feature for this site, just not to clutter the board with reposts and spend some time there reading.
Offline tauburn
« Reply #37 on: Mon, 15 April 2013, 00:21:36 »
Offline Rule16
  • R.I.P. SmallFry
« Reply #38 on: Mon, 15 April 2013, 14:49:48 »
Its not that they're unusable, don't get me wrong, its just a bit more difficult because they're inconsistent. Let me stress the "a bit" in that sentence, ffs as long as a keyboard has 6kro or more, its fine for me, and I'm pretty competitive. It can be any switch really, its just the fact that I don't enjoy gaming on a rubber dome, so I use mechanical keyboards. Just like I don't enjoy that blues are inconsistent ( and feel linear to me, and click noise sounds artificial/annoying ) so I don't use them either.
Dvorak Only Zone
Offline PointyFox
« Reply #39 on: Tue, 16 April 2013, 20:39:42 »
Blues are more consistent than brown and linear since the click corresponds to actuation.  The other keys lack that. The bump comes before the actuation of browns and there is no way to tell with linears.  I guess the most "inconsistent" part about blues is that the reset point is above the actuation point, and there isn't much feedback to tell if it has been reset besides a slight change in rebound force.
Offline Rule16
  • R.I.P. SmallFry
« Reply #40 on: Wed, 17 April 2013, 12:11:20 »
That's what I meant, and I don't use linear switches. I'm thinking about getting blacks, soon though... But honestly I've been all over the place in the past couple months on what I wanted to buy.
Dvorak Only Zone
