Author Topic: Corsair K60 sweet liquid spill  (Read 2269 times)
Offline k9red4ever
« on: Tue, 16 April 2013, 07:44:51 »
Hello,
I've managed to spill some sweet liquid on my Corsair K60 keyboard. After disconnecting it, removing any inside excess liquid and letting it to dry for 2 days everything is working fine except 2 of the keys (S and D) that seem "sticky" and don't feel the same as the others.
What should I do to fix this? since the warranty is void in this case.
I've used a bit of circuit spray on the mechanical switches but with no result.
Any help is greatly appreciated.
Offline llovro
Re: Corsair K60 sweet liquid spill
« Reply #1 on: Tue, 16 April 2013, 08:29:47 »
I recommend switching the switches on S and D.
Offline admiralvorian
  • DIY
« Reply #2 on: Tue, 16 April 2013, 10:37:02 »
I'm not sure what kind of case this is but what I would end up doing is ordering two new keys (find out what's in there-PCB mount or plate-mount, MX Browns or reds or blues or whatever) and de-solder the messed-up switches and install some new ones.
Alternatively you can try to open the switches and clean them, but in many cases this requires desoldering anyway.
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
« Reply #3 on: Tue, 16 April 2013, 12:44:28 »
Hello,
Buy a bag of 10 switches from WASD, and replace them..
THIS saves SO MUCH TIME... vs cleaning.
