Author Topic: Compatability Question  (Read 1211 times)
Offline NikoGasm
  • Platinum mad.
« on: Sun, 21 April 2013, 01:22:05 »
I have the Phantom PCB and WFD's aluminum backplate. Would those fit properly into this?
Offline Jocelyn
  • 조셀린
Re: Compatability Question
« Reply #1 on: Sun, 21 April 2013, 01:43:15 »
It fits, but won't really work with the case (16:58 into WFD's video)
« Reply #2 on: Sun, 21 April 2013, 08:54:42 »
It'll fit fine.. you need to stuff the bottom to prop it up though..
