Author Topic: KBT ONI keycap lettering... fading? WTF!?  (Read 6359 times)
Offline Deceit
« on: Tue, 23 April 2013, 21:55:32 »
Hey everyone. I recently purchased a KBT ONI from mechanicalkeyboards.com
When I got it, I noticed some small "fading" on some of the keycaps lettering. I did some research and I thought these were suppose to be laser engraved?
For example, my left control and alt key fades from left-to-right. The left half the lettering is clear and looks new, the right half looks old and worn out.
My A, S, D, F , K, L, O, X, C, V, N, and M keys all have some sort of fading - most are very slight/minimal, but a few are fading very badly. This was something that came out-of-the-box (the keys with fading), but it seems that the amount of fade on these particular keys are getting worse as well.
I sent an email to them explaining this problem and asking if it was normal, no reply yet. I'm not very happy about this as you can see, $120 on keyboard, I expected something better with these PBT keycaps.
Thanks and please let me know if anyone else has experienced this issue before.
Maybe my research is wrong, and the keys are NOT laser-engraved? Thanks.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: KBT ONI keycap lettering... fading? WTF!?
« Reply #1 on: Tue, 23 April 2013, 22:12:25 »
they sure look pad printed to me, they look very similar to the pad printed KBT RACE pbt caps that i had that faded badly after a week of use.
Offline laffindude
« Reply #2 on: Wed, 24 April 2013, 09:09:18 »
Laser foaming legend is porous, and hand gunk gets stuck in it. They usually get permanently stained if you don't keep your hands clean.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #3 on: Wed, 24 April 2013, 09:35:41 »
Laffindude is spot on.
I've found the same issue with my ABS key caps that are heavily used. Thankfully there are tons of replacement key caps out there. Granted it's an additional expense, but part of the customizing process I'm afraid.
There are a lot of nice sets out there right now, such as Klaxon, or Coffee.
Hope that helps!
Offline dante
« Reply #4 on: Wed, 24 April 2013, 12:18:23 »
I know it seems 'uncool' but my HP rubberdomes use stickers for the legends and look almost as new as the day I got them.  I'm not sure why they don't offer this for mechanical keyboard caps.
Offline Rule16
  • R.I.P. SmallFry
« Reply #5 on: Wed, 24 April 2013, 13:06:13 »
Pad printing is essentially stickers, they're just really thin
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Deceit
« Reply #6 on: Wed, 24 April 2013, 17:59:24 »
So... are these pad printed or lasered?
Offline ideus
  • Björkö.
« Reply #7 on: Wed, 24 April 2013, 18:32:20 »
Public computers here at the University campus have stickers with legends and all of them seem with full texture and no fading at all, why the mechanical keyboards cannot be like that, these are 20 or 30 dollars boards.
Offline BlueBär
« Reply #8 on: Thu, 25 April 2013, 08:37:10 »
I had a Logitech K120 before that had pad printed keycaps and two letters were halfway gone after a month of not even heavy use. It really depends on the manufacturer I guess.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #9 on: Thu, 25 April 2013, 14:50:50 »
They're Vortex. Which means no matter what they are otherwise, above all else, they are cheap garbage.
Vortex has proven this time and time and time and time again. Pures with peeling paint, faded out of the box ONE and ONIs, you get the point. They have no damn business demanding the prices they do, since no matter what model, you'll be dropping another $100 on keycaps.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #10 on: Thu, 22 August 2013, 18:23:05 »
Don't worry, the ones on my Poker II are fading as well. It's kinda sad that the pbt's are nice just the printing. I swapped them out anyways. :(
IF there's away to remove the printing from the keycaps it would be great. Free blank PBTs :D
Offline rootwyrm
    • My Website!
« Reply #12 on: Fri, 23 August 2013, 04:09:30 »
The ONI is supposedly, and I do say supposedly dye sub PBT keycaps.
See for yourself.
So once again, sounds like Vortex lied and they're neither dye-sub nor PBT. So why do people keep buying Vortex? This is not the first time they've shipped garbage.
« Reply #13 on: Fri, 23 August 2013, 04:14:02 »
See for yourself.
that clearly says laser etched..
and since it's white lettering on black, that means white infills
You need more experience
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #14 on: Fri, 23 August 2013, 16:36:11 »
Not all lasering is infill. You can engrave and infill, or etch. Laser etching with dark plastic causes the plastic to turn dark "gold" (Topre), beige (older WASD) or white (Matias, current WASD). WASD and Matias modern etching is pure white, unlike the cream-coloured lumpy spooge that Cherry use with their engraved keycaps.
From what I understand, pad printed keycaps are not stickered: the decal look comes from a clear coating applied around the lettering to prevent wear. To avoid wasted coating, it only covers the area around the letters, giving keys the decal look. In many cases, the "ink" is not coated at all: it's been suggested that it's UV-coated ink; such ink is hard-wearing enough by itself as to not need a protective coating. Pad printing is fairly robust, but some people can wear through the ink in a few months! In other cases, it lasts intact for decades. Double-shot molding of course gives you a 100% guarantee of the legend remaining, and you don't get the grime build-up that you get with laser etching and laser engraving.
I've never found an authoritative source of information on pad printing for keyboards that explains the exact procedures used.
Bore Awards
Offline laffindude
« Reply #15 on: Mon, 26 August 2013, 02:45:27 »
I prefer to call it laser foaming, since that is roughly how they translate from Chinese. Laser etched IMO refers to the laser blackened legends. Modern ABS keycaps formulated for laser foaming do produce whiter "foam" legends.
  • RIP
    • Boring twaddle
« Reply #16 on: Mon, 26 August 2013, 06:34:29 »
I'm going by what WASD and Matias call it.
Bore Awards
Offline blizzardcraft
« Reply #17 on: Fri, 06 September 2013, 01:10:49 »
hi, i have the same problem too ! just not even one week into use >< my " WASDERFC" letters show sign of greyish shades on the letters =X
is it dirt or its fading? =(
Offline dante
« Reply #18 on: Fri, 06 September 2013, 07:40:04 »
Can anyone confirm if the ONI uses same spacebar spacing as the Leopold FC200R?  If not will any of the Vortex dyesub sets have spacing for the ONI?
Offline laffindude
« Reply #19 on: Fri, 06 September 2013, 09:42:31 »
No. Yes.
