Author Topic: Keyboard with detachable cable, but not located under the keyboard?  (Read 2583 times)
Offline Zackarak
Hey,
I'm trying to find a decent mechanical keyboard with a detachable cable that is looked at the back of the keyboard, but not under it like QFR.
I know some of the keyboards with this.
  • Korean boards
  • NEO KB 87
  • Ducky 1087
My budget isn't crazy high to purchase something for like 500 $. Max 200 $ for now. But yea, just want to know what kind of keyboards have that feature.
Re: Keyboard with detachable cable, but not located under the keyboard?
« Reply #1 on: Wed, 24 April 2013, 07:22:03 »
Idk...
sounds like you did your research.. and you're READY to get a korean board.
OR the GH60.  :D AMERICAN-affiliate  :D
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Wed, 24 April 2013, 07:34:27 »
Tt Meka G-UNIT, but that keyboard is otherwise terrible.
Offline Zackarak
« Reply #3 on: Wed, 24 April 2013, 07:37:36 »
forgot to add. I'm looking for TKL keyboard. But umm that Neo KB 87 looks kinda okay but I'm not so sure about having the pcb exposed :O
Offline Aer Fixus
  • And now, back to lurking...
« Reply #4 on: Wed, 24 April 2013, 10:03:49 »
Does it have to be modern? Do you have switch requirements (cherry, topre, etc)? Do you want to buy it from a retailer?
If not, you could consider the IBM Model M Spacesaver (it's a TKL Model M). If this is for constant transport, I might not recommend the Spacesaver because of its weight and the plastic clips that hold the detachable cable in. If it is for occasional transport it might fit your needs.
You will have to get it from another person, so it might take some time to find the right price.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #5 on: Wed, 24 April 2013, 10:09:57 »
You can get NIB model M's for less than $100 shipped on ebay. I prefer the really old ones, but those are harder to find. Used SSK's have often gone for $200-$300 on the other hand.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline polpo
    • http://polpo.org/
« Reply #6 on: Wed, 24 April 2013, 11:09:28 »
Matias Mini Quiet Pro and its other TKL brothers. Micro USB.
Matias Mini Quiet Pro / DSI SMK-88 (Cherry Black) / IBM Model M (10 Jul 86) / ThinkPad Travel Keyboard with Ultranav
Offline daerid
    • Rossipedia
« Reply #7 on: Wed, 24 April 2013, 11:26:39 »
The MQP uses Micro USB? That's pretty sweet.
Offline Zackarak
« Reply #8 on: Thu, 25 April 2013, 01:07:02 »
matias quiet pro loooks interesting, thanks :D
Offline TheProfosist
  • Custom Layouts Only!
« Reply #9 on: Thu, 25 April 2013, 08:05:53 »
What about that backlight MKC board?
Offline Zackarak
« Reply #10 on: Thu, 25 April 2013, 09:24:22 »
I have one :P using it at home
Offline Grim Fandango
« Reply #11 on: Thu, 25 April 2013, 20:14:15 »
A relatively cheap option for a keyboard which has this feature is the Rosewill RK-9000.
Just out of curiosity, why do you want a keyboard with a cable like this?
Offline cannedlemons
« Reply #12 on: Thu, 25 April 2013, 21:57:03 »
How about the poker? I am pretty sure the usb cable plugs into the back on the side.
Offline Zackarak
« Reply #13 on: Fri, 26 April 2013, 00:37:09 »
I want to have one to use at campus and it's nice to just unplug the board and take it with me instead of going behind the tower. Having it behind and not under the keyboard is just something I prefer.
I don't need the numpad but I do need the functions keys and del, home etc :)
I'm not buying one right now (Poor student yooooooo), just wanted to check what kind of keyboards are available cause I'm sure i've missed some. Didn't know about matias :)
Offline Barbastruzzolo
  • No money to buy a Topre
« Reply #14 on: Fri, 26 April 2013, 02:49:10 »
Filco MINILA!
I ordered it yesterday and it's coming soon!
Filco FKBN88M/UKB2 || Cherry G80-3000LSCIT-2 || Cherry G80-3000 LPCEU-2 || Apple Extended Keyboard II (QZERTY) || Filco MINILA FFKB68MRL/UKB
Offline monday
    • Days of Game
« Reply #15 on: Fri, 26 April 2013, 06:12:00 »
You can always mod one your self I will take some pic's of the ones I have done when the sun comes up :D
Offline Jagriff
« Reply #16 on: Fri, 26 April 2013, 08:51:25 »
Another solution (if you don't care about NKRO) is to get a usb extender (male to female) and plug that in to your computer. Then you can put the female side at an easy access point so you can plug and unplug your keyboard as you please. Not only will it solve your needs, it also protects from frequent use of the port on the keyboard which is known to cause problems (especially on Rosewills).
