Author Topic: Drop - a brower based typing game created by Notch  (Read 9296 times)
Offline BoxWithADot
« on: Mon, 29 April 2013, 06:39:25 »
http://drop.notch.net/
Pretty interesting little game, so far I can only score 150 or so haha.
Offline esoomenona
  • Gnillort?
Re: Drop - a brower based typing game created by Notch
« Reply #1 on: Mon, 29 April 2013, 09:59:29 »
How the hell did you get 150... I can't get past 41... :/ lol
edit: alright, got to 86. I guess you just eventually remembered the list of words used until you could repeat them as they came up?
« Last Edit: Mon, 29 April 2013, 10:01:36 by esoomenona »
Offline Dubsgalore
« Reply #2 on: Mon, 29 April 2013, 10:01:56 »
i got 116
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #3 on: Mon, 29 April 2013, 10:10:37 »
176 is my best, a tip is after chaing a bunch of letters together hit space, it will slow down the game for a second and give you time to read the letters.
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline esoomenona
  • Gnillort?
« Reply #4 on: Mon, 29 April 2013, 10:12:50 »
Aha! Tricks! I got to 147 without. I will try to keep chaining without hitting space. Seems more a challenge.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Mon, 29 April 2013, 10:14:47 »
Got to 260 with the space trick.
Offline ITzNybble
« Reply #6 on: Mon, 29 April 2013, 10:17:05 »
;) nice   now I am not sure if you get more points for the amount of letters or for spacing on words correctly?
Offline ITzNybble
« Reply #7 on: Mon, 29 April 2013, 10:19:13 »
245
 20231-0
Offline esoomenona
  • Gnillort?
« Reply #8 on: Mon, 29 April 2013, 10:20:15 »
It seems that if you drop enough in a chain, then space, you get up to 20 extra points. If you keep hitting space, you don't get anything, but it still slows down a bit.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Mon, 29 April 2013, 10:22:21 »
They might also be based on amount of letters in a word, but it seems roughly like this:
one - 0
two - 4
three - 8-10
four - 15
five+ - 20
Offline ITzNybble
« Reply #10 on: Mon, 29 April 2013, 10:23:47 »
one - 0
two - 4
three - 8-10
four - 15
five+ - 20
Just found a small "?" on the screen - I give you the text it holds
"drop 1.4 by markus persson 2013
press d to start playing. type blinking letter to advance. press space or enter to submit letters. bonus points if more than four letters. game gets faster. game over if letter leaves screen. typing wrong letter speeds up.
everything is real. nothing is real."
EDIT: if you want the max 20 extra points space when the string of characters at the bottom are blinking Pro top #2 :)
« Last Edit: Mon, 29 April 2013, 10:26:55 by curro123083 »
Offline esoomenona
  • Gnillort?
« Reply #11 on: Mon, 29 April 2013, 10:28:14 »
So if you string together many words before you hit space or enter, it counts as one big word.
« Reply #12 on: Mon, 29 April 2013, 10:30:50 »
Pretty fun game. 311 is my best so far.
Offline ITzNybble
« Reply #13 on: Mon, 29 April 2013, 10:36:31 »
I believe so but it seems +20 is the max,
319 now
« Last Edit: Mon, 29 April 2013, 10:41:33 by curro123083 »
Offline davkol
  •  Post Editing Timeout
« Reply #14 on: Mon, 29 April 2013, 11:30:51 »
I can't see anything but a blank page. T_T
« Reply #15 on: Mon, 29 April 2013, 11:34:05 »
Lower resolution, turn down contrast.. makes the game alot easier on the eyes.
« Reply #16 on: Mon, 29 April 2013, 11:44:15 »
198 max score.. it makes my head spin when they transform...
Offline ITzNybble
« Reply #17 on: Mon, 29 April 2013, 11:46:53 »
I am taking a break until my score is beaten...my head hurts :'(
Offline esoomenona
  • Gnillort?
« Reply #18 on: Mon, 29 April 2013, 12:08:26 »
I'm eating lunch, then I'm coming for you.
« Reply #19 on: Mon, 29 April 2013, 12:09:24 »
485 ;)
Offline esoomenona
  • Gnillort?
« Reply #20 on: Mon, 29 April 2013, 12:10:20 »
Well then... Guess I'm coming for YOU.
Offline ITzNybble
« Reply #21 on: Mon, 29 April 2013, 12:11:06 »
485 ;)
Awesome! Guess I will get back at it after lunch :)
Offline esoomenona
  • Gnillort?
« Reply #22 on: Mon, 29 April 2013, 12:43:23 »
« Reply #23 on: Mon, 29 April 2013, 12:50:32 »
It gets pretty dang hard around 400, doesn't it?
Offline esoomenona
  • Gnillort?
« Reply #24 on: Mon, 29 April 2013, 12:53:02 »
Ha, I did get a little adrenaline rush there.
Offline rainb1ood
  • so pretty so plastic
« Reply #25 on: Mon, 29 April 2013, 13:00:16 »
Nice find! Bookmarked
Offline ITzNybble
« Reply #26 on: Mon, 29 April 2013, 14:48:34 »
started back up and I cannot do it anymore :( time to put in my contacts so I can see the "e" or "c" is coming :P
Offline esoomenona
  • Gnillort?
« Reply #27 on: Mon, 29 April 2013, 14:50:14 »
This game has made me realize I have trouble typing words with w or q in them. I keep hitting one or the other when I don't mean to.
« Reply #28 on: Mon, 29 April 2013, 16:43:37 »
Me neither. Apparently it needs a plugin that is not available under Linux.
Offline BoxWithADot
« Reply #29 on: Mon, 29 April 2013, 19:06:07 »
It requires Unity web player. Idk if it's supported on Linux or not. Edit: after a quick Google search, you may be able to play it using Google Chrome. Can't test it out right now, but it may be worth a shot.
I managed 440 earlier this morning before I knew the spacebar thing. I just memorized all the words, since there aren't that many haha. I'll have to go back and play again
« Last Edit: Mon, 29 April 2013, 19:12:39 by BoxWithADot »
Offline davkol
« Reply #30 on: Tue, 30 April 2013, 12:16:28 »
I tried Chrome, without success. Well, I should be studying anyway.
Offline DamienG
    • DamienG
« Reply #31 on: Tue, 30 April 2013, 13:38:45 »
124 on first go without trying this space trick.
[)amien
Offline esoomenona
  • Gnillort?
« Reply #32 on: Tue, 30 April 2013, 13:44:24 »
So far, has anyone beat my score of 147 without pressing space at all?
edit: I just did. 201 without space.
« Reply #33 on: Tue, 30 April 2013, 13:53:49 »
I didn't use space on my 673 run or any of my others.. I found it made things harder.
Offline esoomenona
  • Gnillort?
« Reply #34 on: Tue, 30 April 2013, 14:00:33 »
