Author Topic: LED Mod  (Read 7492 times)
Offline biszarerabbit
LED Mod
« on: Mon, 29 April 2013, 21:10:52 »
So hey geekhack, I was recently considering doing a LED mod on my CMStorm QFR (blues), and was wondering if there is anything special I would need besides the LEDs themselves (also if I need a certain voltage, and of course if its even possible). I appreciate any help!
Offline Hyde
  • White Tofu Extraordinaire
Re: LED Mod
« Reply #1 on: Mon, 29 April 2013, 22:07:10 »
I asked about the same question before in here:  http://geekhack.org/index.php?topic=37266.0
There are two types of 3mm (T1 Size) LEDs:
Clear Water LED:  The bulb is clear and glass looking.  It is brighter but also more directional.  Brighter straight on but not so bright from the side.
Diffused LED:  The bulb look frosted.  It is a bit less bright but has a wider viewing angle.  Basically if you look at it from any direction it would have similar amount of brightness.
I went with diffused LED since we're doing indicator light, but I think it's personal preference.
After that you need to check the voltage.  From what I know that Red/Green/Yellow lights have same voltage.  So if you're swapping QFR's red LED to any of those color you should be safe.
However Blue/White/Purple/Pink need higher voltage.  So if you swap your red LED to any of these colors it will be dimmer since it doesn't have enough voltage.
In that case you'll have to either swap the resister or just accept that it has dimmer light, however a lot of users report that the blue light is actually too bright so running at dimmer setting is actually perfect.  However I'm also a noob in this so should double check before actually doing the mod.  :P
Offline Thechemist
Re: LED Mod
« Reply #2 on: Mon, 29 April 2013, 22:48:11 »
You can use some 3mm round wide angle leds which are 120-140° angle vs your standard round top of 20-40° angle. I am not sure about what forward voltage they are but they should have 20mA current. You can go for a brighter clear flat top or a softer diffused flat top led if you want the wide angle, if not you can go for narrower angle with a round top.
Round Top clear Led
Flat Top clear Led
Re: LED Mod
« Reply #3 on: Tue, 30 April 2013, 02:18:32 »
Hmm thanks for the help guys! Really helpful, that thread had a good link for buying LEDs too, I might have to get LEDs through them. Btw quick noob question, can you even put LEDs on a QFR? I don't think there are any connections that allow for LEDs on most of the normal switches on the PCB board...
Offline Thechemist
Re: LED Mod
« Reply #4 on: Tue, 30 April 2013, 11:38:08 »
It is cheaper to purchase the leds on Ebay, you can get 100 of the 3mm for around ~$5 shipped but it takes two weeks from china. Other sites are about $20 or more + shipping just an FYI.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: LED Mod
« Reply #5 on: Tue, 30 April 2013, 12:33:29 »
If anyone has any links to what they ordered from a vendor (not eBay), that would be most helpful.  ;D
Offline Hyde
Re: LED Mod
« Reply #6 on: Tue, 30 April 2013, 12:37:54 »
Yeah I kind of realize that after I bought mine already =_____=
I got mine from here:  http://lighthouseleds.com/
Re: LED Mod
« Reply #7 on: Tue, 30 April 2013, 12:50:57 »
So uh yeah, like i mentioned earlier... it doesnt seem theres LED solder points on each individual switch besides caps lock and such on the QFR... is there a workaround on this?
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: LED Mod
« Reply #8 on: Tue, 30 April 2013, 12:52:36 »
Drill holes and manually wire it.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Re: LED Mod
« Reply #9 on: Tue, 30 April 2013, 12:54:15 »
o_o how would I power the LEDs? Sorry I'm pretty noob :(
Offline The_Ed
Re: LED Mod
« Reply #10 on: Tue, 30 April 2013, 12:57:35 »
Split off 5v from the USB, put some resisters in there, make sure none of the wires short, and turn it on.
R.I.P.ster
Re: LED Mod
« Reply #11 on: Tue, 30 April 2013, 13:00:09 »
Also +Resistor
Offline The_Ed
Re: LED Mod
« Reply #12 on: Tue, 30 April 2013, 13:02:11 »
Also +Resistor
? I said resistors already...
R.I.P.ster
Re: LED Mod
« Reply #13 on: Tue, 30 April 2013, 13:08:28 »
Also +Resistor
right, I  was emphasizing it with a ' + '
cuz it's very important.
Re: LED Mod
« Reply #14 on: Tue, 30 April 2013, 14:01:56 »
I don't know if I can do this anymore... are there any videos on this stuff out there? I searched youtube and drew a blank on videos that would actually be helpful to me.
Offline The_Ed
Re: LED Mod
« Reply #15 on: Tue, 30 April 2013, 14:10:36 »
I remember when I used to follow 'tutorials', but then as I learned more I found out that most people who make 'tutorials' have no ****ing clue what they are doing...
If you live in MN you could just drop it off and I could do it for you. But it'll cost ya quite a bit from all the hours it would take.
R.I.P.ster
Offline Mugen
  • O-Rings are the murderers of keyboard souls
Re: LED Mod
« Reply #16 on: Tue, 30 April 2013, 21:50:42 »
What resistance would you recommend?
Offline Hyde
Re: LED Mod
« Reply #17 on: Tue, 30 April 2013, 22:41:18 »
Yeah if you plan to put LED on ALL the keys I'd say go buy a Ducky Shine II 9087 might be more cost/time effective.
But if you only gonna change LED color on caps lock and scroll lock then I say it shouldn't be too hard to figure out yourself and follow youtube tutorials.
Offline The_Ed
Re: LED Mod
« Reply #18 on: Tue, 30 April 2013, 22:53:56 »
The number of resistors and their resistence values depend on how you wire it up and what LEDs you use. Basically you just have to get the math right for your unique situation, and having a Fluke 87-V helps.
R.I.P.ster
Re: LED Mod
« Reply #19 on: Wed, 01 May 2013, 00:09:06 »
Wait..... what? the op wants to add leds to the entire board?
is he using a phantom plate ? or the original.
Offline Hyde
Re: LED Mod
« Reply #20 on: Wed, 01 May 2013, 07:30:45 »
Sounds like he want to DIY CM QFR's PCB lol.  So my recommendation is no.
Buy a Ducky would probably easier and save a lotttt of headache.  That or wait for CM to release their backlit version, it's been confirmed now just matter of when it will come out.
