Author Topic: Difference between silenced and non silenced topre?  (Read 6396 times)
Offline Schattendolch
« on: Sat, 04 May 2013, 14:48:44 »
A regular happy hacking is ~$270, and the type S is $400.
Do they feel different to type on, or is it all noise?
Offline linziyi
  • The one with many questions
Re: Difference between silenced and non silenced topre?
« Reply #1 on: Sat, 04 May 2013, 15:03:13 »
How does topre feels like in general?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
« Reply #2 on: Sat, 04 May 2013, 15:07:01 »
i have a 55g 87u, but debating an hhkb too
Offline Korbin
« Reply #3 on: Sat, 04 May 2013, 17:16:02 »
I have a realforce (87U) and a silenced version of the the same board. They feel EXACTLY the same when typing on them. Literally the only difference is the "thock" sound has been muted. It would be like typing on a regular 87U while someone sticks their fingers in your ears :P
Keyboards: Nyquist, Ergodox, Levinson
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Sat, 04 May 2013, 17:22:57 »
So you're telling me ear plugs can save me $130?  :eek:
Lol jokes aside the real difference is that they added silicon bands to dampen sound from upstroke.  Similar concept to o-ring but o-ring is for downstroke.
« Last Edit: Sat, 04 May 2013, 17:25:03 by Hyde »
« Reply #5 on: Sat, 04 May 2013, 17:25:16 »
it's still just as loud, just less attack
Offline khaangaaroo
« Reply #6 on: Sat, 04 May 2013, 18:15:17 »
You might want to take another listen. The "thock" sound on the downstroke is unchanged because the plunger, rubber dome, spring, and PCB underneath the key are all the same between the two versions. The "clack" on the upstroke from when the plunger hits the top of the switch housing is what is muted.
They're actually foam pads.
Offline khaangaaroo
« Reply #7 on: Sat, 04 May 2013, 18:43:20 »
I don't think they feel any different on 45g and 55g Topre. Only 30g is light enough that I can feel the foam pads while lifting my fingers during normal typing. The heavier weights just reset the keys too fast to make any noticeable difference in feel, so it's just noise reduction.
Offline Macsmasher
« Reply #8 on: Sat, 04 May 2013, 20:56:37 »
I have a five month old 87U variable silent, a one month old HHKB Pro 2 (non-silent) 45g uniform, and a two week old 87U 55g uniform. I can't comment on the feel between the variable silent and variable standard because I don't own both.
The key travel is the same for silent and non-silent switches, which means they've engineered the switch housing to accommodate the silencing material. The silent switches can be identified by their purple switch housing. Reference here for switch pictures and more info: http://deskthority.net/wiki/Topre_switch
I thoroughly enjoy all three keyboards. These are my 'personal' preferences and observations. I emphasize personal preferences because they are completely subjective. Somebody else will have other preferences and neither is wrong. It's like asking which color car is better.
87U variable silent:
Reference here for the key weighting: http://i.imgur.com/X6g6Y.jpg. Pinky keys are 30g for the US version. It's interesting to note that the modifier keys are 45g, not 30g. The 87U variable takes some getting used to because it's so light. That's not necessarily a bad thing. But it took me about a week to adjust coming from MX browns. I kept bottoming out too hard. But once I modified my typing style, it was effortless to type on. And yes, it is extremely quiet. I can be on the phone with clients taking notes and they can't hear me typing, which was what I was looking for. If I had a complaint, I'd say the switches are on the light side when typing fast. If you're taking your time, it's great. If you're pushing for speed, they're a bit light.
HHKB Pro 2 non-silent:
I love and hate the layout, all at the same time. The idea of a compact is that you can type everything without your hands leaving home row. If I dedicated a lot of time to getting the layout down, I think I could actually work faster for this reason. But I struggle with the arrow keys being on the second layer, and as a coder, I rely on my arrow keys constantly. I do like the 45g switches. However, understand that Topre switches have a break-in period. I'd say at least two weeks as your daily driver before they settle in to their 'final' key weight. This is important to remember.
The switches are PCB mounted on the HHKB, which does change the feel of the Topre switch. Some prefer the key feel on the HHKB because of this. Personally, I'll take a plate mounted Topre board over PCB mounted any day. Do I want to get rid of my HHKB? Not at all! It's a nice change and a joy to use, especially for relaxing and banging out some emails.
EDIT: I've been corrected. The HHKB Topre switches are not PCB mounted. The upper housing that holds the switches is molded as one piece. Daerid used the term "case-mounted", which seems to be the most accurate term.
87U 55g uniform:
I never would've considered this board had it not been for the guys on GH preaching the 55g gospel. But, I had the extra money, so I ordered one, primarily out of curiosity. I figured I could sell it on GH for a minimal loss if I didn't like it.
Three days into using it, I almost put it up for sale. It was too stiff for my taste. But, understanding the Topre break-in, I decided to stick it out. I'm glad I did. It's been my daily driver for two weeks now, and the keys have lightened up to what I consider perfect. I know it's not increased finger strength because I can switch back to my variable without problem. The key weighting on the 55g lightened up to a larger degree than the other Topre switches.
I am extremely happy with all three keyboards. But if I could only choose one, it would be the 87U 55g uniform.
Don't let all this frustrate you. Any of these Topre boards are so far above anything Cherry MX, it's almost laughable. Regardless of which you choose, you'll be happy with it.
« Last Edit: Sun, 05 May 2013, 02:46:15 by Macsmasher »
