Ah... LOL...
I know exactly the problem
The keycap is miss-molded where the prongs are not straight..
Now either the problem is "left-right" or "front-back"..
Find a horizontal surface surface, put the stabilizers on the keycap and the cap w/ stabilizers touching said surface..
look at it closely at it sideways to determine in "which orientation / or both" that the stabilizers are tilting..
For left-right... you can fix that easily by putting a paper ring 2 "sheets thick" YES it can make all the difference.. on the side that is too LOW..
If it is Front-back misalignment.. then you'll need to mod the stabilizer slightly so that it correctly orients.
It could also be that the switch is Not properly mounted on the board.. Desolder, and resolder while pressing down on the switch to make sure it gets "in-there-good"
