Author Topic: Stabilizers on the Corsair K70?  (Read 20396 times)
Offline deazncy
« on: Sat, 11 May 2013, 18:27:53 »
Hey guys, I've been eyeing the K70 for a while now because it's such a nice looking kb, but I was wondering what kind of stabilizers it had. Also, I've read that although the keyboard is light, quality wasn't affected. Is there anybody with this kb that can give a review or tell me whether it's a good purchase or not? Thanks.
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Re: Stabilizers on the Corsair K70?
« Reply #1 on: Sat, 11 May 2013, 18:40:56 »
It's Costar stabilizers.
As for whether or not it's a good purchase, it's not a bad keyboard from what I've seen, I just wouldn't drop $130 on it.
Offline deazncy
« Reply #2 on: Sat, 11 May 2013, 20:58:06 »
Thanks.
But I still have a bit of money on my newegg gift card, so I won't be paying full price.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Sat, 11 May 2013, 23:12:15 »
I remember K60 and K90 were using Cherry stabilizers, did they switch over to Costar for K70?
« Reply #4 on: Sat, 11 May 2013, 23:53:00 »
I could be wrong, but I seem to remember it being stated that they use Costar stabilizers.
Offline deazncy
« Reply #5 on: Sun, 12 May 2013, 00:38:32 »
Darn, I want to make sure that it uses Costar stabs. I really dislike the Cherry ones.
Offline Hyde
« Reply #6 on: Sun, 12 May 2013, 00:44:55 »
Mmmmmm next time I swing by a computer shop I'll pop one open from the display demo and let you guys know  :P
I did that on the K60 and K90 that's how I know it had Cherry stabilizers.  But I have a feeling it might be the same on the K70  >____>
Offline gnubag
« Reply #7 on: Sun, 12 May 2013, 00:55:52 »
well it seems like they have cherry stabs.
I just finished replacing all the larger keys (enter, shift, space), and I found out that Corsair is AWESOME, they did away with the stabilizer bars. So, in order to pop these keys off, you just center the key remover and pull. No need to fuss around with the steel bar that's under other cherry red keyboards. +1 for Corsair for easy key cap replacement.
Source: http://www.amazon.com/Corsair-Vengeance-Mechanical-Gaming-Keyboard/dp/B00CD1FC6G
Offline deazncy
« Reply #8 on: Sun, 12 May 2013, 01:45:05 »
Yup, looks like it comes with Cherry stabs. Have a look:
https://imageshack.us/scaled/large/42/entershiftstabilizers.jpg
https://imageshack.us/scaled/large/560/spacestabilizers.jpg
Sucks, I wish they came with Costars :\
Offline Hyde
« Reply #9 on: Sun, 12 May 2013, 11:33:26 »
LOL it come with 3 LED for spacebar?  So serious lol but I guess it's to give an even under light I think.
But yeah I also wish it came with Costar stabilizers, hard to find a good backlit keyboard with Costar stabilizers.  Max Keyboard is the closest I can think of.
Otherwise I think Ducky is probably the best Cherry stabilized backlit keyboard.
« Last Edit: Sun, 12 May 2013, 11:35:20 by Hyde »
Offline deazncy
« Reply #10 on: Sun, 12 May 2013, 12:46:21 »
I completely agree with you. But I actually came from a Ducky myself, but switched to Max for the stabs. But the thing I found out was that I didn't really like how the Nighthawk attracted so much dust and mine had a bit of pinging which was quite noticeable. When I found out about the Cherry stabs clip mod, and saw how nice the k70 looked (no bad reviews/experiences yet either), I decided that I'd go for it.
Offline Hyde
« Reply #11 on: Sun, 12 May 2013, 16:51:50 »
I read up about that mod before too, but to my understanding that it's only easy to do on a PCB mount Cherry stabilizer.  To do the same mod on plate mounted Cherry stabilizer you'd have to desolder all the switches and remove the backplate to do it.
So in the end I figure that sounds like too much trouble.  But then again I've never owned any Cherry stabilized keyboards so let me know if I'm wrong.
« Reply #12 on: Sun, 12 May 2013, 21:20:29 »
No, you only need to desolder the stabilized switch to make room for the metal bar to come out. through the hole. Cherry stabilisers are snapped to the plate just like Costar stabilisers.
Offline deazncy
« Reply #13 on: Sun, 12 May 2013, 21:51:05 »
There is a video where somebody installs a cherry stabilizer without desoldering. Could the stabilizer also be removed without desoldering?
« Reply #14 on: Mon, 13 May 2013, 08:22:26 »
I doubt it. There is so very little room in there.
The space bar on that keyboard (I suppose that it is a Phantom) is a bit of a special case, because you have access to it from the side.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #15 on: Mon, 13 May 2013, 08:36:10 »
I couldn't stand the Cherry stabilizers on my Leopold so I completely removed the Cherry Stabs (including the stablizer bars) with nothing but a pair of wire cutters, a pair of needle-nosed pliers and absolutely no desoldering. Remove the plate&pcb assembly, cut off as much of the short 90-degree angle on the stabs that you can (both ends) and fish for the remainders with the n-n pliers. Shake and repeat. Greatly improved the feel of my Leopold (but I'm still ditching it for a Filco MJ2 TK+ w/ blues.). I never replaced the stabilizers at all (although I tried and failed to put costar stabs on it). Honestly, I never even notice their absence.
Topre REALFORCE
Offline raisinbun
« Reply #16 on: Sat, 18 May 2013, 14:34:56 »
It may have cherry stabilizer but IMO it is almost as responsive as costar ones.
« Reply #17 on: Sat, 18 May 2013, 15:55:13 »
responsive? how.. wha?
the only difference is a bit of extra mushiness when you press the key down all the way,  costar stabs are less prone to mushiness, as it is less sensitive to misalignment.
Cherry stabs are very sensitive to misalignment.
Offline Rule16
  • R.I.P. SmallFry
« Reply #18 on: Sun, 19 May 2013, 00:08:35 »
Its k guise u kan still sprint az fazt az u rubberdome XD
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
