Author Topic: Anywhere to try greens?  (Read 2346 times)
Offline lightsout714
« on: Sat, 18 May 2013, 14:43:18 »
I love blues, greens seem a lot more prevalent these days. Anyone seen any in a store etc. to try? Went to my local frys (fountain valley, ca) but they did not have any.
I didn't like clears so much when I had them. Whatever that is worth.
Re: Anywhere to try greens?
« Reply #1 on: Sat, 18 May 2013, 14:47:34 »
I'm starting a tour that will have switches including a Ghetto Green. You can find more info here. Otherwise, the only store front I've ever seen MX Greens in was MechanicalKeyboards.com. If you have a MicroCenter near you, maybe you can try there?
« Reply #2 on: Sat, 18 May 2013, 14:58:44 »
Thanks man I was actually in a MC yesterday picking up a QFR. They didn't have anything out. Your tour sounds pretty cool thanks. I didn't know MK.com had a storefront that is pretty sweet!
« Reply #3 on: Sat, 18 May 2013, 15:06:20 »
If you wanna see some pics and read about the MK.com storefront, check out my Wiki in my signature. I met up with Mashby there and checked it out. It was really cool :D
And you can always ask the guys at MC to just open boxes up to try stuff. That's what I do whenever I go. ^__^
Offline Johan
« Reply #4 on: Sat, 18 May 2013, 15:12:35 »
You could get a CM keyboard with greens, or are you looking for something like the Wasdkeyboards sample pack.
Uh, stuff.
« Reply #5 on: Sat, 18 May 2013, 15:33:13 »
I'm aware of the board from CM. Thats the one I would buy if I was going to get one. Just wanted to check them out first. But this is more informational than anything I just bought a keyboard yesterday and money is tight. Thanks for the info on the WASD sampler. Thats pretty cool.
Sweet I'll check it out now. Never thought to ask them to open a box. They're cool with that? Or do you end up buying the item afterwards?
« Reply #6 on: Sat, 18 May 2013, 15:35:16 »
Nope, they just let you play with the stuff. They might watch over you to make sure you're not stealing stuff but I've never actually bought anything from MC. I did get to try various boards with Blues, Reds, Browns, Blacks, and Clicky White Alps this way though. I also discovered I don't care for the QFR's rubber coating at all. So it worked out great :D
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #7 on: Sat, 18 May 2013, 15:41:47 »
send me a pm with your address and i shall send you a handful of greens to play with good sir
« Reply #8 on: Sat, 18 May 2013, 16:03:08 »
Try blue... but imagine a "less sharp/ lower frequency" click sound, and almost twice as heavy.
it's still a distinct click, but not as "bright"
« Reply #9 on: Sat, 18 May 2013, 16:43:14 »
For real? Will do. Awesome!
Offline Rule16
  • R.I.P. SmallFry
« Reply #10 on: Sat, 18 May 2013, 17:32:39 »
Don't imagine anything, just get a WASD sampler kit and put a black spring w/ a blue stem. Then you got yourself a ghetto green to try for $9.99 (Didn't these used to be $5?)
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
