Author Topic: apple juice....  (Read 2453 times)
Offline attackcow
apple juice....
« on: Sat, 25 May 2013, 22:45:24 »
Alright well long story short I spillt some apple juice over my KBT Pure (I really want to cut my dumb ****ing hand off for doing this) but it's all good now. Works perfectly now after letting it dry out for a day, but there's one small problem (which you probably can already guess what it is.)
I have a couple of keys that are now sticky :( It's the L-Ctrl and L-Windows key that are sticky and don't press down and come back up as fast and cleanly as the rest of the keyboard. It's especially jarring when copying and pasting and selecting all text in a box :(
What can I do to solve this problem? I know it's something to do with the switches themselves and I don't have any compressed air with me right now. I've heard of just drenching the thing in alcohol or something but I don't have pure alcohol with me either LOL.
What can I do?
Online tp4tissue
Re: apple juice....
« Reply #1 on: Sat, 25 May 2013, 22:49:10 »
well, since it's a pure, just open the switch and rinse it out with alcohol.
do it with the board upside down. :D
Offline attackcow
Re: apple juice....
« Reply #2 on: Sat, 25 May 2013, 23:01:13 »
Open the switch? You can do that? :O
Offline orlando
Re: apple juice....
« Reply #3 on: Sat, 25 May 2013, 23:05:33 »
With a fork ;D Might have to remove the leds first though.
Offline attackcow
Re: apple juice....
« Reply #4 on: Sat, 25 May 2013, 23:14:58 »
I don't have any LED's on mine except for the Caps-Lock keys :D No need for LEDs when I've already been touch typing for years and years :)
But this sounds like an easy enough fix! Thanks guys. Much appreciated.
Offline grips
Re: apple juice....
« Reply #5 on: Sat, 25 May 2013, 23:33:40 »
I came across this video today... Maybe it will help you, or maybe not :) I'm still new to this stuff.
Online tp4tissue
Re: apple juice....
« Reply #6 on: Sat, 25 May 2013, 23:34:38 »
Ah... no don't do it like that... Make the korean clips.
http://deskthority.net/workshop-f7/i-did-a-guide-of-how-to-open-cherry-switches-t2458.html#p43053
You need pliers
It's better if you have an anvil and rubber top hammers.. but... pliers will do.  :D
Offline grips
Re: apple juice....
« Reply #7 on: Sat, 25 May 2013, 23:37:21 »
Well, there you go. Don't listen to me :)
Online tp4tissue
Re: apple juice....
« Reply #8 on: Sat, 25 May 2013, 23:38:14 »
no disrespect... just saying, the way it's done in that other video, is dangerous, because you can crack the housing that way.
Offline grips
Re: apple juice....
« Reply #9 on: Sat, 25 May 2013, 23:47:07 »
No worries. That link you provided was good for me also. Got it bookmarked now :)
Offline Rule16
  • R.I.P. SmallFry
Re: apple juice....
« Reply #10 on: Sun, 26 May 2013, 00:59:31 »
Speaking of taking switches apart how do you take apart an Alps switch?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
