Author Topic: Is this worth buying?  (Read 4480 times)
Offline DrinkTea
« on: Sun, 26 May 2013, 16:33:22 »
I'm relatively new to mechanical keyboards and I want to try a board with clear switches. Ideally something tenkeyless.
I came across this:
http://www.ebay.com/itm/Leopold-FC660M-Mechanical-keyboard-Cherry-MX-clear-switches-W-Black-body-/300910289761?pt=PCA_Mice_Trackballs&hash=item460fa6a361
It seems a bit expensive. But is that just the price that boards with clears go for? Or should I wait and see if anything new comes out in the next few months?
Offline jabar
Re: Is this worth buying?
« Reply #1 on: Sun, 26 May 2013, 16:35:16 »
qtan has a web store which is cheaper than his eBay listings:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/leopold-fc660m-mechanical-keyb/lid=35177400
If any store stateside offers the FC660M, it would be EliteKeyboards. However they have yet to even import the FC700R which has been available for almost a year now.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Sun, 26 May 2013, 16:43:19 »
What? qtan has FC660M with clears? DO WANT!
(Thanks for the link.)
Offline DrinkTea
« Reply #3 on: Sun, 26 May 2013, 16:44:46 »
Yeah, I saw his webstore too. But even that's a bit pricey. But if clears aren't going to get any cheaper, I guess I'll just go for it. Or is it because of the brand? Is Leopold particularly good. And if so, what qualities make them good? Sorry for all the questions, but I appreciate the help.
Offline davkol
« Reply #4 on: Sun, 26 May 2013, 16:50:59 »
Cherry G80-3000LQCEU and such are much cheaper. Otherwise, you have to focus on mostly limited editions of Ducky, Leopold, Keycool, CM Storm QF etc. keyboards. These definitely aren't bad quality-wise.
Offline DrinkTea
« Reply #5 on: Sun, 26 May 2013, 17:01:36 »
Thanks for the tip on the other board. Just looking around, it doesn't seem easily available, and even when it is, not THAT much cheaper than the Leopold. And it's full size, which I guess can be a good or a bad thing. Looks like no matter what there's not going to be anything with clears at less than about 100USD. And from a build quality point of view, it sounds like the Leopold is the best I'm going to get for now. Although I heard CoolerMaster is coming out with a board with clears soon. Any ETA on that? So that might be cheaper and of similar quality. Would it be best to wait?
Offline kelske
  • The North Borders
« Reply #6 on: Sun, 26 May 2013, 17:05:36 »
Cool! I wonder how the build quality compares to the 660C, which is excellent.
WASDv2 is supposedly coming in Clears too, if you prefer TKL
« Reply #7 on: Sun, 26 May 2013, 17:08:32 »
ah question.. the spacebar is "special" on these boards or is it compatible with our "sets" ?
And is this plate mounted or PCB mounted?
If plate, it probably doesn't have the ez-access for ergo-clear mod right?
Clear is quite terrible without lube and spring mod, so, I wouldn't ever buy a clear plate mounted board, because of that extra desoldering step.
Offline DrinkTea
« Reply #8 on: Sun, 26 May 2013, 17:18:05 »
What do you find terrible about clears? I heard they were like browns but heavier and more tactile. So I wanted to try them since I find the browns too light and a bit mushy feeling. I guess it all comes down to personal preference. So if anyone out there has clears they don't want, I'd love to try them!
« Reply #9 on: Sun, 26 May 2013, 17:24:24 »
mm.. ok.. let's not call it terrible..  it's a preference..
I didn't like stock clears because it felt very heavy and effort-ful to type on.   With the lube, I can accept the 80g spring weight. but over time, I began to miss the low force of MX blues, so I decided on ergo.
Offline PointyFox
« Reply #10 on: Sun, 26 May 2013, 17:33:44 »
The more I use heavy keys, the heavier I want them :P
Offline davkol
« Reply #11 on: Sun, 26 May 2013, 17:36:33 »
German Amazon/eBay, price around 55 EUR. If you're in the US, situation might be different. The good (well, YMMV) thing about Cherry G80 is that it's usually PCB-mounted, so it's easy to mess around with switches.
Offline jabar
« Reply #12 on: Sun, 26 May 2013, 18:46:48 »
Clears for me are right on the fatiguing boundary for me. Browns/Blues/Reds I can game with forever, Clears I need to take breaks (Blacks more often) and Green wear my hands out within 10 minutes.
Phantom 7bit
Offline knotra
  • I ญญญ♥ ⌂ ♫
« Reply #13 on: Sun, 26 May 2013, 20:30:30 »
$100 to $150 is pretty standard for a mechanical keyboard especially for a clear switch board which are relatively rare. That's actually a pretty good price. Leopold is a great brand, in fact I just bought a Leopold the other day, but it isn't necessarily considered the best of the best like Filco and Ducky are.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline DrinkTea
« Reply #14 on: Sun, 26 May 2013, 20:39:08 »
I think my hesitation here is more that it's so small for that price. If it were full size (which I'm not looking for anyway) or even standard tenkeyless, I'd probably be ok with it. But I guess I'm comparing it in my head to the board of similar size with white switches I ordered and is similarly priced but with function keys. And then the tenkeyless with greens, which is a bit less...
However, realistically, I'm not going to save more than $50 if I wait for the coolermater with clears to come out this summer, right?
Although that might be a little bigger and I'm considering getting something tiny anyway to carry around with a laptop.  Does anyone do that? And if I do wait, how does Leopold compare in quality to CoolerMaster?
Offline davkol
« Reply #15 on: Sun, 26 May 2013, 23:16:25 »
Leopold has better keycaps out of the box and Cherry stabilizers (while most CM Storm keyboards are Costar). I'd say they should be more or less on par in therms of quality.
Offline elttaboi
« Reply #16 on: Mon, 27 May 2013, 01:39:34 »
That's a good keyboard if you like small layouts. I wouldn't go for clears myself since they are pretty heavy and I have delicate fingers. :P
Offline therecorder
« Reply #17 on: Wed, 29 May 2013, 08:33:54 »
A few weeks ago, I bought an FC660M with Blues.  I was so impressed with it that I ordered one with Clears (from Qtang).  It's just as impressive as the one with Blues.  The Clears are a limited production board.  If I were you, I'd buy one with Clears.  If it's not for you, I'm sure that you'll eventually be able to sell it for little loss.  (And, yes the quality is every bit as good as the FC660C...  And, yes I also have one of them.  And, yes I've been on a bit of a spending spree.)
Offline kelske
  • The North Borders
« Reply #18 on: Wed, 29 May 2013, 16:31:20 »
Cool thanks for confirming the build quality! Tempting.. I'd need to learn how to solder
Offline DrinkTea
« Reply #19 on: Wed, 29 May 2013, 17:52:49 »
Thanks indeed. Well, it's now a serious consideration. The question is, should I get this, wait for the CoolerMaster clear board or just get both and maybe sell one.
Offline davkol
« Reply #20 on: Thu, 30 May 2013, 03:29:44 »
Have you considered possible preference for stabilizers?
Offline DrinkTea
« Reply #21 on: Thu, 30 May 2013, 11:52:33 »
Unfortunately, I don't know enough about that. But after reading what people wrote here, I went ahead and ordered it. So I guess I'll see how it is soon. He shipped it so fast!
Offline therecorder
« Reply #22 on: Thu, 30 May 2013, 11:56:31 »
Let us know how you like it (or not).
Offline Metr0
  • HHKB or nuttin
« Reply #23 on: Fri, 31 May 2013, 07:00:17 »
Does anyone now the size of the space bar or the right shift on this thing? Will it take traditional ANSI layout keys?
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline therecorder
« Reply #24 on: Fri, 31 May 2013, 07:15:35 »
Think the spacebar is 4 3/4 inches, and the shift keys "are" equal size...  These sizes are not standard.  And, the height of all the keycaps is not standard.  But, you should read this thread:
http://geekhack.org/index.php?topic=43807.0
« Last Edit: Fri, 31 May 2013, 23:29:19 by therecorder »
Offline Metr0
  • HHKB or nuttin
« Reply #25 on: Fri, 31 May 2013, 08:01:32 »
Think the spacebar is 4 3/4 inches, and the spacebars "are" equal size...  These sizes are not standard.  And, the height of all the keycaps is not standard.  But, you should read this thread:
They always make it difficult! :rolleyes: Thanks for the info anyway, I'll keep an eye on qtan's Vendio store in the coming days.
Offline Schattendolch
« Reply #26 on: Fri, 31 May 2013, 23:22:15 »
looks like a good value to me.
cherry clears are hard to come buy, and leopolds are good boards.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #27 on: Fri, 31 May 2013, 23:48:30 »
One option if you just want to try clears is POS boards.  Some of those old Data911 boards and a lot of G80-8133 and 8200 boards show up used with Clear switches.  The issue is that they're often used and dirty.
Overton130, Box Pale Blues.
Offline DrinkTea
« Reply #28 on: Wed, 05 June 2013, 19:12:20 »
Well, it arrived today, and it's great. I like the feel of the clears. This is what brown should be. I even like the sound. It's not clicky but I enjoy the muted, uh, "thockiness" that it has. I also like the size.
Also it just feels more solid and high quality than the other crap I have. I've got two rosewill keyboards, one with blues and one with browns as well as a KBT Race with whites. Might just get rid of the Rosewills for someone to mod or harvest switches now.
Offline therecorder
« Reply #29 on: Wed, 05 June 2013, 22:05:16 »
Really great that you're happy with your new purchase.  Enjoy your "thockness".
