Author Topic: O-ring for Thick pbt Cherry profile  (Read 5181 times)
« on: Fri, 31 May 2013, 20:56:44 »
So, does any one know rings that are thin enough to fit..
How bout those "thin" 40a red ones on WASDkeyboard..
Anyone try them?
Offline Polymer
Re: O-ring for Thick pbt Cherry profile
« Reply #1 on: Fri, 31 May 2013, 21:20:25 »
The thinner red ones will be fine.  The blue/black ones I think reduce the travel too much..but some people may like it like that...
« Reply #2 on: Fri, 31 May 2013, 21:41:50 »
you've tried them? do you have calipers? could you take the thickness?
Offline UniClown
« Reply #3 on: Fri, 31 May 2013, 23:26:54 »
From the WASD website, it says that red O-rings are .2mm and blue/black are .4mm. I have a sampler kit and I prefer the reds the best.
Offline quake4mhg
« Reply #4 on: Sat, 01 June 2013, 00:07:39 »
Either one is fine. When I put 2, even thinner than WASD, keycap pops up when I spam too hard  :p
Offline khaangaaroo
« Reply #5 on: Sat, 01 June 2013, 00:32:04 »
I have some WASD o-rings and calipers. 1.4mm for red, and 1.8mm for blue and black.
Keep in mind that's thickness. Travel reduction is less than that because the o-rings are round and the keys don't land perfectly on the vertical diameter.
Offline WhiteFireDragon
    • youtube
« Reply #6 on: Sat, 01 June 2013, 00:49:51 »
Here's what I had in the past. The WASD thicker ones are the "A" size, the thinner ones are "H". The ones you'd want for imsto's thick PBT caps is the "D" size. I found these are the thinnest you can have them while still being effective as O-rings. If you put these on normal stock caps, then do nothing because they're too thin to even hit the bottom. On the imsto caps, if you use any size other than "D", you get a significant reduction in travel distance.
The "D" size is 1mm thick.
Offline Photoelectric
« Reply #7 on: Sat, 01 June 2013, 00:55:32 »
Which of these are IMSTO's silicone o-rings?  I'm guessing the thickest red and the second thickest?  Not sure where to find D. (Will look for your original post).
« Reply #9 on: Sat, 01 June 2013, 01:22:12 »
Thanks for the caliping khaanga :D
Offline berserkfan
« Reply #10 on: Sat, 01 June 2013, 05:07:44 »
anyone knows where to get cheap orings? Amazon sells them but only blacks.
« Reply #11 on: Sat, 01 June 2013, 09:09:20 »
Unfortunately, almost all non-keyboard O-rings are for industrial purposes and are much harder than what we want.
- Franklin Roosevelt 1933
Offline davkol
  •  Post Editing Timeout
« Reply #12 on: Sat, 01 June 2013, 10:09:08 »
Actually, it depends. I don't like them (linear Cherry MX + Cherry DS). Technically, it would be possible to use even the black o-rings, though.
Offline davkol
« Reply #13 on: Sat, 01 June 2013, 10:12:49 »
70A o-rings exist, but they're usually either too big, or too small. I wouldn't mind very thin, this hard ones only to slightly dampen the sound. I don't want reduced key travel.
Offline tns
« Reply #14 on: Sat, 01 June 2013, 11:47:12 »
oh :o can we have a scissor feeling with a lot of them :o ????
« Reply #16 on: Sat, 01 June 2013, 11:52:25 »
I got some of imsto's but haven't tried them yet.
I think WASD are ~$18 they have them on their site and ebay
also I've seen a few set go recently in the classifieds here
Offline tns
« Reply #17 on: Sat, 01 June 2013, 12:05:29 »
what?
short travel distance like scissors switches :o ? Could it be?
« Reply #18 on: Sat, 01 June 2013, 12:19:08 »
what?
Oh.. yea, of it's possible..
On my oem profile pbt, I was rocking 2mm silicone ghetto-rings, which reduced travel by 1.3mm or so. 2.7mm travel is close to the lenovo scissors
It won't be like the new Apple scissor which honestly feel like 1mm travel.
The only issue is thick pbt because it's cherry profile, so there's not a great deal of room for the orings..
