Author Topic: What about a keyboard with lasers and a sound?  (Read 3226 times)
Offline fateswarm
« on: Sat, 01 June 2013, 08:39:30 »
It's a board with gaps where the keys are and you slide your fingers in them in a non-corporeal manner. You basically deal with no forces at all and the feedback is perfect synchronicity of the laser with audio feedback.
Re: What about a keyboard with lasers and a sound?
« Reply #1 on: Sat, 01 June 2013, 09:07:23 »
what you mean like a touch screen which we already have?
Offline Rule16
  • R.I.P. SmallFry
« Reply #2 on: Sat, 01 June 2013, 11:44:11 »
You mean this?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Latin00032
« Reply #4 on: Sat, 01 June 2013, 13:04:19 »
I prefer sharks with frickin' last beans attached to their heads.
Offline fateswarm
« Reply #5 on: Sat, 01 June 2013, 14:37:00 »
You mean this?
The keys should be on 'air', no touching anything. The feedback should come only from audio or/and screen.
Offline daerid
    • Rossipedia
« Reply #6 on: Sat, 01 June 2013, 14:39:22 »
I originally was going to post "you mean laser beams" but then I thought: "last beans" is so much better.
Offline Rule16
  • R.I.P. SmallFry
« Reply #7 on: Mon, 03 June 2013, 13:14:27 »
You mean this?
I'm pretty sure what you're wanting is impossible to make at this time.
Dvorak Only Zone
Offline fateswarm
« Reply #8 on: Mon, 03 June 2013, 13:33:53 »
You mean this?
There must be a way to cut off light so that if it doesn't pass it registers a stroke.
Offline McWilloughby
« Reply #9 on: Mon, 03 June 2013, 14:05:55 »
You mean this?
Yeah but the technology to have the laser beam "stop" in the air doesn't exist. You could focus the beam to a point in the air in front of you but without anything for the beam to focus on to you would just end up with an unfocused image somewhere behind that point.
Basically from what you're saying I assume you mean a hologram keyboard. Projected holograms are currently a pretty basic technology (you can do it with a tank filled with a semi-opaque gas, basically like smoke, and I seem to remember seeing one with a clear liquid) and we're a long way off the point where it'll be possible to construct a keyboard based on this.
Detecting the strokes isn't the issue, projecting the keyboard into air is.
Offline Rayne
  • For Science!
« Reply #10 on: Mon, 03 June 2013, 14:09:34 »
if there was, we would have light sabers by now...
Offline fateswarm
« Reply #11 on: Mon, 03 June 2013, 15:28:41 »
You mean this?
The board has gaps. It's in the OP. The receptors are there for each key plus a laser source for each.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Mon, 03 June 2013, 15:34:49 »
Hmn, I wonder you could adapt a laser theremin for typing? If so, problem solved.
Offline fateswarm
« Reply #13 on: Mon, 03 June 2013, 15:42:27 »
I'm surprised it's 2013 and we still don't have hovering-hands-and-fingers input devices with delicate finger gestures.
I said delicate finger gestures, get Wii out of your head.
« Reply #14 on: Mon, 03 June 2013, 15:54:21 »
Well, skip the lasers part and you have instrument played with air since the late 1920's.
I suppose with some work you could adapt this into an input device.
Only more recently have lasers been used for this type of instrument, mostly as entertainment factor for live performance I guess.
« Last Edit: Mon, 03 June 2013, 16:00:02 by IvanIvanovich »
Offline davkol
  •  Post Editing Timeout
« Reply #15 on: Mon, 03 June 2013, 16:01:10 »
That's one of the worst ideas ever, and people who are serious about user interfaces have cursed creators of Minority Report numerous times because of this. Let me find some articles now... Yeah, the most recent one that I'm aware of: here we go.
« Last Edit: Mon, 03 June 2013, 16:04:19 by davkol »
Offline fateswarm
« Reply #16 on: Mon, 03 June 2013, 16:17:20 »
> Implying I said anything about full size hover screens and all kinds of other irrelevant science fiction things
