Author Topic: Neo KB-87 ii  (Read 2964 times)
Offline Metr0
  • HHKB or nuttin
Neo KB-87 ii
« on: Sun, 02 June 2013, 06:28:15 »
Hey guys I'm looking to buy an Neo KB-87 ii, just wondering if anyone has had any experience with this board would like to give me a little feed back. Also it only comes with MX Cherry Black switches which are a little to heavy for me, is there a way I could possibly switch them over without soldering (I have little to no experience with soldering) to MX reds for instance?
Thanks, Metr0
[WTB] BLANK PINK HHKB ARROW CLUSTER
Re: Neo KB-87 ii
« Reply #1 on: Sun, 02 June 2013, 06:44:52 »
A quick glance at the picture leads me to believe that this board is plate mounted. You'll need to solder/desolder the switches in order to swap the Blacks out.
I've also never heard of this brand or seen this board until this post. So unfortunately, I cannot offer an opinion one way or another.
Offline Metr0
  • HHKB or nuttin
Re: Neo KB-87 ii
« Reply #3 on: Sun, 02 June 2013, 06:57:09 »
Upon further trundling I found this http://imgur.com/a/FSQJG it seems to me he has swapped the switches out here without desoldering? Possibly just a change of stems and springs?
Re: Neo KB-87 ii
« Reply #4 on: Sun, 02 June 2013, 07:17:50 »
It isn't plate mounted. It's PCB mounted. So yes you can open up switches without desoldering.
Offline Human
Re: Neo KB-87 ii
« Reply #5 on: Sun, 02 June 2013, 08:32:23 »
Got 2nd generation already?
BTW, the 1st gen is indeed a PCB mounted board.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Neo KB-87 ii
« Reply #6 on: Sun, 02 June 2013, 11:24:35 »
As far as I know the only real difference in II version is improved wireless function. Back when first one came out it had generally favorable review except for the wireless functions. It is I think still only PCB mount tenkeyless keyboard available. It comes with nice quality POM Cherry profile keycaps as stock. If I was looking to buy a tenkeyless I would definitely go for one of these.
Offline Metr0
  • HHKB or nuttin
Re: Neo KB-87 ii
« Reply #7 on: Sun, 02 June 2013, 13:32:37 »
That's great. Contacted the supplier earlier, said he would be able to ship one with MX Cherry Red switches. Thanks for all the help guys :D
