Author Topic: Post your Dox layout  (Read 3801 times)
« on: Sun, 09 June 2013, 07:53:26 »
Print screen it.
It'd be nice if you include a description of the Particularly Unusual stuff :D
Online Findecanor
Re: Post your Dox layout
« Reply #1 on: Sun, 09 June 2013, 15:20:42 »
Aw, crap.. my layout is not available in Massdrop's Configurator, maybe something went wrong when trying to save. Anyway... the highlights:
* Modifiers and Space on thumb keys: Left: Shift, Fn, Ctrl. Right: Space, Alt Gr, Ctrl. (inspired by µTron]
* Enter, Tab, Del and Backspace on the inner index-finger keys. (again, inspired by µTron)
* Arrow symbols on Fn-IJKL, with PgUp/PgDn/Home/End in positions around the arrows as on a numpad.
* Key to the left of 6 is "Num Lock". It changes the right side to a numeric keypad, and the left side to a half-keyboard where Fn makes it have the right keyboard's symbols. This is mostly an experiment.
In total, four layers: Default, Fn, Num Lock, Num Lock+Fn. Oh, it is also Swedish layout, which is why I have Alt Gr: Alt is not used.
« Last Edit: Sun, 09 June 2013, 15:23:58 by Findecanor »
« Reply #2 on: Sun, 09 June 2013, 16:30:58 »
Hmm.... are you tenting?  the modifiers in the middle are hard to reach due to my tenting
